Question about Refrigerators
Fisher paykel repair manual
How to remove top fan
SOURCE: service manuals and diagnostic codes with results/reset code
http://www.aars.com.au/F&P%20Service%20manual%20517735.pdf
Posted on Feb 06, 2009
SOURCE: fisher and paykel B1600E multifunction stove manual
I have a PDF copy of the Fisher & Paykel B1600E user manual
Posted on Jul 08, 2009
  • 10 Answers
SOURCE: Fisher & Paykel GW612 Top Loading Washing
Hi there
That fault is the pump blocked error (no change in water level).
i have a quick and easy way to solve this problem.
first turn the machine off then tilt the machine back and lean it on something(a chair or wall), look underneath, in the top right hand corner of the plastic outer boul you will see a small pump motor it has a fan on it spin this fan and if it is hard to turn that means there is somthing stuck in the drain pump keep turning the fan and try to free whatever is stuck in the pump, then try the machine on spin again all goin well the object in the pump should come out with the drain water(doing this will not harm the machine) if the object is still stuck you will need to get the water out of the machine (bailing or siphioning will work) and tilt the machine back again and take the wires off the pump and there should be a white tab on the boul holding the pump on pull this tab and twist the pump anticlockwise about a quarter turn(you will need a few towels or a boul or bucket to catch the water) and it should come off exposing the blockage.
Hope this solves your Problem.
Nick
Posted on Aug 03, 2009
localwonder
  • 6784 Answers
SOURCE: Noisy, Chattering fan with fisher & paykel fridge.
HI. Just so you know, Hissing and popping is normal on frost free refrigerators, it is the defrost heater, in this case. I would check these following areas to address any other abnormal noises.
If the level of the unit is not adjusted to proper specs, this will create an unstable operating condition, causing many noises to emit from the units structure. inspect the unit for proper level. adjust if needed. Next will be the drain pan. Once removed for cleaning, the pan must be replaced in position correctly. If not, the pan will rattle against the compressor, causing a ping or rattle.Simply reposition the tray if this is the case. The third possible issue will be the condenser fan. The condenser fan is located behind the refrigerator. It may be necessary to remove an access panel to reach it. This fan has a shroud, and if the fan blade becomes warped, it will rub against the shroud, causing noise. This fan blade is whole,and it can be removed and replaced if this is the case. Ok, the fourth problem spot will be the evaporator fan.
The evaporator fan is located at the back of the freezer. It may be necessary to remove obstructions such as the contents of the freezer, freezer shelves, ice maker and the rear inside panel of the freezer. The rear panel may be held in place by retainer clips or screws. Remove the screws or depress the retainer clips with a small screwdriver. Check the fan for warped blades. if the blades are warped or mis-aligned, replace it. This fan also is protected by a shroud as well, and it will make noise if the fan blade is damaged.
Last, i would move on to the compressor mounts. This is the most common spot for noise overtime. The compressor sits on rubber mountings. Those rubber mountings are designed to absorb vibration from the compressor. As the mountings age, they can become hard or disintegrate. When this happens, the compressor vibration is transmitted to the refrigerator structure and it can cause noise.
The compressor is located in the rear. It may be necessary to remove an access panel to get to the compressor.
Locate the compressor and remove the screw or retaining clip of just one of the compressor mounts.Using a pry bar, lift up the compressor enough to slip out the rubber mount. Inspect the mount for deterioration. The rubber should be firm but not rigid. If the mount is crumbling or hard, it should be replaced.
This concludes the inspection procedure. Follow carefully, and replace any failed or damaged device.....
Posted on Dec 20, 2009
2007 f350 cluch fan quit working
To remove clutch fan: 1. Remove the fan shroud. Remove the top screws & the two side screws with a socket & ratchet. 2. Remove the top radiator hose by using a screwdriver to loosen the clamps. 3. Hook the ends of the water pump pulley lock on the bolts on the outside of the water pump pulley. 4. Remove the large nut on the fan with the 1-1/16 wrench by turning counter clockwise. 5. Replace the fan by holding the nut perfectly level with the water pump post & start the nut by hand. --------------------------------------------------------------------------------------
FGtech V53
Mar 20, 2013 | Ford F-350 Cars & Trucks
Fix a fan on a fan oven
Remove plate at rear of oven remove fan blade 3 screws hold fan in place remove bottom screw incompletely slacken top screws. Remove all screws holding rear panel you have bend top right hand corner of rear panel don't worry if pops back when refitted,best to wear gloves, remove fan replace refit in reverse.
Sep 26, 2012 | Cannon 10476G Dual Fuel (Electric and Gas)...
