Question about Sega Video Game Consoles & Games
Audio hum and white screen
Dual player with 1 master and slave. Slave has audio hum when turned on the after about 5 minutes or so goes to white screen
localwonder
  • 6784 Answers
SOURCE: jumper settings wd1600
yes, you are correct.
Posted on Feb 20, 2009
  • 9 Answers
SOURCE: need master slave configuration
First set the jumper pin for master or slave configuration as provided in the cover of the hard disk.
Posted on Mar 20, 2009
  • 30 Answers
SOURCE: How can I check that MXL-2300 modem is master or slave and how can changed?
If you have the IP of the device - telnet to the IP and you can change the status in there within the Config page
log on as craft
Posted on Jul 24, 2009
chirash333
  • 265 Answers
SOURCE: Main/slave selection
2 ways to select master slave congiration
1. BIOS method.
Start ur pc. nter the setup by pressing delete key or any other key as per ur bios..
now c if there is a option named boot configration. then u will be having a option of selecting master and slave boot device also sumtimes known as primary(master) and secondry(slave)
2. Hardware method
Behind ur hard disk there r six pins closely located like this :::
now there is a black colored small plug, when u insert it in first two ::: THen tht drive is master..
If in second 2 ::: then slave
Posted on Aug 11, 2009
scc2657
  • 90 Answers
SOURCE: New larger hard drive can only be detected as Primary Slave
Floydage, some ribbons are different in the orentation of pin#1. try a differnent cable...but you said that you tried that right.? have you tried to make sure you have the latist BIOS. It could be this paticuler drive have a different bios it self...and yes drive's do have chip's and software in them. If nothing ells just load the OS to that drive anyway and than change the drive letters in windows.
Posted on Feb 17, 2010
Pins location master slave
During the boot process you will see on the screen to press a certain key to enter setup
Press and hold that key during the boot up process to enter BIOS the scroll down to advanced bios features press enter change your first boot device to IDE-1 means Pri slave escape then press f10 to save to cmos to restart
you will have to have master with slave set up
you can find the jumper location next to the power on a hard drive and the settings for plastic jumper location is usually printed on the top of a hard drive
IDE-0 means Pri master
IDE-2 means Sec master
IDE-3 means Sec slave
single or master :::::
master with slave ::'::
slave :::':
black line between dots is plastic jumper
note the plastic jumper is ' located at the rear of the hard drive between the EIDE and electrical lead/s
Hope this helps
Nov 24, 2012 | Gateway Motherboard Gt5408 Gt5438 Gm5407e...
Jumper settings for master drive
if its a SATA hard driveyou dont need to set master slave the biggest capacity hard drive will set as master
slave :::':
Oct 03, 2011 | Dell Computers & Internet
I have 2 sony 400 megastorage cd players and a 200 disc megastore player, how do I "daisy-chain" them together so I can have a 1000 disc library at my control? thanks!
Run a mini mono plug out control of the 2nd slave to the 1st slave in control and the audio cables likewise from out to in. Run another mini mono from the out control of the 1st slave to the in control on the master and the audio out from the 1st slave to the audio inputs on the master. Set the 1/2/3 switches on different on each unit and you should be in business.
Sep 12, 2011 | Sony MegaStorage CDP-CX455 400-Disc CD...
S.smith1@hotmail.co.uk How do I slave HDT721050SLA360 500GB 7200rpm
if you want to set a master / slave on you computer
slave :::':
Aug 26, 2011 | Hitachi Deskstar 7K1000B HDT721050SLA360...
How to connect it as a slave. there is no guide to follow on hd label
IDE-0 means Pri master ?
IDE-1 means Pri slave ?
IDE-2 means Sec master ?
IDE-3 means Sec slave ?
? single or master :::::
???????????????? slave? :::':
May 20, 2011 | Seagate Cheetah 15K5 Ultra320 SCSI 146GB...
Want to install wd1200jb-75cra0 as slave drive in dell xps420 with vista operating system operating master drive. do i need a driver installed first before it will recognize the wd1200 as a slave?.
there is a jumper setting on the drive itself that determines master and slave. Look closely at it, there is always a diagram of the pins to connect or disconnect for master slave setup.
No longer needed with Sata drives...
Feb 18, 2011 | Western Digital Cavier SE WD1200JB 120 GB...
Feb 16, 2010 | Computers & Internet
How do i install a used hard drive into an eMachines T2341? The hard drive still has information on it. do i set it as master, slave, or cable select? hard drive is an IBM 10.1 gb
There are two possible solutions depending on how your desktop is setup.
#1 install the 2nd hard drive and put jumper to CABLE SELECT. When you start the computer it should now appear in the bios as a SLAVE or 2nd hard drive. If not go to #2 below
#2 Turn system off again and change jumper on 2nd hard drive to SLAVE.
Now when your computer restarts it will appear in your bios correctly as the 2nd drive/SLAVE.
Do not make it "MASTER" or you will be trying to boot up to this drive and it may not work as you planned.
FYI: "Cable Select" means the hard drive determines which one is Master and which one is Slave by where it is on the data cable.
Good Luck
Dec 30, 2009 | Computers & Internet
What are the jumper settings for a maxtor 90640d4
this is layout " : : : . : " also no jumper for slave
master -------- " [:]: : . : "
cable select -- " :[:]: . : "
Oct 08, 2009 | Maxtor Hard Drive
Video Game Consoles & Games Logo
69 people viewed this question
Top Sega Video Game Consoles & Games Experts
Josh Whitehead
Josh Whitehead
Reggie brown
Frank Zabroski
Frank Zabroski
Are you a Sega Video Game Console and Game Expert? Answer questions, earn points and help others
