Question about Fortune ? TOWN & COUNTRY Romney Sons Louis Renault Damsels in Distress Griscom
When I indicate right the left indicator flashes both on the dashboard and outside the car, indicating to the left work fine, the hazards work fine. I have changed the indicator but the same problem persists. 1 Solution Report Abuse Print this Page Share this Page
    Novelist:
  • 180 Answers
Here's my guess... An often overlooked problem in electrical apparatuses on a vehicle is the GROUND connections.. A light can be grounded by its case.... OR there can be a special wire running to it from the frame to serve as the ground. I believe you're having a failure of one of your turn signal lamps on the right side of the vehicle (could be either front or rear) to properly ground to the frame or body of your vehicle. The failure could result in the turn signal circuitry feeding back and using the other light fixtures grounding to serve in making a circuit...for the turn signal flasher.... and causing the other lights to flash, because THEY are serving as the ground. Let me tell you, a faulty GROUND can create the hardest, weirdest, most confusing problems to diagnose on a vehicle. Good luck.
Posted on Jan 04, 2014
How do i fix my problem, left indicator starts flashing when turn engine on but stalk will not stop left side or start the right side yet hazards work fine
One of the most important safety systems in the car is the Turn signal system. It can help prevent accidents by signalling to other drivers on the road when you need to change course and which way you'll be turning. It is also required by law to have a car dashboard turn signal indicator that works properly. You will need to wire the indicator in your dashboard to the proper lights and locations in the car. For a standard turn signal indicator in which the turn signal lights are the brake lights, please check this link on how you can do this:
How to Wire the Turn Signal Indicator in the Dash
Oct 18, 2014 | Cars & Trucks
Right turn indicator stays on
flasher relay under steering column does not work,switched it with hazard and see if it works,then get the new one,make sure the light on turn signal in front or back is not burned out first
Apr 04, 2014 | 1992 Chevrolet Lumina
Left indicator lights not work
blinking fast indicates a bad bulb on that side. try front and back bulbs
Sep 07, 2013 | Volkswagen Passat Cars & Trucks
I have an 02 kia sportage. my signal lights come on but dont blink outside. no lights for the signal lights come on on the dash at all. also, no hazard lights.
If the 15A HAZARD fuse in the passenger compartment fuse box is OK, power is getting to the hazard function of the flasher unit. Pressing the hzard switch should cause the hazard lights to flash. HOWEVER, there is an electronic time and warning indication system module connected to to the hazard switch lead and that may be affecting things. If the 10A TURN fuse is OK, power is applied to the turn switch (with the engine in START or RUN) and you state you can select a right or left turn. HOWEVER, the RED/WHT and RED/BLU outputs from the flasher unit connect directly to the front and rear turn lamps and the instrument cluster turn indicators so you are not getting any flasher output. Again, that electronic time & warning indication system module could be affecting things
Oct 26, 2012 | Cars & Trucks
I have an opel corsa utility bakkie. the right indicator flashes on the inside fast but no indicator works on the outside , all bulbs were checked and n.f.f...... the left works fine . fuses were checked...
Mine did the same. After a while the other indicators started doing the same. The problem was the flasher unit. Cost was R830-00 for the unit and 10 minutes of labour to replace.
Kobus
Apr 01, 2011 | GPS
Unknown light indicator in the dashboard
it is a rear bulb failure light,have you checked the reversing light bulbs...?
Jun 18, 2010 | 1995 Toyota Camry
Light indicator problems
I would say try and REPLACE the turn signal fuse/relay. It should be a square, black fuse/relay on your fuse panel. They run about $10.00.
Mar 09, 2009 | 1993 Isuzu Trooper
1/2 of my hazards will not work '98 wrangler
check the bulbs. sometimes if one is bad it will cause both to stop working.
Sep 27, 2008 | 1988 Jeep Wrangler
Fortune ? TOWN & COUNTRY Romney Sons Louis Renault Damsels in Distress Griscom Logo
Top Fortune ? Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Fortune ? Audio Player and Recorder Expert? Answer questions, earn points and help others
