Question about RC Remote Control Rc Helicopter
Problem with servos burning up - RC Remote Control Rc Helicopter
  • 35 Answers
Terry, look at my other answers about this, could it be another post by you? Digital and anologue tail servos need selecting on your gyro ;)
Posted on Dec 07, 2014
Cruise control doesn't work on 1996 dodge neon. no air bag lite and cruise light doesn't come on
25653844-lbgspggdnnvo0gv1s31q0hti-1-0.jpg this is a cruise control servo maybe it burned put or the cable broke the switch not working the connection came loose at the servo
Apr 18, 2015 | 1996 Dodge Neon
Have trex 450 v2 , with hobby wing ESC , two rudder servo burn up under two different transmit
have you got a digital or analogue servo in the tail. You have to select what type you are using on the gyro. If you use an analogue one and switch the gyro to digital, that will fry the servo for sure, iv'e burnt a hole in a servo case before. ( slap own face )
Jan 03, 2014 | RC Remote Control Rc Helicopter
06 f150 4x4 the 4wheel drive will not go into 4 low but will go into 4high
You need to have your foot on the brake, put the Trans in Neutral, and then shift the Selector to 4 Wheel low. If this does not work you need to check the wire at the transmission for Voltage changes. Each position on the selector has a Resistor and they use 1 Servo to make the gear changes. You need to see if the Selector has different Voltages in each position. If it does, then the Servo is not responding.
But do not forget the Interlock of the brake pedal for the gears to change. Also check for light at the Selector switch. If the lightbulb is burned out you will sometimes throw off resistance and wind up missing functions.
Feb 17, 2011 | Ford F-150 Cars & Trucks
Transmission slips
About the transmission slipping, which I have heard several complaints about, it might be an improper gear ratio code pop up and a gear slipping code popup. I would like to know in what gear it actually slips.
A common problem is also that the servo bores wear out and the servo piston gets cocked and breaks or the band just burns up.This could also be your gear ratio error.The fix is to drill out the servo bores and sleeve them. If you get an overhaul, which I believe any dealership you take it to would advise you to do, make sure they do that whether it needs it or not. If you can find a used trans that is extremely low mileage then I would buy it. A real low mileage trans will be very clean(bolts still shiny).
Hope this helps...
Jan 14, 2011 | 2000 Lincoln LS
While sitting at lights even pressure on brake pedal. brake pedal sinks to floor . engine revs drop to 600 rpm's . when brake pedal is released engine rev's increase to 900 rpm's? Dealer mechanics say it...
not normal at all,a couple of causes 1 small valve at the front of the servo unit,2busted pipe coming from the servo unit,3the servo unit itself needs replaced.so where is the servo unit?.if you lift the hood you will see in front of the brake pedal only inside the engine compartment look closely and try to judge it ,its about the size of a bottom of a small sauspan only about 4/5 times the thicknes,thats your servo and that where your problem is.adrian,,,
Dec 03, 2010 | Dodge Dakota Cars & Trucks
Why is there no reverse action?
MAKE SURE FLUID LEVEL OKAY FLUID + FILTER HAS BEEN CHANGED RIGHT TIME PERIOD. POSSIBLE CAUSES FOR TRANSMISSION SLIPPING IN REVERSE FORWARD CLUTCH NOT RELEASING.DIRECT CLUTCH HOUSING HAS BURNED CLUTCH PLATES OR CLUTCHES NOT RELEASING,CRACKED PISTON OR HOUSING.THE REVERSE INPUT CLUTCH HOUSING HAS WORN CLUTCH PLATES CRACKED WELD ON THE REVERSE INPUT HOUSING AND DRUM.THE REAR SERVO ACCUMULATOR HAS DAMAGE SERVO PISTON SEAL OR STUCK PISTON.THE LOW REVERSE CLUTCH COULD HAVE WORN CLUTCH PLATES DAMAGE SEALS OR DEFECTS IN THE PISTONS.
Aug 25, 2010 | 1987 Chevrolet G20
How do you change the throttle servo on a revo 3.3
Disconnect the servo at the receiver, remove the servo horn and linkage from the servo. Remove the four screws that hold the servo to the chassis. Replace with new servo, plug new servo into receiver and turn on transmitter and receiver. With transmitter and receiver on reattach servo horn and linkage. This will make sure that the servo is centered at neutral throttle.
Sep 25, 2009 | Traxxas Rc Revo Nitro Monster Truck
4wheel drive issues
There is a small servo motor on front axle, Check the connections, also check connections on switch. May need to check for voltage to servo motor they often burn out.
May 16, 2009 | 1988 Ford Ranger
RC Remote Control Rc Helicopter Logo
74 people viewed this question
Top RC Toys Experts
Tom Chichester
Kevin K.
Brett Duxbury
Brett Duxbury
Are you a RC Toy Expert? Answer questions, earn points and help others
