Question about Microsoft X Box 360 Console 20 Gb Games,wireless Adapter,controller Bundle
Samsung how to connect
Can I connect my X box to my Samsung E-4350 3D theatre system so I can get the F1 swound effects through the speakers
How do i connect my blue ray Samsung ht-bt1220 2.1 to play through my sky hd box
Connect an optical lead from the sky hd box to the Samsung Blue Ray.
Then change the function button on the Blue Ray to Din 1.
Then change settings on Sky HD box to Dolby and this worked.
Jan 16, 2010 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
I have bouight a samsung home theatre system that comes complete wiht a DVd player - i also have a samsung blu ray player - naturally ithought they would be compatible!! how wrong i was!! the connections...
You have several ways to do this. You can hdmi cables from the two units and plug them into your tv if it supports hdmi and run the audio out portion on the back of the tv and hook that into one of the audion inputs on the surround unit. Or you run audio directly out of the bluray using rca, digital coax, or digital optical cable. Turn the surround reciever to the corresponding input that you choose to use.
Jun 19, 2009 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Gurus, I just bought Samsung Home Theater System which i connected to my Hitachi TV with HDMI cable. I have a Optical Cable going from HT to my TV Optical port. I have another connection from my cable
On the remote control for the Samsung Home Theater System look at the bottom left to a button that says "MODE", those moods change the sound each speaker gives off. if that doesn't work, you might need new wiring because there are other wires that are more durable than the ones that come with it, much better too.
Jun 02, 2009 | Samsung HTP-1200 System
Samsung series 6 tv & Samsung 2:1 home theatre problems
if you got all the lead you should have fibre optics which connects from dvd to tv and then set your dvd to digi in. you should get the sound. i have same cinema system and i have done the same
Jan 13, 2009 | Samsung HT-X20 Home Cinema 600W Theater...
Samsung htz310r home theatre system to samsung tv no sound
make sure the HDMI is a output not an input. then try your settings and see if you have a setting for output audio
Dec 13, 2008 | Audio Players & Recorders
Rear check message on HT-TXQ120 samsung home theatre
Looks like it is to do with the rear wireless speaker. Now, my problem is over. Its gone. I first turned the reciever on and then turned on the rear speaker wirel less on. No rear chk in problem now. Hope this helps. R.
Nov 19, 2008 | Samsung HT-TXQ120 Home Theater System...
PROBLEM HOME THEATRE SYSTEM HTDS490
Hi, Ive had the same problem and after talking to Samsung Tech Support, I re-checked all my speaker wires and thier connection... one wasn't quite making proper contact so I adjusted it and PRESTO all better!!!!!
Sep 28, 2008 | Samsung HT-BD2R 7.1 Channel Blu-ray Home...
Getting home theatre sound AND sound from TV
i dont think you are suppose to have the tv speakers on with the theather systems speakers on because of the magnectic field can cause your tv speakers to mess up.
Jan 30, 2008 | Samsung HT-X40 System
Microsoft X Box 360 Console 20 Gb Games,wireless Adapter,controller Bundle Logo
542 people viewed this question
Top Microsoft Radio Communications Experts
Adrian W
Adrian W
Level 1 Expert
Are you a Microsoft Radio Communication Expert? Answer questions, earn points and help others