How to remove fan from gateway dx4200
for replacing the fan you must open computer case unplug all power cords, remove 4 screws near the rear fan and pull out the power supply from the top interior. then you have at leat more 4 screws to remove the power supply cover out. then you will see the other 4 screws to remove the fan. if you just simply want to clean the fan open the computer case go to outside, take an air compressor and blow air into the fan and at the rear od the power supply on the air intake and you are done.
Aug 26, 2012 | Gateway DX4200-09 PC Desktop
How do I remove the cooling fan shroud from the top of the radiator ? I'm trying to change the cooling fan motor, and I've removed the bolt holding the fan shroud to the radiator, but I can't get the...
I would suggest replacing the cooling fan relay in the fuse compartment under the hood first. Cooling fan motors very, very rarely go bad. You will probably end up having to remove the radiator to remove the shroud. You will save yourself a lot of time and money if you replace the relay first.
Jul 07, 2010 | 1996 Chevrolet Cavalier
Range rover p38 radiator removal info
First, remove the grille, then the top panel. Remove the viscous coupling and fan. Remove the top radiator mounts, Remove the coolant hoses and oil pipes, remove 4 bolts holding the A/C and intercooler/or PAS radiators (depending if yours is diesel or petrol.) then lift up and out the radiator. Fitting is reversal of removal.
Hope this helps
Nov 20, 2009 | 2000 Land Rover Range Rover
How do i take out a cooling fan out of a intrepid
YOU MUST REMOVE UPPER RAD SUPPORT TO REMOVE COOLING FANS..REMOVE ALL 10MM,13MM HEADED BOLTS..REMOVE 4 HEADLAMP SCREWS..7MM HEAD..THERE ARE 2 PLASTIC RIVETS THAT MUST BE CUT OFF AS WELL..HOOD LATCH CAN STAY WITH SUPPORT,LAY BACK ON TOP OF ENGINE OR REMOVE IT..MARK LOCATION ON SUPPORT..REMOVE 4 BOLTS FROM FAN ASSEMBLY,UNPLUG IT..IT ALSO COMES OUT EASIER WITH UPPER RAD HOSE DISCONNECTED..1 CLIP ON TOP OF FAN HOUSING AS WELL
Aug 31, 2009 | 2001 Dodge Intrepid
How to remove 2003 engine cooling fan assembly?
The fan assembly is attached using either small bolts or clips. in some cases you will have to remove the upper radiator hose to allow the fan to come out the top. just simply remove the top bolts and the hose and the fan should slide right out.
Jul 05, 2009 | 2003 Chevrolet Monte Carlo
Replacement of fan oven element on Nef U1721
Hi Steve...yes, these are a pain! Remove the centre fan nut (which is anti-threaded) then lever off the small locating washer underneath. If you are lucky, you will be able to now pull the fan blade off of the motor shaft. However, very often they won't budge!. If you try to knock it off, it is so easy to damage the fan motor (about £80!!). It is possible to leave the top bracket screwed to the oven and unclamp the element from it. I have come across three different typed of clamps so far. One is very easy to do. You can then remove the clamp from the new element and once the element is in place, use the old clamp. It's a fiddle but quite do-able. I have also come across these where the top clamp has been previously removed altogether by engineers on previous repairs! Hope this all helps a little....
Jun 24, 2009 | Neff U1721 Double circotherm Electric Oven
How do i remove the radiator fans
First, you must disconnect the electrical connector, which is located at the top of the fan unit, on the driver side of the vehicle. Then there are 4 fasteners, 2 on driver side and 2 on passenger side of the fan unit, all on the engine side of the unit. The top fasteners are about 1/3 of the way DOWN, and the bottom fasteners are about 1/3 of the way UP. Take these out, then remove the clips on the very top center and very bottom center of the engine side of the fan unit. Be careful not to bend the condenser inlet tube while removing the fan.
Jun 09, 2009 | 2000 Dodge Intrepid
Ceaning inside of fan
With a little more detail on how to clean the 84001. There are 2 screws at the top of the unit on the back side and 1 on the bottom with a small removable cover. Remove those screws and the cover can be removed.
There will be some resistance towards the middle because of 2 clips on both sides. Be carefull not to pull too hard on the ends ; possibility of breaking the cover. Try pressing on center of the cover on one side of the edge.
There are 2 screws holding a bracket that holds the top of the fan. Remove those screws. Then on the bottom there is a shaft that attaches to the motor. You will find a set screw that you need to loosen. When you loosen and remove squirrel cage you will notice a flat spot on shaft. That is where the set screw is to be put when assembling the fan back together.
After cleaning just follow the steps back to assemble your 84001 and enjoy a clean brisk breeze. I hope this helps explain in more detail on how to clean it.
Oct 13, 2008 | Tower Aloha Breeze Fan
Refrigerators Logo
269 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
