Question about 3M Office Equipment & Supplies
3m 630 reader printer - error code 80
1980s Fiche/aperture card reader. Need operators manual. Is showing error code 80 & can't do anything. Have pushed reset in back, nothing happens. Calls for "key operator". Anyone elp?
3 Suggested Answers
  • 12 Answers
SOURCE: I need to reset the key operator ID on the printer?
Unless it was changed by someone, the default key op code is 0000. That's 4 zeros, not 'O".
Dan
Posted on Jan 09, 2009
SOURCE: 3M Microfilm Reader/Printer 35mm film repair
3m 630 microfilm printer and viewer, the paper is getting hung up and scorching the paper, and the light will not come on for viewing. Also bad image.
Posted on Mar 24, 2010
Format memory images
Paul,
You are using misleading words. You can format a memory card. And images can have a certain format, So I wonder what you mean.
Your camera can use the following format to save images:
5M (2592x1944pixels 4:3), 3M (2048x1536pixels 4:3),
2M (1920x1080pixels 16:9 )
VGA (640x480pixels 4:3)
To switch to another image format, press the Menu / OK button
Press the up down button till you see resolution then again press Menu / OK
with the up / down goto the format you want and press OK to confirm the selection.
The manual does not say anything about formatting the memory card. If you want to format a new memory card, put it in an external memory card reader and conner it to the computer. Format with FAT32. But my guess is, when you insert a memory card in the camera, it will show CD card inserted. that is the moment the camera will format the camera.
Success
Jan 26, 2014 | Vivitar ViviCam 5024 Digital Camera
How do i hook up my tablet to a 3m mobile projector mp410
yes, you need to look at the projector and see if it likes the Android operating system as it might not ... now you might also check into google play and see if anything is there to help with this fiasco... or look into the projector options/operators manual to see what it can read... once again, google might help
Dec 29, 2013 | 3M MP-410 Pocket Mobile Projector
E000719-0031 error code for canon ir c5250
E719 0031 00 Title Error in serial communication at the start of the New Card
Reader
Description Failure in communication with the serial New Card
Reader at start-up.
Remedy - Check if the cable of the serial New Card Reader is
disconnected.
- Take out the serial New Card Reader.
- COPIER > Function > CLEAR > CARD
- COPIER > Function > CLEAR > ERR
Dec 20, 2013 | Canon Office Equipment & Supplies
Fee error on d300 with Sigma lens with aperture ring
Turn the aperture ring on the lens to its smallest setting (largest f/number) and then forget it's there. You can control the aperture from the camera body, the same way as on lenses without an aperture ring.
Oct 13, 2012 | Nikon D300 Digital Camera
3M MP7640i Personal Projector lamp wont light
it's the vents and the passage to the blower.
Dec 24, 2009 | 3M MP 7640i Multimedia Projector
Error code : err
If your lens has an aperture ring, do note that most of these lenses require the ring to be locked at a certain position for it to work. In the course of using the lens, you may have accidentally unlocked the aperture ring and moved it out of position. This is a common problem.
To fix this error, try this:
1. Turn off camera
2. Turn the aperture ring clockwise and then lock it
3. Turn on the camera
If you still encounter the same problem, repeat the same steps but turn the aperture ring counter-clockwise. Hope this helps.
NOTE: Please rate our help to keep this free service online
Jun 19, 2009 | Nikon D80 Digital Camera with 18-135mm...
Cant get rid of blinking error message, nothing works
The [H4-00] system error popped up when the power went out of the house. I called Sharp tech support (1-630-378-3590) and was talking to their tech support in less than a minute.
The FIX? Just press the following keystrokes:
# * C * This will clear the display error, now press…14, then press the green button twice. This should let your printer start to warm up and you have fixed your problem.
Dec 20, 2007 | Office Equipment & Supplies
Dec 18, 2007 | Office Equipment & Supplies
Memory Card Error
Do not ever format a card.,any card via a computer That does it in. For camera use it will not be recognised. Put the card in the card reader and if there is anything at all on it delete it. Try to reformat in the camera again- failing that -new card.
Jun 21, 2007 | Canon PowerShot A80 Digital Camera
Camera flashes "error" when turned on
Check if the aperture is set on anything other than 22. This would generate an error message. the N50 (and other auto Nikon cameras) needs to have the lens aperture set to the smallest -- AutoFocus lenses have a lock on them to lock the aperture at the smallest. Some models, such as the N5, can be set to use either the lens' aperture ring or the camera's command dial to set the aperture, but most simpler Nikon auto cameras can only be set by the camera. Setting the lens to its smallest aperture tells the camera that it can control the lens. If the lens is set to anything else than the smallest aperture, F-- shows up on the camera's LCD, and the camera locks up. Check your camera manual for complete info.
Mar 05, 2006 | Nikon N50 35mm SLR Camera
63 people viewed this question
Top 3M Office Equipment & Supplies Experts
jasbo
jasbo
Are you a 3M Office Equipment and Supply Expert? Answer questions, earn points and help others
