Question about Mercedes-Benz Vehicle Parts & Accessories
E350 fuel gauge wont work
Put gas and gas gauge didn't show gas that I put. Wondering what the problem cold be?
    New Friend:
    Welcome Back:
    Visited the website for 2 consecutive days.
  • 19 Answers
The problem is the float attached to the gasoline sending unit the brushes have worn down and are not making contact but could be the cluster also you can detach the cluster and check the leads with ohm meter to detect if the gauge is good or bad
Posted on Jan 04, 2014
a 6ya Mechanic can help you resolve that issue over the phone in a minute or two.
click here to Talk to a Mechanic (only for users in the US for now) and get all the help you need.
02 seirra Cruze control not working the switch has been replaced so the wipers n everything works but not the Cruze?i checked the fuse already also.
fuel gauge in tank is a common problem for GMC truck
fuel gauge have nothing to do with the cruise control ,, look if cruise module is hook up to trottle body. and with scanner read data of cruise set.resume and switch on/off function.
hope it helps
Oct 06, 2014 | 2002 GMC Sierra
Fuel pump in 96 Chevy Blazer replaced by mechanic, gas gauge didn't work after, took back, gas gauge only goes halfway now. What is causing this and what is remedy?
incorrectly and half assed installed. putting a fuel pump in a chevy is very difficult and takes patients. most mechanics dont have that so go to another shop and make sure they fix the problem before you pay.
Oct 18, 2012 | Cars & Trucks
All other gauges work on the hyundai but the fuel gauge wont work shows empty all the time how can i fix this problem
Turn the ignition on and off several times before inspecting the gas tank because a blown fuse is the usual cause for fuel gauge malfunctioning. If the gauge remains motionless, check your fuse box and determine the fuse's location using your service manual.
Replace the fuse if the link is broken or damaged. Then, inspect the gauge's wire connections for cleanliness and make sure the wires are connected.
Turn the ignition switch to the "off" position. Attach one end of a jumper cable to the fuel-gauge terminal behind the gauge itself. Attach the other end to the ignition terminal.
Replace the sender unit in the gas tank if the gauge reads full and your car does not have a full tank. Replace the fuel gauge if the needle remains inoperative.
Jun 12, 2011 | 1994 Hyundai Sonata
Speedometer of 2003 dodge neon does not work and gas gauge is jumpy. replaced 2 input and output vss sensors and still won't work. no codes show on scanner
some of these have had problems with the dash assembly causing alot of problems with gauges and lights and speedometers.if there are no codes in the computer and weren`t any before you replaced the vss sensors then you spent money you didn`t need to.
Mar 18, 2011 | 2003 Dodge Neon
FUEL GAUGE SHOWING FULL TANK BUT BUT ONLY HALF TANK OF GAS
either fuel gauge on dash is bad or the sending unit in tank is bad
Feb 13, 2010 | RTO Fuel Pump Carburetor Transmission...
Gas gauge is not reading correctly. Shows a full
the problem is caused by a defective gas gauge sending unit, this part is located inside the gas tank, you must remove the gas tank to replace it.
Dec 02, 2009 | 2002 Cadillac Deville
Inquiry of 85 300zx analog fuel gauge operation
One is Fuel Level, and the other is Fuel Pressure
Sep 14, 2009 | 1985 Nissan 300ZX
Car wont start,put 8 gallons of gas,new fuel filter and gas gauge still shows empty.checked fuses,fine.is thier a fuel reset button.
No, but if you put fuel and the gauge shows empty, then you have a loose connector near the gas tank. If car doesnt start, then it is for sure that the connector of the fuel pump is loose. Reconnect the fuel pump and you are gonna be fine.
Jul 18, 2009 | 1998 Saturn SC
Engine wont run when reved up
sound like you have a bad senser. it would be a good i dear to have it scanded. i would check the fuel presher. you may have got a bad fuel pump
Apr 07, 2009 | 2002 Ford E350
Vehicle Parts & Accessories Logo
187 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Timllfixit
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
