Question about Dual Electronics XDM7510 CD Player
Car stereo not working after installing
99 olds cutlass put in euc car stereo , new speakers, it worked then shut off so my mom (her stereo) took it to a audio place and they said at first it was because the olds is only 5 volt and requires 12. well wouldnt that blow a fuse ? they said there must be a short in the stereo. well i find it hard to believe i am going to call tomorrow to see if they changed the fuse by the battery / relay to see it that is the problem. then they offered her 30 off if she buys a new one from them. hmm does that sound right? my brother originally put it in and he said it worked then stopped working, it a dual 7510 or cd770.
I had the same problem with mines it came on the shut off then i looked at the fuse and the radio blown the 10fuse i had in it then i put another 10 in it and the radio didnt come one at all finnaly i looked it up on the internet and it said i needed 11-19 i think so i put a 15fuse in the line and it worked fine
Posted on Jun 21, 2009
How to install a radiator
If you have to take the old one out make sure you write down what bolts you take out and if there are supports that you have to remove and make sure your replacement is the same as the one you took out. Then install your new one the way you took the old one out. That's how I did mine and it worked.
Jul 22, 2014 | 1995 Oldsmobile Cutlass Ciera
I was told I need a new lamp ballast assembly. I was also told by someone to order 6913V00002C Ballast (EUC 100 P/11) but when I opened my TV and took out the "bad" ballast, its is a EUC 100 C/00. Anybody...
so the one first is an LG model ballast but the one in the tv is a phillips one, strange.. can you give me the bord number power side... it is always best to replace old number so the damaged numer one should be the number you use. LG, Philips etc use different part to make the same tv model. e.g one can be made in twain and the other from china. both the same case do the same things but have completely different parts in side. Looking at the parts on line they don't have the same connections or the same voltage so would be a bad idea to try and put the new one in with the wrong number.
Oct 22, 2013 | LG RU-60SZ30 60" Rear Projection...
Tried installing a new stereo system and had it in and going but the speedo wouldnt work so took out the stereo and it would work again then tired replacing fuse in stereo as it had blown and tried once...
your best bet is to buy a chiltons book for your car from an auto parts store. also i might add: reconnect your wires to the factory plugg you cut off and buy a wiring harness from a car stero installer or radio shack for your car it will automaticaly adapt your original harness (which your having trouble with) to a standard wiring setup for an aftermarket stereo. then its all about maching colors :)
Jan 31, 2011 | Car Audio & Video
Replacing Stereo in 99 Plymouth Neon
What for? All you need to do is hook up the power wire, a ground and the speaker connections and you are good to go.
Want some good stuff go to Crutchfield. Have everything and very helpful with installation Crutchfield Car Stereo Speakers Home Theater Pro Audio 4k TV
Sep 04, 2017 | Sony Car Audio & Video
No sound dual xhd6420 92 accord lx
my brother has a 1993 Honda accord and had the same issue, we put it different speakers and it worked fine, don't know what the problem was but it worked
Feb 12, 2010 | Dual Electronics XHD-6420 CD Player
99 camery stereo works but no sound was making crackling sounds in front door speaker when you would open or cloe the door the sound would go off and on now nothing the stereo has no amplafire
Sounds like they took on water in the voice coils and are shot. Pull the speaker out of the door (not to bad) and give the cone a little push if it makes noise it's shot.
Oct 24, 2009 | 2009 Toyota Camry
Wiring cut when my stereo was stolen now nothing works.
Could have crossed wires and blown the fuses. try isolating and electrical taping the wires and then go through your fuses and replace the blown ones.
May 29, 2009 | 1996 Oldsmobile Cutlass Supreme Coupe
Dodge radio starts then shuts off
Hi Davis,
I had the same problem with Dodge Grand Caravan as well. I have a 2001 GCV and these radios go out all the time, plus each speaker has separate amps which some speaker will stop working. You will need a new stereo, however the dealership will charge you over $350 for the same replacement. I chose to go to BestBuy and buy a new Stereo for around $100 which has iPod connections which is a plus.
Next problem!!! Since each speaker has its own amp, in order to get the new stereo to work, I had to install a relay by tapping into the passenger side kicker panel master amp power supply to bypass the chip. Best Buy guy will know what to do. I suggest install the stereo yourself with a kit and go back to install an amp bypass relay switch. Hope that helps.
Stock Stereos **** and Dodge make is difficult to go aftermarket.....Good Luck
Apr 05, 2009 | 2001 Dodge Grand Caravan
JVC Car Stereo Very Noisy
Bought new JVC stereo and installed it. No noise, no cracking. 1st stereo must have been bad.
Jun 08, 2008 | JVC AM FM CD DET FACE CAR STEREO
Dual Electronics XDM7510 CD Player Logo
266 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Jose Velazquez
Jose Velazquez
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
