Question about KitchenAid KUDC03FVSS 23 in Builtin Dishwasher
Wiring diagram We were having problems with our dishwasher and found there are 2 brown wires disconnected underneath and I cannot find a wiring diagram to figure out where they belong. Any suggestions?
4 Suggested Answers
gwshaw71
  • 83 Answers
SOURCE: wiring diagram
try the whirlpool or kitchen-aid web sites I looked up your model # at 1st source parts and that model is not there
Posted on Dec 07, 2007
kachbibi1
  • 979 Answers
SOURCE: Wiring in oven
If you are saying you are re installing this oven, then what did the 2 other wires go to before?
Posted on Feb 15, 2009
aasc
  • 1606 Answers
SOURCE: KitchenAid Wiring diagram
http://www.servicematters.com may have what you need .
Posted on Aug 09, 2009
What color are the brake light switch wires on a 1985dodge pickup
Here's a wiring diagram for your truck (about 2/3 the way down).
Repair Guides Wiring Diagrams Wiring Diagrams AutoZone com
Judging by the diagram, it looks like it's the brown wire (red is turn signal).
Dec 04, 2016 | Dodge Cars & Trucks
MY BOSCH DISHWASHER DOES NOT TURN ON. IT HAS POWER GOING TO IT. I WOULD LIKE TO SEE A WIRING DIAGRAM.?
If you are certain there is 120 volt power connected at the terminals (loose connections do happen), then check the door switch and control. If those parts are working (and it has power) then at least an indicator light would glow. The most likely problem is a loose connection at the power connections where the house wiring connects to the dishwasher. Many instances of this failure have been found. You can also try disconnecting the existing power and connecting to another power source (a heavy extension cord) to see if that makes a difference.
Sep 11, 2014 | Bosch SHX46L15UC Dishwasher
Wiring for dispenser
Usually there are service papers hidden under bottom of machine. They show a schematic for wiring.
May 03, 2014 | LG LDS5040ST Stainless Steel...
I want to install a new switch in my Superior scms 10 L miter saw but I need a wiring diagram to put it all back together again.(2 blue,2brown & one grey wire.When I took it apart I did not mark the...
Denis use a meter on the switch. Measure resistance / continuity. Find the 4 contacts that are made when the switch is actuated. There are 2 terminals for blue and 2 terminals for brown. The terminals are paired so that each of the 2 terminals is made when the trigger is actuated. Blue to blue... brown to brown and grey will be the last terminal. It will not matter which side of the switch you connect the wires to as long as you pair up the colors. My concern at this point is the gery wire. If it is piggy backed to another terminal and you disconnected it this can be a problem. I believe the grey wire is for actuation of the brake. If this does not help you feel free to seek other experts. I do not think your going to be able to locate a wiring diagram without the aid of the products service center.
This is my experience:
http://blog.fixya.com/index.php/2010/05/award-winning-service
I only answered to try and help you due to the fact I know getting the wiring diagram will be a difficult task.
Thanks for choosing FixYa,
Kelly
Jun 30, 2011 | Garden
Need a wiring diagram for a 1969 Ford F250.
there should be a slot for each wire on back of ignition play with them till you get it right cant hurt anything
Jan 14, 2010 | Ford F-250 Cars & Trucks
Needing wiring diagram for 1991 dodge dynasty le
here is what I found:
http://www.the12volt.com/installbay/stereodetail/715.html
Mar 26, 2009 | 1991 Dodge Dynasty
Need stereo wiring diagram
1998 Dodge Ram 1500 Truck Car Stereo Radio Wiring Diagram
Car Radio Constant 12v+ Wire: Red
Car Radio Switched 12v+ Wire: Red/White
Car Radio Ground Wire: Chassis
Car Radio Illumination Wire: N/A
Car Stereo Dimmer Wire: Orange/White
Car Stereo Antenna Trigger: Yellow
Car Stereo Amp Trigger Wire: N/A
Car Stereo Amplifier Location: Behind the glove box.
Front Speakers Size: N/A
Front Speakers Location: N/A
Left Front Speaker Positive Wire (+): Dark Green
Left Front Speaker Negative Wire (-): Brown/Red
Right Front Speaker Positive Wire (+): Violet
Right Front Speaker Negative Wire (-): Dark Blue/Red
Rear Speakers Size: N/A
Rear Speakers Location: N/A
Left Rear Speaker Positive Wire (+): Brown/Yellow
Left Rear Speaker Negative Wire (-): Brown/Light Blue
Right Rear Speaker Positive Wire (+): Dark Blue/White
Right Rear Speaker Negative Wire (-): Dark Blue/Orange
Dec 30, 2008 | 1998 Dodge Ram 1500 4WD
Need wiring diagram for a hotpoint df22 dishwasher on/off switch, the switch in it has been replaced with the wrong one so i have no reference to connect up the new one. thanks
You're in luck - I've just had one apart to repair the wiring loom.
The door switch is a simple two-pole latching switch with the wiring as follows.
This is the order of connections from the front.
1. Brown - Live (fed from mains)
2. Red - Load (goes to controller)
3. Black - Load Neutral (return from controller)
4. Blue - Neutral (goes back to mains)
By the way - the flat wiring loom gets fatigued at the bend at the bottom of the door and will eventually short out. Easy to fix with heatproof cable stripped out from an immersion lead.
Jul 05, 2008 | Dishwashers
Wiring a cooker top
Thios induction hob (Electrolux) has 4 wires - Y/G, brown. blue and black.
The Y/G is obviously the Earth conductor, and I would assume normality says that
Brown is the live conductor and Blue the neutral conductor.
The quandry is whether or not to disconnect the black wire completely, as this appears to have no function in a domestic wiring circuit.
Regards, Albert.
Oct 27, 2007 | GE 30 in. JP326 Electric Cooktop
KitchenAid KUDC03FVSS 23 in Builtin Dishwasher Logo
32 people viewed this question
Top KitchenAid Dishwashers Experts
Mike
Are you a KitchenAid Dishwasher Expert? Answer questions, earn points and help others
