Question about Toshiba 62HM95 62" DLP HDTV
TV acts like it is turning on then shuts off then repeat, repeat
I was watching TV and heard a loud pop thru the speakers, the cable box reloaded and the TV shut off. I tried to turn the tv back on and it acts like it is turning on a green light next to the power red light (labeled Timer rec) blinks a few times then the tv shuts off and repeats the process over and over without ever turning on (black screen). What the damage?
  • Anonymous May 23, 2009
    heard a loud pop now can hear but no pic.turn on and it shuts itself off
  • Anonymous May 26, 2009
    Exactly the same thing happened to mine this morning; anyone out there have any updates on this. Did the TV work again or is it time to get in line for a new set at Best Buy?
  • 4 Answers
When my lamp died the bulb literally exploded. That may be what you heard. Have you check the lamp? If the lamp is ok, the lamp's ballast or power supply might have blown.
Posted on Oct 06, 2009
Had a loud snap when watching then no power.
TV repair, clicking and will not power on, loud snap, no ...
? 13:57
https://www.youtube.com/watch?v=UKoR7pWAHzk
Nov 25, 2014 - Uploaded by Robert DIY
TV Power board replacement - 30 - 60 minutes ($20 / $110 / $250 / Replacement) This video will show you ...
Samsung LCD 46 Pop! Then Dead! - TV Forums
www.tv-forums.com/...Repair.../Samsung_LCD_46_Pop!_Then_Dead!_...
Nov 23, 2011 - 7 posts - ‎3 authors
While watching TV, I heard a loud pop, then the tv went dead. ... Ok, so I tested the fuses and the main fuse, by the power plug, had no ...
Samsung power defect causes some TVs to fail, and a class ...
www.cnet.com > Home Entertainment
CNETFeb 14, 2012 - A defective capacitor in some Samsung LCD, plasma and DLP TVs is causing the ... The LN-S4051D is one of the TVs Samsung admits has issues ... In a February 9 report entitled "More than 7 million Samsung TVs plagued by possiblepower defect", ..... Today I heard a loud pop and now I have no picture.
Feb 09, 2016 | Samsung Televison & Video
Watching TV and all of a sudden a loud pop came from the back of the set. Doesn't turn back on after unplugging.
Hello
Check its power supply regulator board. The pop sound you heard may be due to an explosion to any electrolytic capcitors on it. If the line voltage exceeds, this fault will happen. just repalce the damaged component. It is best to replace this board as card basis.
Mar 19, 2012 | Hitachi 50HDA39 50 in. Plasma HDTV
No Picture, Power light Blinking 3 times then repeats
3 times blink shows lamp cover is removed or not installed properly on TV.
Please take out lamp inside TV and check, seems its broken as you heard loud pop.
Thanks.
Aug 28, 2009 | Sony Grand WEGA KDF-55WF655 36" Rear...
LOUD BUZZING/HUMMING SOUND- CAN HEAR OVER AUDIO
have someone check speaker ground to the TV chassis. Your speakers are picking up reverb from the Video Signal.
Aug 19, 2009 | Vizio L37 Television
Turns off after a few minutes
Sounds like a possible power short, especially if you have speaker cables connected to the receiver but not to speakers -- leaving the ends more likely to short (even via a single thin copper strand across a millimeter or two, when the voltage peaks). The receiver's message says "Check Spkr Cables," right? (They do mean the Speaker Cables!) Most receivers have a built-in power overload detection/protection shut-off circuit to save you from such mistakes.
Jul 18, 2009 | Yamaha HTR-5850 Receiver
I have BOSE speakers plugged into a small lcd tv. when the tv is off, I'm still hearing cable audio. why? i'll clarify. my tv has rca jacks connecting it to a couple of small bose speakers. sounds...
Your TV output is a pass-thru from the coax cable then. The only solution- turn the volume down, or unplug them.. Or get a cable box. A VCR may work as a temporary cable box, and if you have a remote for it, you should be able to just turn off the audio at any time with a VCR remote. (unless the VCR also has a pass-thru only audio output)
May 25, 2009 | Audiovox DVD Player FPE1505DV
Tv went out after loud pop and has clicking noise does not turn on
If you have a Sony DLP, then the loud pop you heard is your lamp.  The lamps last approx. 4K-6K viewing hours.  Read your manual for replacement part number to reorder and very simple to replace yourself.
Apr 22, 2009 | Televison & Video
Audio Problems
well dvd player is only 480 i ok not 720 unless its blue ray so dont even do that coupont cables usallly 480 also with comcast outs do u have hd then use one with hdmi outs ok coxal digtal cable works great also better rcas
Jan 05, 2008 | Olevia LT37HVS 37 in. LCD HDTV
DURABRAND HOME THEATER
if you have a cable box run the subwoofer thru that . should work fine but you will have to turn off sub to kill volume as its running thru cable box not the audio of the tv
Nov 06, 2007 | Durabrand HT-3915 System
Sony Bravia XBR-2 32-inch LCD with popping noise problem
Has anyone heard of something like this where the cable box/service is causing popping sounds? yes & it is common problem. And is this something I should be concerned about causing damage to the TV's speakers? not at all. The Sony tech-support representative (over the phone) diagnosed it further to a problem not with the TV but with the cable box/service because there were no popping sounds when I played a DVD on my Playstation 2 that is attached to the TV. they are right that your problem is not due to tv. it is due to cable box/service? yes but not defective it reqires to change the way you have connected tv to cable.please call tech to get it connected in such a way so that you do not get popping sound when you you put off cable box.
Sep 23, 2007 | Sony FD Trinitron KD-36XS955 36" TV
Toshiba 62HM95 62" DLP HDTV Logo
571 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Henry  Thomas
Henry Thomas
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
