Question about Epson Stylus CX4800 All-In-One InkJet Printer
Purge tube out - Epson Stylus CX4800 All-In-One InkJet Printer
Code reading is 1447 is it the same as 1440?
No these are 2 different fault codes, although they are related to the same system
EVAP control system does not operate properly.
- EVAP control system has a leak in the line between intake manifold and EVAP control system pressure sensor.
Possible causes include ...
- EVAP canister purge volume control solenoid valve stuck closed.
- EVAP control system pressure sensor and its circuit.
- Loose, disconnected, or improper connection of rubber tube.
- Blocked rubber tube.
- Blocked or bent rubber tube to MAP/BARO switch solenoid valve.
- Cracked EVAP canister.
- EVAP canister purge volume control solenoid valve.
- Closed Throttle Position Switch.
- Improper connection of one-way valve.
- Blocked purge port.
- EVAP canister vent control valve.
Nov 02, 2016 | Cars & Trucks
What does code p1447 mean ...???
The code says "evap purge flow monitor fault"
This is a "jackpot" code. It points to so many possible causes as to be almost useless.
Feb 15, 2013 | 1996 Nissan Maxima
2004 BMW 325i I have a code p1447 do you know were to fix?
Fault codes do not have a single reason for being set, there are multiple reasons. here is the info you need to know about this code.
P1447 - Evaporative Emission Control System Purge Flow Monitor
Possible causes- EVAP canister purge volume control solenoid valve stuck closed
- EVAP control system pressure sensor and the circuit
- Loose, disconnected or improper connection of rubber tube
- EVAP canister purge volume control solenoid valve circuit
- Closed throttle position switch
Jun 13, 2012 | Cars & Trucks
2000 Ford Focus...DTC code PO455
code PO455
EVAP Control System Large Leak Detected
Possible Causes:
Aftermarket EVAP hardware non-conforming to specifications Canister vent (CV) solenoid stuck open EVAP canister purge valve stuck closed, or canister damaged EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube disconnected or cracked, or canister is damaged Fuel filler cap missing, loose (not tightened) or the wrong part Loose fuel vapor hose/tube connections to EVAP components Purge sensor or FTP sensor is out of calibration or has failed I would say that your gas cap is a good place to start.
Apr 25, 2012 | 2000 Ford Focus
Describe your Problemcheck engine light codes p0457 p0455
Trouble code P0455-EVAP Control System Large Leak Detected
Trouble Code Conditions:
ECT sensor less than 90°F at startup, engine running, and the PCM detected several small fuel vapor leaks or a large leak in the system.
Possible Causes:
  • Aftermarket EVAP hardware non-conforming to specifications
  • Canister vent (CV) solenoid stuck open
  • EVAP canister purge valve stuck closed, or canister damaged
  • EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube disconnected or cracked, or canister is damaged
  • Fuel filler cap missing, loose (not tightened) or the wrong part
  • Loose fuel vapor hose/tube connections to EVAP components
  • Purge sensor or FTP sensor is out of calibration or has failed
Jan 22, 2011 | 2006 Ford Explorer
Codigo p1440
EVAP System Vent Circuit Malfunction
This diagnosis detects leaks in the Evaporative Emission (EVAP) purge line using of vapor pressure in the fuel tank. The EVAP canister vent control valve is closed to shut the EVAP purge line. The vacuum cut valve bypass valve will then be opened to clear the line between the fuel tank and the EVAP canister purge volume control solenoid valve. The EVAP control system pressure sensor can now monitor the pressure inside the fuel tank. If pressure increases, the Engine Control Module (ECM) will check for leaks in the line between the vacuum cut valve and EVAP canister purge volume control solenoid valve.
