Question about LG LB8000ER Air Conditioner
Air not cold
My air conditioner unit is new as off 2006 and its not blowing cold air, could it be already out of freeon in may 2009? is that usual?
  • 700 Answers
If you are always using it, yes it could be. The heat it produce helps in its normal wear and tear. Corrosion is one and dirt helps. Freon could stay in the system as long as it is not getting any break or hole.
If freon is out of the case. Unit not getting cold, the fault could be dirty air filtter, dirty exchanger, dirt in the system itself, or clog. And also you cannot negate it thermostat, could be its setting or actually faulty. And compressor fault.
Posted on May 22, 2009
Air conditioner not working
first check if the compressor engages if not could be fuse, broken wire, or just low on freeon you will need to send it to a ac shop to empty and fill, test for leak
Apr 01, 2014 | 2006 KIA RIO Remote keyless entry
Left Vents blow warm/hot air when calling for cold air
Usually a sign of a faulty blend door under the dash.
The blend doors direct air thru the ac and heater core along with the upper and lower vents.
Sep 12, 2012 | 2009 Chevrolet Silverado 1500
My home air conditioning unit only blows cold air
You have an air flow problems. Clean the outside condenser coil I use on half baking soda and one half joy soadp squirt this on the coil take a coil brush that you can buy at any hardware store. and go up and down on the coil. then take the water hose and squirt it down to clean the soap and dirt off, It this doesn't solve it you will need to clean the fan blower motor the squrrel cage but don't get the motor wet. Next you will need to clean the evaporator coil just take the coil brush and go up and down to clean. This should solve your problem, What kind of readings did you get on the low side and high side. You should have a 40 degree drop across the evapartor. And the high side should be the out side temp and 30 degrees. If you have any questions you can email me at crislsparks@gmail .com. What kind of freon does it the unit take. It will tell you on the nameplate on the outside unit.
Jun 25, 2010 | Ruud UAKA042 Air Conditioner
Air conditioner quit working
first thing to check is loss of gas pressure due to leaks , this is the most common failure.
if gas is good then could be a number if things , compressor , climate controller unit , bad wiring or connections somewhere.
Aug 18, 2009 | Pontiac Aztek Cars & Trucks
Rear AC in 2003 Honda Pilot blowing warm air.
Sounds like the blower transistor is bad. Here's a link to the service bulletin. http://www.in.honda.com/Rjanisis/pubs/SB/A03-048.PDF
Jun 11, 2009 | Whirlwind FH-778 Air Conditioner
After boost air conditioner started blowing hot air
BLOWING HOT AIR YOU MAY HAVE A RESTRICTION ON THE SYSTEM, OR MAYBE A REAL BAD LEAK THAT UR FREEON IS ALL GONE,
May 28, 2009 | 2006 Chevrolet Trailblazer
Not getting any cool air
Unit works good? Is the compressor coming on but not blowing cold air? If the compressor is running but not cooling, then the main issue is usually with cleanliness of the condenser. Wash it out if this is the case. If the compressor is not coming on, multiple problems could be the reason.
These units do not have service ports as a normal AC does. If you have lost freon then there is a leak in the system somewhere as they are sealed. The process for recharging a rooftop unit is usually expensive and not fail safe. I would recommend a new unit if a leak is discovered.
May 22, 2009 | Coleman Mach III Air Conditioner
PINGUINO PAC-L90 PORTABLE AIRCONDITIONER
yes we charge freon if it leaks out, but we fix the leak first. but also it may have electrical problem only, better get it check with a technician
May 09, 2009 | DeLonghi Pinguino PACL90 Portable Air...
Doesn't blow hard anymore
First make sure unit is correct for the size of room. You may have to mount it permanently so that it's tilted so it drains out the window. Check freeon level.
Jul 15, 2008 | Haier hwr10xc6 Air Conditioner
LG LB8000ER Air Conditioner Logo
209 people viewed this question
Top LG Heating & Cooling Experts
Donni Steen
Tim Whalen
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
