How do i connect my projector to my laptop - Office Equipment & Supplies
    Genius:
  • 1,552 Answers
If your laptop has a "VGA-output" port, and if the projector has a "VGA-input" port, then use a VGA-to-VGA cable to connect the two ports.
Posted on Mar 29, 2014
There is a blue line when plugged into laptop
I had the same problem. The projector works wonderfully connected to my iPhone (with an adapter), and connected to other kinds of laptops, but not with mine. Apparently the projector is not compatible with every laptop. I had to connect my projector to my laptop via a Netgear PTV1000 streaming player in order to use it.
You connect to the player wirelessly. Then use the HDMI cable to connect the player to the projector.
Streaming Players
I happened to already have the player so I didn't have to purchase a new device. I hope this helps you.
Jun 28, 2014 | Brookstone HDMI Pocket Projector
Laptop screen resolution
when u connect to projector.after connecting change your laptop screen resolution and by setting lowest resolution you will see full screen.
Feb 19, 2012 | InFocus LP530V Video Projector 2000 ANSI...
Our problem is the acer projector how to connect the projector with using lg xnote laptop.
Laptops have a 15 pin DSub video connector. Just connect a data projector to this video connector, power up the data projector first and then boot up your laptop. The video data will automatically divert to the data projector.
Sep 05, 2011 | Computers & Internet
I have a DELL XPS 15 Laptop. I tried to connect the laptop to different lcd Projectors using HDMI to VGA connector. The laptop could not be connected with any of the lcd projectors and no projection on the...
Hi
Sure can be fixed.
1st of all you need to connect the projector with your laptop turned off. One the laptop has finished booting and loading windows. Hit the Fn+f4 or f7 key to switch between the displays then you will get the display.
But if this also does not give display then you can check with the projector with Video INPUTS (Eg. Input 1 / Input 2 etc.,)
Jul 21, 2011 | Epson EMP-S5 Projector
I have my G60 laptop connect to an LCD projector. I wanted to turn off the screen on the laptop and hit Function F4 which i have done in the past and it took the picture off of the LCD projector and now...
Disconnect the cable that is connecting the laptop to the projector. Sometimes this will happen if the projector or device you're connecting your laptop to does not support the current resolution that the laptop is displaying. Reconnect the cable and try using Function F4. If that does not work then disconnect the cable from laptop to projector, reboot the laptop then repeat connecting it to the projector and pressing Function F4.
Feb 23, 2011 | HP G60-120US Laptop
When i connect my dell latitude d630 laptop to projector it did not work. Pl. suggest any suitable solution. Regds safi
after connecting the projector just press function key and F4 . After pressing these key the projector connected automatically
Jun 02, 2009 | Computers & Internet
How to connect laptop to projector?
Data projectors have a video cable and you connect it to the 15pin blue video connector on the laptop. Then you power up the projector and then power up the laptop. The laptop should automatically dirvert the video information to the data projector.
If the image produced from the projector is not clear, then you will need to reduce the screen resolution on your laptop using Control Panel - Display - Settings.
Mar 30, 2009 | Fujitsu LifeBook A6110 Notebook
Infocus projector 4805 connected to Toshiba laptop
1.
Connect the external display port on your laptop computer to the projection system, and then turn on the projector. For information about connecting external devices to your laptop, see the documentation for your laptop computer.
2.
Set the display resolution of your laptop computer to match the resolution of the projector system. First, on your laptop, open the Display Properties dialog box by using the Display icon in Control Panel, and click the Settings tab. Then, in Screen resolution area, move the slider to adjust the display resolution of your laptop. If you don't know which setting to choose, try 800 x 600 pixels; this is a common setting for many projector systems.
Jan 08, 2009 | InFocus ScreenPlay 4805 Multimedia...
Gateway laptop 450ROG video issue when using a projector
Honestly from the information you have listed it sounds like the issue is with your projector, not your laptop. If your laptop was having display issues it would be consistent on anything it was attempting to output display to, such as your monitor.
The projector sounds like its out of focus and possibly has a bad back light in it, I would suggest contacting the manufacture for a possible resolution.
Dec 15, 2008 | Gateway 450ROG Notebook
HOW TO CONNECT MY PROJECTOR TO MY LAPTOP?
I have hp laptop with hdmi & vga, sharper image projector with rca connector what do I need to connect these two
Dec 22, 2007 | Philips cBright XG2 Multimedia Projector
jasbo
jasbo
