Question about Crock Pots & Slow Cookers
Greenspan ya600 pressure cooker
Greenpan ya600 pressure cooker need to know how to use the pressure cooker part.
Paula deen pressure cooker. Can I use it for slow cooking? What is temp of keep warm? Could put lid on loose. Also, timing notches are mixed into keep warm button. I overcooked my first batch
A pressure cooker is NOT anything close to a slow cooker. The cooking philosophy are practically totally opposites. A pressure cooker basically cooks your food in a fraction of time because it is under pressure. A slow cooker takes hours.
The whole idea of using a pressure cooker is that it is sealed and applies pressure to cook the food faster. The lid needs to be sealed for the pressure cooker to operate properly. It is frequently referred to as "infusion" cooking now days.
You need to read the instruction book that came with the pressure cooker. Pressure cookers usually cook for less than an hour--my homemade pressure cooker spaghetti sauce is cooked in less than 30 minutes. They are nice and were very popular long before anyone thought of microwaves and slow cookers. However, there are some precautions to be taken. There must be water or liquid in a pressure cooker. The rubber seal needs to be cleaned frequently and, when the rubber seal warps/stretches and no longer seals, it needs to be replaced. There are also certain foods that CANNOT be cooked in a pressure cooker like rice, dry beans, etc. The pressure control valve operates to regulate the amount of pressure and releases extra pressure otherwise the unit would blow up (very dangerous!). Most pressure cookers (required on all new ones) have a small rubber emergency stopper that will "blow off" in case the pressure is too high. I've seen this happen and my mother cleaning potatoes & meat from the ceiling!
Mar 03, 2017 | Crock Pots & Slow Cookers
Is there somewhere I can buy a replacement pressure valve?
Tracy, Check the attached links or try google search your make replacement pressure valve. Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Pressure Cooker Parts
Fagor America Shop
May 28, 2016 | Crock Pots & Slow Cookers
I have an all clad pressure cooker I need to know how long to cook a 5 pound pork roast for pork tocos
Hi Sharon! If you want the seasonings to get all thru the meat, I would cut it into about 6 pieces. Add your seasonings and cook it for 20 - 25 minutes. I have been cooking for 50 years and bought one of the electric digital pressure cookers. Liked it so much I bought another one. I made a pork roast about 2 weeks ago and I cooked mine for 25 minutes, It was so tender I could pull it apart with dinner forks. The seasonings I used were fresh diced onions ( 1 med) 2 cloves fresh garlic diced, salt and pepper to taste. Hope this helps.
Jan 24, 2016 | Crock Pots & Slow Cookers
Pressure cooker manuals
You can find a pretty good collection of pressure cooker manuals here. You didn't mention the manufacturer, so just find them on the list and then click to see all of the pressure cooker manuals available for that pressure cooker:
http://www.hippressurecooking.com/pressure-cooker-manual-library/
Aug 23, 2014 | Crock Pots & Slow Cookers
Where can I purchase a replacment pan?
Go to this site http://www.crock-pot.com/CustomerService.aspx?id=rpt and put in your model number (located on the bottom of the unit) and you can order the liner and other parts for your crock pot.
Jun 23, 2014 | Greenpan Premier Pressure Cooker
Cooker manual needed for philippe richard 8 qt pressure cooker
I purchased a Philippe Richard 6 qt pressure cooker and the second time I used it I noticed steam venting out of the pressure handle lock. later I stepped on something in the floor. it was the aluminum part for the pressure lock. I didassembled the handle but don't know how to get the part back in place, please advise. thank you
Russell Johnson
Ozark, Arkansas
Dec 30, 2011 | Crock Pots & Slow Cookers
I just need to know what the size of the wolfgang puck electric pressure cooker rice measuring cup is. i lost mine.
Replacement parts for the Wolfgang Puck pressure cookers are difficult to find and I just received an e-mail back from an earlier inquiry to the the company advising that parts are available here:
http://www.wpcookware.com/categories.asp?cat=29
A rice measuring cup can be purchased on-line; no information available on it's size.
Jan 26, 2011 | Wolfgang Puck 5-Quart Electronic Pressure...
Crock Pots & Slow Cookers Logo
80 people viewed this question
Top Crock Pots & Slow Cookers Experts
tsalagi152
charles
Irene Tulloch
Are you a Crock Pot and Slow Cooker Expert? Answer questions, earn points and help others
