Question about RC Remote Control Rc Helicopter
Have trex 450 v2 , with hobby wing ESC , two rudder servo burn up under two different transmit
  • 35 Answers
Have you got a digital or analogue servo in the tail. You have to select what type you are using on the gyro. If you use an analogue one and switch the gyro to digital, that will fry the servo for sure, iv'e burnt a hole in a servo case before. ( slap own face )
Posted on Dec 07, 2014
I recently rebuilt my trex 600, left the servos hanging, put it back together, and the S9255 front, left cyclic is not working. at all, no life is it repairable
Check the continuity in the servo motor from the board connectors (so it includes the wires) with a multimeter set on resistance - if it's not even registering then it's dead - the connectors have been ripped.
Nov 11, 2014 | Futaba S9255 High-Torque Heli Digital...
I have a brand new Hobby Zone Champ RTF. For awhile, it will do fine. Then, all at once the rudder control stops working. All other parts of the plane are fine. Then a few minutes later it can be fine....
I have the same problem with my champ. Rudder loses control intermittently. If I open it and flick the gear a little it sometimes responds. Any solution yet?
Feb 18, 2011 | Hobby Zone Champ RTF
Have hobbyzone firebird commander 2, new to flying. Could not get it off the ground, kept veering to right - and my friend's new, same plane, also did the same, yet veered to the left. Help
Some RTF aircraft are not quite RTF as they sometimes need trim adjustments. Also, a wing could be heavier on one side than the other as RTF models are mass produced with cheap and cheaply assembled components.
For a quick balance check, remove the prop and obtain an electrical terminal block (aka Chocolate block). You will need just the brass terminal insert with both screws.
Remove the prop and put the terminal onto the prop spindle. On the other open end of this, you need to insert a small curtain hook (ones that are used to hold up net curtain wires). Insert this into the other end. To the hook, tie a short length of nylon or cotton. Suspend the cotton from a platform such as a shelf. You need to be able to hang the aircraft without it touching the wall but it needs to be close to the wall. Once done, obtain a tape rule and measure the leading edge END of the wing. Move the tape to the other wing and make sure that the same position aligns with the same mark on the rule. If it doesn't, you need to add a minute amount of weight. About a gram, to the higher wing.
If it is fine, then remove the cotton and then tie a loop into it. Make another cotton string loop identical and hang it one plane length away. Using a small piece of sticky tape, tape the cotton to the tape and then to the extreme top of the tail fin. Loop the other cotton loop over the prop spindle, making in effect a cradle system. Again, use a tape rule to ensure that the both wings sit at exactly the same height. Add a piece of tape to the lighter wing to level it. A better way is to use nail varnish as it levels itself and prevents wing surface issues.
If both wings are okay, then it may be the tail fin rudder. It could be stuck on the right side rather than in the middle. This makes the aircraft fly to the right the faster the speed is, even taking off. Try trimming the rudder with the trim control on the transmitter or servo link.
If all else fails....buy a model boat as it could be the operator....
Feb 13, 2011 | Hobby Zone Firebird Commander 2 RTF...
The Esky BELT-CP 450 V2 that I purchased has some issues that I need help on. Questions are as follows. After I plug the battery in and sync the gyro and controller I ease up on that throttle as...
Hi
The one problem with some of these copters on 49MHz and 27Mhz are that the manufacture used a splash technique for the frequency. Meaning there is no frequency separation. If two of you are on 27mhz then neither will work. Same for 49mhz. One 27mhz and 1 49mhz should work OK. Now foreign countries use different frequencies because their cell phones are on 27 mhz and 49mhz. So you may have a problem there.
Aug 12, 2010 | Esky 6-Channel 2.4GHz BELT-CP 450 V2 RC...
Hi i have a futaba gy401 gyro with a s9254 tail servo, i had a crash and since then my tail servo constantly wags from left to right every time i switch on heli, i have tried putting the gyro on another...
