Question about Cell Phones
Make font larger - Cell Phones
MAKE MY HP OFFICEJET 5610 PRINTER PRINT LARGER
The only way a printer should print larger is that you should WRITE your text with larger fonts.
You should select font size on your word processing application, call it nopepad, wordpad, winword or any other similar application.
If you tell us the application and the version you are using for word processing, might help you select a larger fornt
May 02, 2015 | HP Office Equipment & Supplies
How to make font size larger
On a WIN7 or 8 PC, right click on desktop, left click Screen Resolution and lower the resolution to make everything larger. If you just want the fonts larger, go into Control Panel, Display & change the font size. Both methods don't always give you the desired visual results, but there is no harm in trying each. Good Luck
Mar 03, 2015 | Intel Computers & Internet
How do I make my font size larger
under the heading you can see the font name and a number next to it is the font size that you can change to make it larger before you type. If you only have to make a word or paragraph larger then you need to highlight it then change the font size.
Dec 11, 2014 | Toshiba Computers & Internet
Make font larger on HP1510 printer
What font are you referring to? Have you prepared a document in a word processing program, or added text to an image file, and are disappointed because you want to see the text printed larger? If so, your best solution is to edit the document or image and change to a larger text size. For example, most text documents will normally default to either a size 10 or 11 text which is readable but small. Changing to size 12 or 14 will make the text look larger onscreen, and the text will also print larger. The font name and font size should be displayed on one of your processing program's toolbars, and is easily changed to a different font name or size. If you are simply copying an already printed document and want the text to appear larger, you should refer to your printer's User Guide. If you don't have the User Guide, you can download a free copy at this link:
HP PSC 1510 All in One Printer User guides
Nov 15, 2014 | HP PSC 1510 All-In-One InkJet Printer
Change to larger font on aol e-mail
AOL Mail is an email service provided to the customers of American Online as well as Web users.
When you print an email using AOL Mail software, you may notice that the font size either appears too small or too large.
AOL Mail gives you the flexibility to adjust the font size and thus, the size of the print.
Note that these instructions apply to AOL 9.0 or higher.
If you have an old edition, follow instructions from the link specified under Resources.
Launch your AOL Mail software from the Start menu or desktop shortcut.
Log in using your AOL screen name and password.
Click "Settings" on the top bar.
Click "Font and Text."
Click the font type drop-down menu to choose either a larger or smaller font type than the current one.
Click the font size drop-down menu to choose either a larger or smaller font size based on your preference.
Click "Save."
Hope this helps
Nov 04, 2012 | HP Computers & Internet
How do you change font size of email printout?
Internet Browser Instructions
  • If you open your email account using a browser, there is a very simple way to increase the font. Font size options are located either under "Tools" ("Options" or "Preferences" then "Content") or "View" (text size) on your browser's main menu. Change the font to a larger size, which may be set by number or by selecting "Larger" or "Largest" font from the list of options. You may have to click "Advanced" or the similar option in the "Fonts" section of some browsers to adjust the font properly.
    Next, click "File" then "Print Preview" on your browser's main menu. This will show you how the email will look when printed. Click "Page Setup" and deselect the "Shrink to Fit Page" option. This will allow you to print the email at the new, larger font size. Be sure to return your browser's font size to normal when you are finished printing the email, or else all of your pages will display with a larger font.
Other Email Software
  • If you use a non-browser email software program to view your emails, insert your email contents into Microsoft Word (or a similar word processing program) to print it in large letters. Select the entire message from your email software then go to Word to paste the contents into a blank document. You can then select the text of the email and increase the size of the font. When you're done, print the file as you would normally. You can also perform this action with an email that you open inside of a browser.
Nov 29, 2010 | Canon Office Equipment & Supplies
How do I get the font of aol web browser to be large?
On Windows 7:
  • Go to Control Panel
  • Click on ease of access
  • You should see a section that says "Make things on the screen larger"
  • Select Change the size of text and fonts.
  • Select Larger 150%
  • Click Apply
  • You may have to restart.
  • ALL fonts on your desktop and in all Windows will be significantly larger.
Apr 09, 2010 | Systemax AOL Optimized PC (100607) PC...
Prints in to small of font. How do I get a larger font
The larger fonts you are getting in your application, like Microsoft Word for example, the printer is not to blame for this. Just increase the font size from your application.
Jul 07, 2009 | Konica Minolta PagePro 1350W Laser Printer
Brother Hl-2040 laser printer
Fonts and sizes are typically controlled by the application you are using. Are you sure you are increasing the font size? I've had some users confused by the zoom feature which is more like a magnifying lens. It just makes thing larger for viewing purposes and does not affect the print size. To change the actual font size of a document already created you would first highlight the text in the document. In Word (other applications are similar) you would then select Format from the main menu bar, then select Font. In the next box that appears you would click on the Font tab, and then in the Size field select a larger font size. After that click on OK and you should see your font size change. Let us know if that was your problem or not.
Aug 02, 2007 | Brother HL-2040 Laser Printer
Cell Phones Logo
43 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
