Question about Eyemax Dvb-9120 Dvr Surveillance Card 16ch Video 120 Fps Support Iphone, Android
I am getting a black screen off a camera on a dvb 9120 capture card why?
Using HP Pavillion desktop with windows 7 32 bit
  • 1 more comment
  • David J Hamilton
    David J Hamilton Jan 06, 2014
    I was able to get the program fully downloaded
  • David J Hamilton
    When I run the program it will run for about five minutes. Then I get a box on the screen that says the program has stopped and when I restart it, it gives me a box that says checking file system
  • David J Hamilton
    And I am still getting a black screen
Why is there a black screen on hp pavillion windows 7 "boot mnr missing"?
Windows 7 - black screen with blinking cursor
  1. Remove any CDs, DVDs, or memory cards from the computer.
  2. Disconnect all devices from the computer except the original mouse, monitor, and keyboard. Leave the power cord connected.
    1. Restart the computer.
    If it starts normally, start plugging devices in one at a time until you find one that may be causing the black screen
    1. Press the F10 key repeatedly during the first startup screen until the Entering setup message displays.
    2. Press the F5 key to restore the defaults. Use the arrow keys to select YES , and press Enter .
    3. Press the F10 key to save the changes and exit. Use the arrow keys to select YES , and press Enter .
      The computer restarts.
    4. If a Windows Error Recovery screen displays when the system restarts, select Start Windows Normally , and press Enter .
  • If this doesn't resolve it, follow the procedure below.
  • Aug 17, 2014 | HP 5188-7103 Compaq Motherboard Gl8e...
    What is the best resolution on LED tv?
    I've never been a fan of the Snapshot feature because rather than capturing at the native resolution of the video it always uses desktop sizes 640 x 480 ,800 x 600 etc) and doesn't make any effort to scale it properly. It would be nice to see 720 x 576 and 704 x 576 sizes in there. You can get much better quality by recording an MPEG file and using the snapshot feature in DVD playback software such as Win-DVD or Power-DVD.
    Jun 02, 2014 | HP Hauppauge Wintv Nova Dvb-t 90002 Pci Tv...
    Just installed Vantec 2+1 Firewire 800/400 PCIe card on my windows 7 - 64 bit desktop. Card seemed to install OK using Microsoft driver. Device manager says it is running OK. Whenever I try to connect a...
    sir....
    Sorry for the trouble...
    I suggest that you try using a different video capture software to capture videos using the firewire card to resolve the issue.
    thank you.............
    Nov 19, 2011 | Vantec Computers & Internet
    My hp Pavillion DV6000 laptop starts up fine and after a few minutes the screen turns black. I can still see the desktop image in the background but barely. If I reboot the screen looks normal again but...
    Well are 2 reasons for this behaviour of your notebook...first it can be an issue with the graphics card installed on the motheboard or its an issue with the Monitor cable which is connected between the motherboard and the LCD.
    Following are the steps that you can try to resolve the problem:
    At first we need to check whether its a hardware problem or not.
    1.Restart the computer and tap on the F10 key for a while which would take us to the BIOS SET UP UTILITY...
    2.Now we need to wait for sometime in this screen so that we can check the status of the screen whether the screen goes dim or it remains normal..
    3.If the screen remains normal for around 10 minutes then its not a problem with the cable,
    4.Now we need to get back to the windows screen and try installing the graphics driver for the notebook.
    Let me provide you a couple of drivers for the notebook.
    I am providing you the drivers assuming Windows Vista installed on the system
    if you have an ATI card installed, the install the below mentioned driver:
    http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&swItem=ob-60201-1&jumpid=reg_R1002_USEN
    if you have an NVIDIA card install the below mentioned driver:
    http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&swItem=vc-77961-1&jumpid=reg_R1002_USEN
    or you can install the drivers directly from the manufacturers website..
    Hope this works.
    Regards
    KEN
    May 10, 2010 | HP Pavilion dv4000 Notebook
    Screen blacks out after startup
    well the problem could be caused by either memory card or display/ graphic card. Since most notebooks have shared memory for the graphic card, I would suggest to clean/ replace the memory card. If it has two cards, take off one of them, if it remains the same, place with the other one.
    Apr 09, 2010 | HP Pavilion 714a (A714N) PC Desktop
    Cant take pictures on webcam
    1. Double-click the HP Photosmart Essential icon on the Windows desktop.
    2. Select View>Get images>From Scanner. The Select Device dialog box appears.
    3. Select HP Camera and then click OK.
    4. A warning appears to indicate that the device isn’t a scanner. Click Yes.
    5. Click Capture to take a picture (snapshot).
    6. Click Transfer to save the picture in the My Documents/My Scans/<Current Month> folder.
    Now you are ready to edit and share your photos with HP Photosmart Essential.
    Apr 14, 2009 | HP Pavillion a818n Desktop PC (Refurb)...
    What does a TV card look like, to support Nero Vision films to put on hard disk???
    To run vision you need:Nero Vision
    • FireWire® (IEEE 1394) Controller for DV capturing
    • USB recording device (web cam)
    • Analog or digital TV card (analog, DVB-T, DVB-S, DVB-C, and ATSC) according to the BDA driver standard
    • DirectShow compatible video capture card (optional)
    • Graphics card with 3D accelerator and at least 64 MB video memory for Smart3D templates
    • Blu-ray/HD DVD Video-Plug-in for playing Blu-ray and/or HD DVD medi
    This is a standard TV card: http://www.mepisguides.com/Mepis-7/hardware-reports/leadtek-winfast/tv-card-5.png
    Sep 08, 2008 | Computers & Internet
    DVBT-100 Digital TV Tuner PCI Card
    Normally, the driver you have with the hardware is the driver you must you, as it may cause all sorts of conflics trying to use others. Intervideo would not have written a driver for your dvbt card, only their own.
    Oct 30, 2006 | KWorld DVB-S 100 (DVBS100) Video Capture
    Eyemax Dvb-9120 Dvr Surveillance Card 16ch Video 120 Fps Support Iphone, Android Logo
    41 people viewed this question
    Top Eyemax Computers & Internet Experts
    David Payne
    David Payne
    Are you an Eyemax Computer and Internet Expert? Answer questions, earn points and help others
