Sandisk ultra 8gb
Someone has deleted the scan disk folder from the memory stik now it will not work on laptop
SOURCE: memory stik problem in k530i
I hope if you did master reset this will resolve your problem.
Posted on Dec 03, 2008
  • 23 Answers
SOURCE: PC does not recognize SanDisk Ultra II 8GB memory card.
install the usb drivers 3.0 it wi;l solve u r problem...........
Posted on Oct 06, 2009
Obertelli
  • 3006 Answers
SOURCE: SanDisk ULTRA II 8GB won't read when installed in
No, it's a hardware issue. Your 8GB card is an SDHC card (the HC stands for High Capacity), but the card reader in your machine is clearly only compatible with the older type SD cards. SDHC devices will accept SD cards, but devices designed solely for SD cards cannot read or format SDHC cards.
There is no firmware update for this, your only fix is to buy an external reader compatible with SDHC cards for connection via a USB socket. Most new readers are fully SDHC compliant, but check the specs for shelling out your hard-earned...
Posted on May 24, 2010
  • 102366 Answers
SOURCE: how do i unlock memory
SD and SDHC cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
Posted on Oct 25, 2010
bronk50
  • 27725 Answers
SOURCE: My computer (HP a1040n) won't
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you could see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
hope this helps
Posted on May 30, 2011
SD card format ng no card
  • 1 Insert your SanDisk 8GB memory card into a card reader connected to your computer.
  • 2 Double-click "Macintosh HD" on your desktop.
  • 3 Click on the "Applications" folder, then the "Utilities" folder.
    4 Double-click "Disk Utility". Look on the left side to locate the drive that says "SanDisk.
    5 Select the capacity of the drive on the left side of the window. The capacity will state "8GB" or "8,388,608 kilobytes." Click on the "Erase" tab to format the memory card. When you see "SanDisk" listed as the device's name, the capacity will be located above. You need to select the capacity and not the device.
    6 Select the appropriate "Volume Format." Under the "Volume Format" button, select the format you wish to use. Select "Mac OS Extended" if the SanDisk 8GB will only be used on Macs, or "MS-DOS (FAT)" if you will share the card between a Mac and PC. Select "Erase" to complete the format of your SanDisk 8GB memory card.
    Mar 07, 2012 | Panasonic AG-HVX200A Mini DV Camcorder
    How can i recover data from a flash drive
    Recuva (pronounced"recover") is a freeware Windows utility to restore files that havebeen accidentally deleted from your computer. This includes files emptied fromthe Recycle bin as well as images and other files that have been deleted by usererror from digital camera memory cards or MP3 players. It will even bring backfiles that have been deleted from your iPod, or by bugs, crashes and viruses!
    • Simple to use interface - just click 'Scan' and choose the files you want to recover
    • Easy to use filter for results based on file name/type
    • Simple Windows like interface with List and Tree view
    • Can be run from a USB thumb drive
    • Restores all types of files, office documents, images, video, music, email, anything.
    • Supports FAT12, FAT16, FAT32, exFAT, NTFS, NTFS5 , NTFS + EFS file systems
    • Restores files from removable media (SmartMedia, Secure Digital, MemoryStick, Digital cameras, Floppy disks, Jazz Disks, Sony Memory Sticks, Compact Flash cards, Smart Media Cards, Secure Digital Cards, etc.)
    • Restores files from external ZIP drives, Firewire and USB Hard drives
    • It's fast, tiny and takes seconds to run!
    http://download.cnet.com/Recuva/3000-2242_4-10753287.html
    Feb 19, 2012 | SanDisk 8GB Ultra 15MBs SDHC SD Class 4...
    I have the 8GB SDHC Card and when I insert it into my laptop it is not recognised. How do I change this?
    may be the port does not support it , try inserting it to a card reader and plug the usb card reader to your laptop .
    Jul 02, 2010 | SanDisk Ultra II 8GB Secure Digital High...
    Sandisk Ultra 2 compact flash 8gb won't work in my camera (Olympus E-520), it says 'card full' & I am unable to format the card, it says 'card error'.
    insert the card to a card reader then format it in the following way:-
    right click my computer then menage then click disk menagement then right click on your card then click format. good luck.
    Jan 09, 2010 | SanDisk Ultra II 8GB Secure Digital High...
    Sep 27, 2009 | SanDisk 1GB microSD Memory Card
    Unusable memory
    When you reformat a memory stick it creates a trash folder which stores all the data incase you need to use it again. Put your memory stick in your psp then connect your psp via usb to a computer, in the computer view of the momory stick make sure you have the 'view hidden folders' option checked, then delete all folders & files on the stick. Remove the psp from the computer & reformat it again you should find 8gb available again
    Jun 01, 2009 | SanDisk Memory Stick PRO Duo for...
    8gb cruzer files not transferring
    Download malaware bytes and trojanremover from
    www.download.com
    and this will help you to fix this issue ,actually the malware gets associated with all files and folders and unknown process starts running in background due to which system rejects the request to delete or move your files
    Thanks And Regards
    Fixya at your service ,Sir!!
    May 12, 2009 | SanDisk Cruzer Micro 8GB USB 2.0 Flash...
    My new 8gb sandisk says it is not formatted and I can't format it
    well i heard on another website - that because the memory card can hold alot of memory, the computer doesnt accept it, so you need to use a usb memory card reader, ebay sells it for like £1
    Mar 31, 2009 | SanDisk 8GB microSDHC Memory Card with...
    San disk ultra II won't show up on computer
    You'll have to go to Sandisk.com to verify this for your specific model, but... the problem is that some firmware versions won't recognize over a 2GB card. There may be a firmware update available. Find your product on the site using search, and then look for software updates. Don't hesitate to call techsupport (866-726-3475).... usually NOT a long wait, they speak clearly and they're polite.
    Feb 04, 2009 | SanDisk Ultra II 8GB Secure Digital High...
    Computers & Internet Logo
    56 people viewed this question
    David Payne
    David Payne
