Question about Ford 8N Tractor
I have fire at coil but no fire through sparkplug wires
  • 653 Answers
The problem sounds like it is your distributor. Replace the ignition points and condenser, make sure the points are gapped properly. If you still don't get fire at the plugs, change the distributor cap, rotor, and wires. Points and condenser kit runs $9.72.
http://www.yesterdaystractors.com/ATK7FA_Ignition-Kit-4-Cylinder_14717.htm?gclid=CJzJscSG47sCFXPNOgod31wAqA
Posted on Jan 03, 2014
No fire to sparkplugs
Bit late here, but I love Datsuns! First check if you are getting power to coil on the + side of coil. Pretty much a straight path from ignition switch to coil. Then pull off coil to distributor cable at the distributor and check for spark on that wire when cranking engine over. If good, rotor, distributor cap, plug wires, or sparkplugs need checked. If no spark from coil, it should be tested with an ohmmeter for proper resistance values, or swap in another coil.
Does it have mechanical points and condenser or electronic ignition?
Nov 22, 2012 | Datsun 510 Cars & Trucks
Diagnostic states 3rd cylinder mis fire
Hello, Depending on the Year of the car, the cars that had a sparkplug with a remote coil, you could have a bad sparkplug wire or a bad coil-pack or a bad sparkplug. For newer cars, the coil is attached to the sparkplug directly on top.
For those newer designs, the coil would need to be tested for that cylinder. Using an Ohmmeter, with 1 lead on top and the other on the tip which touches the sparkplug, it is a 10,000Ohm resistance.
Accessing the sparkplug coil is different for several engines. You may have to remove the Intake manifold to reach the coil and you may need to remove part of the fuel rail to remove the Intake manifold. Switching out a plug or coil is easy once you can get to it.
You can have your scans done free at Autozone, Oreillys, or Advance autoparts and they will clear the problem codes once you replace parts. I hope this Solution is very helpful to you.
Jun 18, 2011 | Mercury Marquis Cars & Trucks
This is a 1984 1200 that will not start and back fires thru the exhaust and carbs
hello
Back fire is an indication that the bike is firing incorrectly.
Your timing chain is probably stretched, due to the year.
inproper valve timing due to stretched timing chain will make the bike backfire.
I have other thoughts like stuck valves or inproper sparkplug wires on wrong plug,
i always start with easier and less expensive method.
1st check your sparkplug wires to make sure they are on the right plug.
2nd pull sparkplugs and do compression and leakdown test.
3rd pull componets to see if valves are opening and closing, (valve clearance check)
4th if valves are good, then timing chain is probably stretched.
5th if timing chain and timing marks are good, and valves are good, then proceed to
testing the signal generator to make sure your getting a signal to the cdi,
6th if you have a signal to cdi, the cdi tells which coil to fire. either # 1&4 or # 2&3.
if signal generator is working, but coils aren't firing right then its the cdi.
obviously your coils work because its firing, just back firing.
Thats all it could be from easiest to hardest.
Good luck and have a great weekend.
Big Al
May 21, 2011 | 1987 Honda GL 1200 Aspencade Gold Wing
2.5 cranks ,has no spark
Check the fuse and relay in the fuse panel for a blown fuse. Then unplug the power wire to coil and test for power to coil. If you are getting power to coil then it will be the coil causing the problem. Use an inline tester to connect between the coil tower and sparkplug wire to correctly see if the coil is putting out fire. Could be bad sparkplug wires or plugs. Hope this will help you.
May 31, 2010 | 1994 Dodge Dakota Club Cab
Engine will not start in sunne days
Check the coil for fire during the day. Use an inline spark plug tester to test for fire to plugs. Connect the tester between the coil tower and one of the sparkplug wires. Have someone to try and start the car while you are watching the tester. Check each wire from coil to each plug. If no fire then replace the coil. Hope this will help you.
May 23, 2010 | 1997 Dodge Neon
Fireing order 04 midnite star got plug wires mixed
Generally the leads are a tight stretch and having slack if around the wrong way. Take the sparkplugs out and connect each to your best choice of leads. Place these so they are resting metal to metal on the cylinder heads. Place your finger tip tightly over front cylinder sparkplug hole and rotate engine with ignition on. When compression is felt (your finger will "pop" off hole) and the sparkplug that sparks will be the front cylinder coil and lead. Repeat procedure with rear cylinder to confirm.....mark F and R on lead caps when your done!
Cheers.
May 06, 2010 | 2003 Yamaha V Star Classic
Have a 2.2 4 cylinder distributorless chevy egine , acts like it might be out of time .Is there any way to check it ?
They dont really go out of time...These were common for bad sparkplug wires and ignition coils having open circuts...check for spark on plugwires 1 and 4 and 2 and 3 if there is no spark on 1 and 4 replace ignition coil the same with 2,3 the coils do fire the 2 sparkplugs simultainously ..and if there is an open circut in the plug wire only one wire will not have spark..if its a coil 2 wires will have no spark..
Apr 05, 2010 | Chevrolet Cavalier Cars & Trucks
No fire at the sparkplug
Take the flywheel cover off and remove the wire that is attached to the coil. Then try to restart (put the cover back on). If you get spark then you have a wiring issue (coil is being grounded) if it doesn't start then your coil is bad and needs to be replaced.
Report back.
Aug 19, 2009 | Garden
03 ford taurus wont fire ,spins over,no fire
What you do is take either and old sparkplug from the car or pull one from the car and connect one of the sparkplug wires to it. Then with an insulated set of pliers hold the sparkplug so the electrode is grounded. Then have someone crank the car over. This is best done at night so you can see if there is a spark. During the day however you should be able to here a spark. If not probably a bad coil.
Jul 20, 2009 | 2003 Ford Taurus
No Spark
The " FIRE" doesnt come to the coil from any of those things you have changed.......The "fire" comes from the coil TO those items!!!! Good luck, RC
Mar 06, 2009 | 1996 Jeep Cherokee Country
Ford 8N Tractor Logo
195 people viewed this question
Top Ford Toys Experts
Philip Doherty
Level 1 Expert
D. E. Hev
Are you a Ford Toy Expert? Answer questions, earn points and help others
