Wharfedale 991 amplifier gone single channel
I have just plugged an MP3 player into my Wharfedale S991 amplifier, which is brand new. Now I have lost a channel. That is, it has gone mono. Only one of the outputs to the speaker now works. Where could I get a circuit diagram and fault finding instructions?
SOURCE: Reads PROTECT on the display of my Onkyo TX-SV525 ???
HOWDY,         NOW YOU COULD TRY THIS ONE: POWER THE RECEIVER UP , THEN PUSH&HOLD !THE VIDEO 1 BUTTON, THEN TURN THE PIECE IN THE OFF (STANDBY MODE ) ,IT WILL SAY "CLEAR SO IT SHOULD BE BACK TO IT,S ORIGINAL FACTORY SPECIFICATION,S.
SUCCES !                              AMSTERDAMCOWBOY-HOLLAND-NOW FLORIDA! 4-EVER
Posted on Oct 23, 2007
SOURCE: Subwoofer Connection: Speaker wire to Mono RCA
The easiest solution to use your subwoofer is to buy an amp for it. Any old stereo receiver from a garage sale will probably do just fine.
  1. Connect the mono RCA subwoofer output from your Sony with a 1xRCA-to-2xRCA splitter to both the left and right input of the cheap reciever's tape or aux input
  2. connect both speaker outputs of the cheap reciever to the speaker input on your subwoofer. make sure both black (-) outputs on the reciever connect to the black input on the sub, and the red outputs (+) on the reciever are both connected to the red input on the subwoofer.
  3. make sure the cheap receiver's volume is all the way down. turn your Sony up to about the loudest you'll listen to it. turn up the subwoofer amp until it's loud enough to sound good.
  4. leave the subwoofer amp alone, the Sony volume will all you ever need to touch from now on.
You can even now turn off your subwoofer / adjust the volume easily now!
Posted on Nov 11, 2007
SOURCE: cd/mp3/usb player
Hi, try holding down the play button for a few seconds until "USB" shows up on the little display - my sons ipod nano works when I plug in the ipods usb lead.
Posted on Jun 09, 2008
  • 119 Answers
SOURCE: speaker connection from Denon AVR 2105 to Wharfedale suround
The spkrs sound like they are bi-amp spkrs, meaning you have multiple terminals on the backs of each spkr, the jumpers on the spkrs should be connected as such. Now you just connect the spkrs according to the Denon spkr conection diagram. Do not use the surround back unless you have 6 or 7 pair of spkrs
Posted on Feb 25, 2009
dunnbiker
  • 8546 Answers
SOURCE: my pioneer vsx-816 sshows overload then shuts
Generally speaking, an amp protects itself from heat, shorts and overloads.
Overloads can be from excessive periods of high output and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'naked'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced hands-on tech.
Posted on Jan 25, 2011
Where can I get a Amplifier Warfedale S-991 or spare transformer for this unit
Hi Dave. One just finished on the bay. http://www.ebay.co.uk/itm/Wharfedale-S-991-Amplifier-mini-H-Fi-integrated-amp-/230791689518 They may still have it ?
Jan 05, 2015 | Audio Players & Recorders
Lost usb cable for Wharfedale MP3 player where can I buy one
there are sites that you can buy online which is compatible in your mp3 player.
Sep 17, 2012 | RCA OPAL M4001 MP3 Player
Wharfedale tv no digital access
I'm not familar with that particular TV but check in the menu. Some TV's have to be set to digital and default to analog.
Dec 28, 2009 | Wharfedale DVD-M3 DVD Player
I have a Wharfedale Slimline MP3 player and I'm
found out that jack size i need is 25mm - and then after searching internet have bought an adaptor that has a 25mm male jack with a 35mm female adaptor on other end - so I can use headphones I've bought .
Nov 13, 2009 | Audio Players & Recorders
Mp3 player wont turn on when plugged in to the computer.
Hello.
If its brand new, it might be possible you have received a faulty unit.
Please sent it back to the company to get it replace for a new one.
Jan 12, 2009 | Wharfedale DVD-M3 DVD Player
In car usb conection wont work
It appears this stereo is compatible with a limited number of mp3 players. I had the same problem with my Ford Edge Sync option. See if you can get a list of compatible players from the manufacturer/ dealer. If not, try different mp3 players until you find one that works reliably and purchase one.
Dec 30, 2008 | Wharfedale DVD-M3 DVD Player
Wharfedale flash mp3 player slmo1 4gb has frozen
if ur mp3 has frozen it usually shows that the internal disk is corrupt the only thing you can do is to format it. plug ur mp3 player into ur computer right click on the disk when it comes up and select format. or u can go to command prompt and type in format e: for example this will fix it.
Jul 05, 2008 | Wharfedale DVD-M3 DVD Player
Wharfedale drivers
i have a
Wharfedale FM6709i really need a driver for this product can you tell me where to go or the download site needed.
Mar 07, 2008 | Audio Players & Recorders
Wharfedale DVDRHD400
where can i get a remote for the wharfdale dvdr hd400
Jan 15, 2008 | Wharfedale DVD-M3 DVD Player
12 people viewed this question
 Grubhead
Grubhead
