I attached the return chord and drive strap as illustrated. But there's s slackness in the rower chain. When I pull it only pulls in one direction. It doesn't pull back as it should. What have I done wrong or should I do?
SOURCE: Slack in line on rowing machine
extend the line to its max required length while you are sitting on the machine { as using } then get someone else to adjust the slack on the line and make it taught , the adjustment should be a bolt and nut type located on the main wheel . do not adjust the line from the seat as this may dislodge the seat . happy rowing
SOURCE: Can someone tell me where toput batteries in reebok rower?
Find the Reebok rower manual here.
SOURCE: Nordic Rower replacement wheel
Nordic Rowers were made by Water Rowers, which still exists and sells parts.
SOURCE: Cord seems to be slipping off the flywheel; I pull
You have a bungee problem, your bungees broke. You can easily order new bungees from your manufacturer. They are also easy to replace once you take off the side of the fan.
