Question about HP PSC 2355 All-In-One InkJet Printer
Reset printer alignment - HP PSC 2355 All-In-One InkJet Printer
How do I manualy reset the head alignment
God day,
there is no way to reset the head alignment. you just do a head alignment.
Sep 25, 2014 | Canon Pixma MP600 Printer
My C310a printer wont align
on the front panel press setup >> Tools >> Clean Cartridges
again press setup >> Tools >> Align Printer...
if it does not work then do a reset on the printer
and to do that Press BL/TL/BR/TL Buttons, in sequence
(BL: Bottom left, TL: Top left, BR: Bottom Right) >> Touch Support Menu >> Press Right arrow for Reset Menu and Touch OK >> Press Right arrow for Partial Reset and Touch OK >>
Wait for unit to Power Down/Turn Off >> Press Power button to turn the Printer On...
the printer would automatically align itself...
Hope this helps...
Oct 30, 2012 | HEWLETT-PACKARD C310a All-In-One InkJet...
Alignment on canon mp210 is off
You can try to do a power reset on the printer and if does the same, try to do a hardware reset. I found some steps on this site with specific error messages, How to reset Canon mp210. It has steps procedure you can follow.. :)
Aug 15, 2012 | Canon PIXMA MP210 Photo All-In-One Printer
Press enter to alline cartridges
If you are getting Alignment failed or Align cartridge Error, It could be because of these possible reasons listed below.
1. Faulty Cartridge ( if you are replacing one now )2. Refilled Cartridge ( not filled properly )3. Cartridge Low on ink ( does not give printer enough ink to align the printer )4. Could also be Hardware Issue ( Most of the time the HP Printer has life time of 4-5 years )
First step,
Remove all the cartridges out and clean the electrical contacts ( golden Contacts ) with a lint free cloth and Re-install them again
It should go through the alignment process and complete it.
If it does not,
Try to access the Setup menu and under tools you will find Align Printer, Try this.
If the Cartridge ink is full or has adequate ink ( atleast 30% in each cartridge ), and the cartridge is not refilled, then the last option is to do a hard reset on the printer.
But Doing the reset your printer will loose network connection, all the printer settings and fax logs,
To do the Reset,
Disconnect the power cord from back of the printer ( while printer is powered on )While holding the # and 6 button at the same time, Connect the power cord back.Go through the setup process to re-setup the printer settings,If it still does not align the printer, You may give a try to install using new cartridge ( but i doubt, it could be the end of the printer.)
Call HP and check if they have any good offer or they can help you with aligning the printer once.
Regards,Suhail
Nov 13, 2011 | HP OfficeJet 6110 All-In-One InkJet...
I was given an HP Officejet J3640. I installed the HP21/22 ink cartridges, printed the alignment page, then loaded the alignment sheet in the feeder. After I loaded the alignment sheet, it responds...
Hi
Check if the alignment page has been printed correctly i mean the bars printed with a little yellow color around it right?
Okay what you can do is do a reset first. Follow the below things
1. When the printer is on remove the power directly from the back of the printer.
2. hold # and 9 key and connect the power
3. Printer will show you on the screen it is resetting the NVRAM then release the buttons
The printer will print alignment page again this time try to scan and it should work.
DO RATE MY SOLUTION
Jun 30, 2011 | Office Equipment & Supplies
HP officejet pro l7680 all-in-one: when attempt to print, printer says "aligning printer" for a while, will print one page, then print an alignment page, and then states "alignment...
You could try to turn off printer.
Unplug printer from electrical outlet.
Wait at least 15 minutes, this will let the printer to clear memory.
Plug back in printer and turn on. Do a cleaning cycle.
The cleaning cycle will insured a good alignment page.
Align printer.
Jan 11, 2011 | Office Equipment & Supplies
HOW TO STOP THIS PRINTER FROM ALIGNING, EVERYTIME I PRINT SOMETHING IT BEGINS THE PROCESS OF ALIGNING PRINTER, PLEASE HELP...
Reset the printer and align it successfully, remove the cartridges, clean the copper contacts with a clean lint free cloth and distilled water and then perform the reset, insert the cartridges when asked by the printer.
reset is below/
1. Unplug the power cable from printer when the printer is powered on and wait for 20 seconds.
2. Then, press and hold # and 6 while plugging in the power cord.
Continue holding until it displays Semi Full Reset message in the front panel of the All-in-One.
Apr 10, 2010 | HP Officejet Pro L7780 All-In-One InkJet...
New cartridges - printer not printing
Align your cartridges to solve print quality problems such as: • Characters are not properly formed or are not aligned at the left margin. • Vertical, straight lines are wavy. 1 Load paper in the paper support. 2 On the control panel, press Copy. 3 Press Options until Maintenance appears. 4 Press the right arrow until Align Cartridges appears, and then press Select. An alignment page prints. Once this page prints, your automatic alignment is complete.
Please rate this solution.thanks and good luck.
Jan 22, 2009 | Lexmark X6170 All-In-One InkJet Printer
ALIGNMENT PROBLEM
try doing incremental resets.
start with a partial reset:
press the # and 3 buttons simultaneously, and while holding them down, unplug the power cord from the back of the printer. wait 3 seconds, while still holding down the buttons. Then plug the cord back in. Wait until the LED will prompt "partial reset" and release the buttons.
try to align again.
if the problem persists, do a semi-full reset:
Same instructions as above, but this time use the # and the 6 buttons. Wait until the LED will prompt "semi-full reset" and release the buttons.
try to align again.
Feb 17, 2008 | HP Photosmart 3310 Printer
HP PSC 2355 All-In-One InkJet Printer Logo
24 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
