Question about Mercedes-Benz Vehicle Parts & Accessories
Gas gauge not working in Mercedes Benz e350 - Mercedes-Benz Vehicle Parts & Accessories
    Genius:
  • Mercedes-Benz Master
  • 1,966 Answers
-sending unit at fuel pump is effect. Replace it
Good luck
Mai
Posted on Feb 12, 2014
Why my mercedes 2006 e350 will not start with code P2006?
P2006 is a Knock Sensor Code. What Octane Rated Gas are you using? Try Premium Grade Gasoline if you are not already doing so.
Hope this helps
Aug 26, 2014 | Mercedes-Benz E350 Cars & Trucks
E350 fuel gauge wont work
the problem is the float attached to the gasoline sending unit the brushes have worn down and are not making contact but could be the cluster also you can detach the cluster and check the leads with ohm meter to detect if the gauge is good or bad
Jan 03, 2014 | Mercedes-Benz Vehicle Parts & Accessories
How much does it cost to fix mercedes e350 gas gauge is not working
The cost for the new part is relatively cheap, the labor will vary, but to fix it it involves dropping the tank down, unplugging and removing old putting in new, can be time consuming, prob have to replace tank straps, then you gotta get to the back of the gauge cluster and that can be tedious and time consuming too. easier and cheaper to estimate gas usage or just keeping the tank full-
Jan 02, 2013 | Mercedes E-class Pillar Posts Trim Set
My gas gauge on my e500 Mercedes isn't working is
reset? no. check sending unit for faulty ground
Apr 30, 2012 | 2005 Mercedes-Benz E500 Sedan
How to fix gas gauge on 2002 mercedez 240c
To troubleshoot and solve this problem,click the link below :---Gas gauge stuck on empty on 2002 Mercedes Benz 240c?http://repairhelpcenter.blogspot.in/2012/02/gas-gauge-stuck-on-empty-on-2002.html
--------------This will help.Thanks.
Feb 26, 2012 | 2002 Mercedes-Benz C-Class
I have a 2006 Mercedes E350. It has 74,000 miles. The check engine light just came on. What are the common solutions for this?
Spark plugs and wires, Moisture in the gas or dirty gas filter,a dirty air filter or injectors.Run some injector cleaner in a tank of gas....Hope this helps.
Aug 13, 2010 | 2006 Mercedes-Benz E-Class
What does E service mean for my Mercedes Benz E350 2007 mean ?
hi this means that the vehicle has now come to the required service interval you have completed the amount of miles required up to this period in other words it need a service...hope this helps
May 27, 2010 | 2003 Mercedes-Benz E-Class
The speedometer odometer gas gauge and rpm gauge arent working it doesnt appear to be a blown fuse, could it be somehting else with the fuses
try disconnecting your battery and reconnect,gonna screw up your preset radio stations but it worked on my daughters car
Feb 03, 2010 | 1993 Mercedes-Benz Mercedes Benz 400 Class
Fuel gauge lights keep flashing mercedes benz s320 car has gas
psi diff inside tank is wrong.
use a OEM fuel cap to make light go off.
make sure it clicks at least 3 times.
Oct 10, 2009 | 1997 Mercedes-Benz Mercedes Benz S Class...
Vehicle Parts & Accessories Logo
79 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Matthew Spark
Matthew Spark
Timllfixit
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
