Question about Canon Imageclass D1350 Multifunction Fax Copier Printer Scanner Bw
Error message when printing d1350 imageclass - Canon Imageclass D1350 Multifunction Fax Copier Printer Scanner Bw
2 Suggested Answers
wheatlandsvc
  • 1110 Answers
SOURCE: my canon ImageClass MF6550 only make blank copies
I have copy and pasted this solution from another question I answered from a person with the same issue. Several people have reposnded that this solution helped them very much.
This is either your toner cartridge or more likely the plastic arm that opens the laser shutter is broken. When you insert a toner and close the access door, there is a plastic arm that opens the laser shutter. If this shutter does not open it blocks the laser and results in blank copies. If the arm is broken you CAN open the laser shutter manually and block it open. What you need to do it open the cartridge access door, remove the cartridge and look for a 1/2 inch wide slot running from left to right in the metal frame that is in the back upper section where the cartridge goes. The plastic arm that operates the black plastic shutter is on the right side. If broken you can manually lift up the shutter and "block" it open using something like a folded up scrap of paper. I know it sounds strange but I have used this repair on several of my customers machines and they have all worked fine since. If you can not find or effect the repair yourself at least you will know where to point the service person when they come out to look at it.
Good Luck and Thank You for using Fixya.
Posted on Apr 13, 2010
How do I set my canon image class d1350 to print a tx received report after a fax has been sent?
The imageClass D1350 should have a report button above the 3 in the number pad. This is to the left of the Energy Saver button. If you don't have that button, please check the model number. Once this button is pressed, you should see the header Report Settings. Select TX Report and set this option to ON.
This is shown in the manual for the D1350 which is available on Canon's support page: https://www.usa.canon.com/internet/portal/us/home/support/details/printers/black-and-white-laser/d1350 . Click on the Manuals tab. The direct link to the Basic Operation Guide is http://gdlp01.c-wss.com/gds/0/0300007490/02/D1370_1350_1320_BASIC_en-us_R_1.pdf . See page 10-7 (page 169 of the PDF) for accessing the Reports setting menu. The buttons on the D1350 are shown on page 1-4 (page 28 of the PDF).
I hope this helps.
Mar 21, 2017 | Canon Office Equipment & Supplies
Why my canon ir1133 printer is showing e733/0000 error message?
ERROR E733-0000 Stops printing and shows sign "Turn ...
www.fixya.com/support/t21602993-error_e733_0000
Nov 20, 2013 - ERROR E733-0000 Stops printing and shows sign "Turn main power ON". Error ... error message when printing d1350 imageclass. Jan 03 ...
Oct 29, 2015 | Canon imageRUNNER 1133 Laser Multifunction...
CODE 162,0,0 ON CANON D1350
This happens across the range of Canon Printers. The fix is to push the right button! Yeh I have a differing model, but the answer is the same. Go to the printer and select remote scan. Then invoke computer program. Some one has to be boss either the printer or the computer for scanning.
I can make the scanner printer the boss and issue a TIFF scan to the computer. Just push scan on the printer and select computer (it does a push data)
I can make the computer the boss by selecting the steps below:
Please choose what option you require. Ignore the model number.
The error codes 162,0,0, or 255,0,0, usually indicate that you have not selected a scan type at the machine. Please follow the steps below to perform a scan from the image I-SENSYS MF8230Cn:
Verify that MF Toolbox is closed on the computer and press the [SCAN] button on the printer.
Highlight [Remote Scanner] and press [OK]. The screen will show, "Remote Scanner. Waiting online...".
On the computer, open the MF Toolbox and select [PDF].
Click the green [START] button on the [PDF] window. The machine will start processing the scan.
If you receive any errors or need further assistance with the I-SENSYS MF8230Cn, we recommend that you contact us at 1-800-OK-CANON (1-800-652-2666).
Sep 29, 2014 | Canon imageCLASS D1350
ERROR E733-0000
E733-0000
Error code : Printer communication error Communication error between the Engine Controller PCB and the Main Controller PCB occurred.
Try turning off the device, unplug power cable and turn on to flush the memory. Change the power cable as well. If this doesn't resolve the issue, probably something is loose in the board. Contact your support.
Nov 20, 2013 | Canon Imageclass D1350 Multifunction Fax...
I am getting an error message - E071 on the MF8170C. I have no idea what it is.
I also had this error message. Cleaning contacts and restarting made me able to copy/print.
Aug 18, 2010 | Canon imageCLASS MF8170C All-In-One Laser...
Canon Imageclass MF4370dn constant paper jam errors
Dear
Inside the back panel there are paper sensors attached to lever, a small spring connected to lever to keep its home position, the spring may dislocated from its position or the lever sticked to the base. some times a small piece of paper sticked at this may cause the problem.
Thanks.
Apr 20, 2009 | Canon imageCLASS MF4150 All-In-One Laser...
Color imageclass mf8170c
You Cyan cartridge is getting low. Buy one now because there is no warning to when it decides to up and quit and you wont be able to print anything!!!!
Jan 23, 2008 | Canon imageCLASS MF8170C All-In-One Laser...
Canon Imageclass D1350 Multifunction Fax Copier Printer Scanner Bw Logo
Top Canon Computers & Internet Experts
Computer Links
Tony
old marine
old marine
Are you a Canon Computer and Internet Expert? Answer questions, earn points and help others
