Question about Birds
How to freeze pumpkin - Birds
Can one freeze pumpkin pie and, if so, for how long?
As long as it stays frozen and never thaws out from freezer stopping or power going out, it's good as long as you need it, it want effect you in any way
Sep 27, 2017 | Cars & Trucks
Tip
Homemade pumpkin pie spice mix
Have you ever wanted to make a recipe that calls for "pumpkin pie spice" but don't have it in your pantry? It turns out, pumpkin pie spice in made from things that most people already have so there's no need to go out and spend the money on another spice that's just going to sit on the shelf. Instead, you can make your own with stuff you probably already have lying around your spice rack.
Here is all you need to make your own pumpkin pie spice:
  • 4 tablespoons ground cinnamon
  • 2 tablespoons ground ginger
  • 3 teaspoons ground allspice
  • 3 teaspoons ground cloves
  • 1 1/2 teaspoons ground nutmeg
Take these ingredients and put them in a small mason jar or some tupperware and shake them up good.
You don't need to use exact measurements and can alter to your own taste. My kids hate the taste of ginger so I usually cut it by about half.
On a side note, pumpkin pie spice tastes great sprinkled on your morning coffee or over your late night scoop of vanilla ice cream!
on Oct 07, 2013 | Cooking
Can I freeze homemade cheesecake
No. the cheese base will "break" and have a weird texture. Cheesecakes keep for about a week in the fridge. If you need a smaller size, use 1 8 oz brick of cream cheese, 1 large egg and 1/4 cuo of sugar over a graham cracker crust to make 6 cheesecake cupcakes.
Apr 05, 2016 | Homemade Gourmet Pumpkin Pie Cheesecake...
How to freeze a freshly baked pumpkin pie?
Cover it in saran wrap and stick it in the freezer.
Dec 07, 2015 | Baking
Can a pumpkin pie be frozen with a graham cracker crust
The pie filling will separate from the crust if you freeze it.
Feb 18, 2015 | Ovens
yes you should cook any veg before freezing. you will know by the smell and slimy texture of the flesh inside if it has gone bad.
Jan 12, 2014 | Birds
Can birds eat pumpkin seeds?
Yes, they can. You can feed your pet bird pumpkin seeds that you bought from the store, or you can take them out of a pumpkin yourself, clean them, dry them, and lightly cook them in the oven on tin foil. it is healthy and birds do find it tasty, too.
Dec 25, 2012 | Birds
97 ford explorer/bad front differential..can I remove it completly with the cv joints and let front wheels freewheel?
Yes is the short answer. Did you blow the gears in your front differential or you going to put a whole new pumpkin in? If you are replacing the entire pumpkin drain it first. Then make sure to support it with a transmission jack first. Remove the tires. Then remover the CV axles and lower the pumpkin. Your vehicle requires a 75w90 synthetic axle lube for a refill. Good luck.
Mar 06, 2011 | 1997 Ford Explorer AWD
Birds Logo
241 people viewed this question
Top Birds Experts
Tom Chichester
DaveMc3
DaveMc3
Heartland Ho
Level 1 Expert
Are you a Bird Expert? Answer questions, earn points and help others