Hi
If you put the gyro on another helicopter and have the same problem then you'll need to replace it. I've tried repairing these in my lab but just not worth the effort. Good luck
May 02, 2010 | Toys
Copy of instuctions for fighter squadron
Flight and Weapons
Joystick
Button 1 fire main weapon Button 2 fire guns Keyboard
E engine on/off Ctrl P props feather on/off P toggle autopilot + increase throttle - decrease throttle F flaps down Shift F flaps up G landing gear up/down B toggle wheel brakes Ctrl E eject T target Space fire guns 1 select main weapon M.G. 2 select main weapon cannon 3 select main weapon all guns 4 select rockets 5 select bombs 6 select bomb bays A arm master weapon Enter weapons release D toggle bomb bay door Wingman Commands
J as you were K form up on my wing L attack my target ; disengage ' return to base Rudder/Trim
< rudder left > rudder right / rudder center Left Arrow trim left Right Arrow trim right Up Arrow trim up Down Arrow trim down Ctrl Left Arrow rudder trim left Ctrl Right Arrow rudder trim right View Selections
F1 set designation padlock F2 external F3 chase F4 weapon F5 next vehicle Shift F5 previous vehicle F6 command vehicle Shift F6 A.I.-controlled vehicle F7 next crew Shift F7 previous crew F8 tower view F9 quick view 1 F10 quick view 2 F11 quick view 3 F12 quick view 4 M in mission map Shift M in mission map close-up Overlays
H toggle HUD Shift H HUD mode Ctrl H HUD color Shift I HUD intensity up Ctrl I HUD intensity down Alt M target state R target map range Alt W weapons state Alt V vehicle I.D. state Alt I I.D. state Inside Plane Views
Numpad 8 foward Numpad 2 aft(behind) Numpad 4 left Numpad 6 right Numpad 5 up Numpad 0 down Shift Numpad 8 pan up(digital) Shift Numpad 2 pan down(digital) Shift Numpad 4 pan left(digital) Shift Numpad 6 pan right(digital) Ctrl Numpad 7 shift up Ctrl Numpad 1 shift down Ctrl Numpad 4 shift left Ctrl Numpad 6 shift right Ctrl Numpad 8 shift aft Ctrl Numpad 2 shift fore [ zoom in ] zoom out Shift Numpad 5 center your view System
Z screenshot Esc end mission Shift Esc pause game Ctrl Esc end program Ctrl - reduce window Ctrl Equal Sign enlarge window Shift - reduce gamma Shift + increase gamma Network
~ radio chat
Sep 22, 2009 | Activision Fighter Squadron for Windows
Cutting cost on wing production, resulting in a nasty crash!
i normaly only repair large aircraft, but it seems your old good wing was fatigued from regular use and broke, and the new ones are of poor asian quality, thats why they are snaping. i assume the wings are folding up, so on the bottom attach a very thin wire (stainless lockwire if you can get) to the ends of the wing to fuse, at least 30 deg. from wing (like bottom of wing to bottom of fuse)
Jul 24, 2009 | Hobby Zone Aerobird 3
Crashed blade 400 repaired it unsure of servo settings helicopter tilts forward and tends to spin around
Try setting gain on Gyro (use small plastic screwdriver) to a straight up and down position.
Set Gyro setting in Transmitter to 75%. NOTE: before turning on helicopter, be sure to center all adjustments on transmitter
Side switch on GYRO to DS and make sure the servo is moving in correct direction. If not. reverse direction with switch on side of Gyro. You may need to reverse the controller of Rudder in settings on transmitter.
This worked for me on my Blade and using the same Gyro on a self build 450 heli.
Helimangler
Apr 20, 2009 | E-Flite Blade 400 3D RTF Electric Mini...
Rudder control very slow on CX 2
sounds like your servos are weak or just slow you can get stronger and faster servos check with your local hobby store
Mar 27, 2009 | E-Flite Blade Cx/cx2 Scale Body Sh-60...
Hobbie tower wed page say that can work with 2 ch radio and I purchased because I have 2 ch radio at home. I like to know how can I set it up with 2 ch radio and what I need as a esc (what kind) if this...
You onky need one servo for steering as the esc does the power for you. You should get the basic Tamiya esc from tower. Something like this:
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXGMR6&P=7
Setup instructions will be in the manual and with the ESC.
Mar 20, 2009 | Tamiya America Tamiya 1/10 Rc Hp Off Road...
RC Remote Control Rc Helicopter Logo
114 people viewed this question
Top RC Toys Experts
LP
Tom Chichester
Kevin K.
Are you a RC Toy Expert? Answer questions, earn points and help others
