Question about HP PAVILION M8200N PC Desktop
How do I enter setup?
How do I enter setup if my monitor doesn't get anything. Stays black not even power indicator light. I know monitor works since I'm using it now on another computer.
  • 818 Answers
Setup is usually entered by pressing the delete button or F2 (or F1 .. it depends on your computer..) during the boot-up process.
However, as you say there's absolutely nothing on your monitor which you know works, suggests that the fault lies elsewhere. If there's nothing at all on your monitor it may be a failed video card/chip.
I take it that your computer actually powers up even though you can see nothing on the monitor?
If you can, try another video card in your computer. If the monitor then works, you know it is the old video card/chip at fault.
If, after trying a replacement video card and there's still nothing on the monitor, you'll have to suspect a motherboard fault.
Posted on Jan 03, 2014
4 Suggested Answers
nyilasrobert
  • 627 Answers
SOURCE: PC monitor warning error of PC entering power saving mode
it is CPU overheating problem, Go out and get some composite paste which is keeping the temp down
Posted on Jul 13, 2009
  • 146 Answers
SOURCE: Black screen not booting
check both your power and video connections to the monitor, sounds more like a monitor power issue.
if the connections appear ok, but screen still blank, try connecting a known good working monitor from somewhere else and see if it works with your pc, if it does, your original monitor is faulty, if it doesn't, you have a pc video issue.
Posted on Jan 14, 2008
SOURCE: Computer stays powered up even when power button
hi
you have problwm with disply chack your disply setting from the bios settings
Posted on May 25, 2010
My flatron L1710S flat screen will not come out of power saving mode. When I turn on the monitor the power button/light is green for a few seconds, the screen indicated "power saving mode", then...
I switch on my PC, ensuring that all cables, leads and power supplies are connected properly. The tower powers up no problems at all. I switch the screen on, the green led lights up, the screen is completely black. A blue box appears centrally on the screen with the text 'power saving mode'. The green led light turns amber and then the screen just goes black.
Please don't suggest going to control panel, as I can't get that far.
PLEASE PLEASE CAN ANYONE SUGGEST ANYTHING give me
Mar 08, 2011 | LG Flatron L1710S 17" LCD Monitor
Hi, I have a V7 L19WA - 19" widescreen monitor.
The fact that you can see a faint picture indicates that the monitor is working but the backlight circuit has a problem. The typical failures are blown transistors or bad capacitors. This can be troubleshot if you know how to unsolder and check the components with a meter. Don't know how technical you are, but if you are not, you could take to to an electronic repair service to fix. Hope this helps you.
Jan 24, 2011 | Videoseven L19WA 19" LCD Monitor
MY SCREEN IS BLACK IS THERE ANY WAY TO FIX IT
if there is no power getting to the monitor ( indicator light ), test the fuse in the power lead first.Ensure it is inserted tightly.
If there is power to the monitor, the green indicator light should be steady, if it is flashing there is a problem with the display
Test the monitor in another computer or laptop.
If t stays black , I'd supect a faulty backlight or more probably a blown power capacitor whih will need checking and replacing
Dec 30, 2010 | HP L1955 19" LCD Monitor
I HAVE A SAMSUNG 2253 22' LCD MONITOR,POWER LIGHT FLASHES,AND SCREEN STAYS BLACK ,IT TRYS TO LIGHT UP ,BUT STAYS BLACK,MY OLD TINY 15' LCD WORKS FINE ON THE SAME COMPUTER,MY 22 USED TO WORK FINE??????
A flashing power light like that indicated a blown power supply. Your monitor should be under warranty with Samsung. Check the mfg date on the back sticker, if it is less than 3 years then contact Samsung. If it is out of warranty then contact us at tech@ccl-la.com and we can get you the info you need to do the repair yourself.
Buddy
Corporate Computer
www.ccl-la.com
Dec 22, 2009 | Computers & Internet
Samsung monitor power light flashes long and short
Check the electrolytic capacitors with values 820uf/25V and 1000uf/10v. Replace them if found leaky..
Nov 21, 2009 | Samsung SyncMaster 932B LCD Monitor
ViewSonic LCD Monitor Went Blank
It is probably a bad INVERTER and / or backlight fluorescent bulb.
Jul 02, 2009 | ViewSonic Computers & Internet
Monitor stays black
First make sure you have the monitor cables correct. Try another monitor hopefully works so you can go into your device manager and make sure the right drivers are loaded and that your monitor is listed. You may do some research because I'm not sure but I think your monitor uses a back light & an inverter which is replaceable and not usually a difficult job or to expensive. Labor of coarse cost more than the parts. Monitors use a video card or on board video so make sure these are not the problem.
Are you sure its not in wake mode in the bios?
If you shine a light on the monitor when the comp. is on and the monitor light is on you may be able to see your screen. That would be the back light.
When if all and what was going on when it stopped working?
Jul 07, 2008 | KDS Radius RAD-7 17" Flat Panel LCD...
MX 6124 Gateway notebook screen stays black when powering up
Repaired! This sounde like a fuelty screen or screen inverter. To check this, connect to an external monitor, if the external works properly, then it's the screen or inverter. If the external doesn't work, let me know and we'll run the problem down to a more indepth (internal) trouble shoot.
Jun 28, 2008 | Computers & Internet
HP monitor problems
Look into trying a PCI video card. I doubt the monitor went bad, however, the onboard video controller for the PC may have.
Mar 19, 2008 | Computers & Internet
HP PAVILION M8200N  PC Desktop Logo
1,868 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