Possible causes
- Incorrect fuel tank vacuum relief valve
- Incorrect fuel filler cap used
- Fuel filler cap remains open or fails to close
- Foreign matter caught in fuel filler cap
- Leak is in line between intake manifold and EVAP canister purge volume control solenoid valve
- Foreign matter caught in EVAP canister vent control valve
- EVAP canister or fuel tank leaks
- EVAP purge line (pipe and rubber tube) leaks
- EVAP purge line rubber tube bent
- Blocked or bent rubber tube to EVAP control system pressure sensor
- Loose or disconnected rubber tube
- EVAP canister vent control valve and the circuit
- O-ring of EVAP canister vent control valve is missing or damaged
- EVAP canister is saturated with water
- Absolute pressure sensor
Possible solution
- Loose fuel filler cap
- Leaking fuel filler cap
Hope helps (remember to rate this answer).
Jan 05, 2011 | 2000 Hyundai Sonata
Obd-2 code p1455
DTC P1455 - Substantial Leak or Blockage in Evaporative Emission Control System
The PCM monitors the complete EVAP control system for no purge flow, the presence of a large fuel vapor leak or multiple small fuel vapor leaks. The system failure occurs when no purge flow (attributed to fuel vapor blockages or restrictions), a large fuel vapor leak or multiple fuel vapor leaks are detected by the EVAP running loss monitor test with the engine running (but not at idle).
Check this possible causes:
After-market EVAP hardware (such as fuel filler cap) non-conforming to required specifications
Disconnected or cracked fuel EVAP canister tube, EVAP canister purge outlet tube or EVAP return tube
Damaged EVAP canister
Damaged or missing fuel filler cap
Insufficient fuel filler cap installation
Loose fuel vapor hose/tube connections to EVAP system components
Blockages or restrictions in fuel vapor hoses/tubes (items also listed under disconnections or cracks)
Fuel vapor control valve tube assembly or fuel vapor vent valve assembly blocked
Mechanically inoperative fuel tank pressure (FTP) sensor
Check for audible vacuum noise or significant fuel odor in the engine compartment or near the EVAP canister and fuel tank
Tell us news.
Jul 19, 2010 | 1996 Ford Explorer
I had an emission test done on my 98 bonneville and it failed because code P0440 evap control system what should i do ?
Here's list why your car is coming up with this code. It could be any of these things causing it.
DTC detecting condition:
  • EVAP control system has a leak.
  • EVAP control system does not operate properly.
Possible cause:
  • Incorrect fuel tank vacuum relief valve
  • Incorrect fuel filler cap used
  • Fuel filler cap remains open or fails to close.
  • Foreign matter caught in fuel filler cap.
  • Leak is in line between intake manifold and EVAP canister purge volume control solenoid valve.
  • Foreign matter caught in EVAP canister vent control valve.
  • EVAP canister or fuel tank leaks
  • EVAP purge line (pipe and rubber tube) leaks
  • EVAP purge line rubber tube bent
  • Blocked or bent rubber tube to EVAP control system pressure sensor
  • Loose or disconnected rubber tube
  • EVAP canister vent control valve and the circuit
  • EVAP canister purge volume control solenoid valve
  • EVAP canister purge volume control solenoid valve and the circuit
  • Absolute pressure sensor
  • Fuel tank temperature sensor
  • O-ring of EVAP canister vent control valve is missing or damaged
  • Water separator
  • EVAP canister is saturated with water
  • EVAP control system pressure sensor
  • Refueling control valve
  • ORVR system leaks
  • Fuel level sensor and the circuit
Apr 01, 2010 | 1998 Pontiac Bonneville
Degassed tube how to fix? repair?
Do you mean de-purged tube or de-gause tube? Image intensifiers are not like CRT where they have a gausing problem. If a spot is burnt into the image intensifier, it unfortuantely is permanent.
If you mean de-purged (gasless), this can be done by a reputable service/repair workshop with nitrogen.
Aug 12, 2008 | Tasco NV200 Monocular
Epson Stylus CX4800 All-In-One InkJet Printer Logo
16 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
