Question about Vacuums
Dismantle hoover - Vacuums
Hoover carpet cleaner f5915905 the handle release won't lock. what should I do ?
Repairing the Hoover Steam Vac Deluxe - YouTube
? 6:01
https://www.youtube.com/watch?v=QBtWcC4gqjY
Apr 21, 2009 - Uploaded by general0ne
I think Ill make one for the Dual V steam cleaner and provide some tips on maintenance. Good job ... The ...Missing: lock
Dismantling the Hoover Steam Vac Deluxe - YouTube
? 6:16
https://www.youtube.com/watch?v=sul52ULCR90
Jan 12, 2010 - Uploaded by general0ne
Dismantling the Hoover Steam Vac Deluxe. general0ne .... Aftercleaning the screen as shown on the video ...Missing: f5915905 ‎lock
Nov 29, 2015 | Hoover Vacuums
How to replace a on /off rocker switch on a hoover pure power bagged vacuum
Some switches can be prised from the housing with a thin blade and the wires transferred to the new switch which is then pushed back into place.
Often with older equipment the plastic of the switch and the housing can become stubborn and unyielding so it is kinder to access the rear of the switch and either press in the locating springs or break them off to free the switch.
Lots of repair professionals would break the old switch to pieces in-situ and save any dismantling.
Feb 25, 2015 | Hoover Vacuums
The cable is jammed in the sebo hoover winding unit, gentle persuasion wont get it out - how do I get to the cable to unjam it?
Have you tried holding down the release button whilst pulling out the cable?It could be the clutch mechanism has not released or engaged.. Assuming the cable didn't double wrap at some point.if this fails it may require you to dismantle from the base.i have worked on sebo vacs , they are a German company and very well made that can withstand harsh treatment without bits breaking off.but if you do decide to dismantle...disconnect from mains power source....take photos at each stage and be methodical ...keep screws to together for each section and if you come across springs try not to remove them before you know how they locate back into the correct positions when it goes back together.good luck!
Feb 01, 2015 | Hoover Vacuums
How do i open/dismantle a hoover telios vacuum cleaner ?
Hi there! Disassembling the cleaner beyond detaching the nozzle, wand and hose is not recommended. If you need further assistance we recommend taking your cleaner in to a Hoover authorized service center for inspection. Follow the link to locate the nearest service center to you. Service Center Locator
Thanks!
Jun 22, 2014 | Hoover Vacuums
F5915-900 hoover steam vac brush block diassemble
click the link below for the manual it will give you step by step instructions how to dismantle the brushes.
http://hoover.com/file/601/
Aug 06, 2012 | Vacuums
Hi how do you dismantle the head turbine for the Dyson Hoover DC80 as i need to clean it and i have no idea how to dismantle it!
There are two (or is it three) plastic screws on the underside of it. This allows it to be partially split so you can clean the area around the brush roll.
To strip it further needs a Torx T15 bit, but I don't advise doing that unless you know what you are doing and are confident about the re-assembly.
Cleaning around the brush roll area is all most people need to do with these and that is a simple matter.
Jan 18, 2011 | Dyson DC08 Cylinder Bagless Canister...
Will not turn bottom blad for hoovering
DC14s have two drive belts that turn the brush bar - one connects the output of the motor to the clutch, the other connects the clutch to the brush bar.
You can check the latter simply by removing the sole plate and looking. Unfortunately the other belt is hidden under a plastic cover, so you cant see if it is okay or not without some dismantling. This cover is not easy to remove and requires a Torx driver to under the securing screws.
If, after removing the cover, the other belt is okay, then you have a faulty clutch. New clutches are available on eBay2_bing.gif reasonably cheaply, but again good tools and DIY skills are required.
Have a look at www.dysonmedic.com which has some excellent info on dismantling and repairing a DC 07 which is very similiar to your DC 14, but unless you have access to such tools, and feel confident to tackle it, it's probably time tocall Dyson or a Vacuum repairer.
Jun 14, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
No suction, I even replaced the filter and its not picking anything up!
If you can hear the motor then either the fan inside is broken (or unscrewed) or there's a blockage somewhere. Either way you will have to dismantle it completely to find out.
Oct 27, 2009 | Hoover U6630-900 WindTunnel Bagless...
High squell
hi thanks for the question you probably sucked in some foreign object and it got stuck and its caught in the fan blade dismantle and clean thanks the appliance doc
Sep 16, 2008 | Hoover Vacuums
Replace interior hose for cleaning attachment for Hoover Steam Vac Agility
http://geeksquad.fixya.com/ThreadView.aspx?prdid=618767&thid=632107
Replace interior hose for cleaning attachment for...
Posted by castcomm on May 29, 2008
How do you dismantle handle to replace aforementioned hose?
Swing arm on unit goes all the way to the floor. Is this normal? Is there a "stop" broken that caused the hose to stretch, and ultimately break?
I would advise you to ALWAYS to FIRST UNPLUG YOUR VACUUM before beginning any service procedure. Hoover SteamVac Carpet / Upholstery Deep Carpet Cleaner.
There are handle screws that you can get into the handle and then you can back track the replace the interior hose for the cleaning attachment. There should not be a stop that caused the hose to stretch ad break. The hoses after a while do get old crack and break due from normal use or if the bend @ sharp angles, this is common among all vinyl vacuum cleaner hoses. You should really check with your local factory authorized Hoover vac dealer in your area or , please feel free to contact your local vacuum cleaner dealer in your area or in the yellow pages, or contact the factory phone number or website to further assist you with your questions.
http://www.hoover.com Telephone
Contact our Customer Service Department at 1.330.499.9499
Monday through Friday
8 a.m. - 7 p.m. EST
Thanks, Don the Vac Man
Go Ahead. Use Us.
May 29, 2008 | Hoover SteamVac Carpet/Upholstery Deep...
Vacuums Logo
198 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
