Question about Conair SW-207AS Corded Phone (SW207AS)
Mute on phone - Conair SW-207AS Corded Phone (SW207AS)
How can I turn off the mute function?
If it is a VTech phone ( CS6429 or similar )
press the [mute] button again: it is a toggle.
First press of [mute] turns mic off (mute-on).
Next press of [mute] turns mic on (mute-off).
Apr 22, 2016 | Lands Phones
How to get my unidendect60 off silent mode
Uniden offers a variety of electronics products including corded and cordless telephones. Each of these phones features the ability to mute the phone whenever you desire. Muting the phone can be done as often as you like and canceled as you desire. The steps to muting your phone will vary depending on the type of phone you are using.
b> Locate the "Mute" button on the phone. The button will be on the keypad near the number keys. Press the "Mute" button to mute the phone. Look for the "Mute" indicator on the phone's display to ensure that the phone is muted. Speakerphone Volume Use the VOL (+ or -) buttons to adjust the speakerphone listening volume while it is in use.
http://www.uniden.com/pdf/1380BKom.pdf users guide
Jan 20, 2013 | Lands Phones
I have accidentally muted my phone, how do I unmute it. Razzle phone
Knowing the type of phone you have would help also the circumstance. Is the phone muted during calls? or is it muted all the time? If the phone is muted all the time use the volume button usually on the side of the phone to raise the volume and it should take the mute off. If the phone is muted during a call their is normally a button on the screen of the phone during the call to mute and unmute the phone.
Jul 15, 2011 | verizononline.com
I need to mute/unmute my phone for a conference call. Not sure how to do this.
Some cell phones don't mute, but a *6 will mute your phone to the conference call center, and #6 will unmute if you wish to say something. This will not mute your phone, so when you hang up...you're always good to go to make calls. It only mutes a phone (any phone) to the server conducting the conference.
Oct 21, 2010 | Samsung Smooth SCH-u350 Cell Phone
How do i get mute off my phone
Well that would be hard to believe you can't get mute off since you have to personally initiate mute while during a call and the mute would be disable after you hang up. The mute button is located on the left side below the screen. Now here is what you might want to look at. Make sure TTY mode is off, this option would put your phone in permanent mute. Go to settings then to call settings, TTY mode should be off. If this still doesn't work and your phone displays "car kit" on the main screen then your phone is probably water damage or needs repair.
Jul 13, 2009 | LG VX8350 Cellular Phone
No mute - conference calls
sounds as if you will need your vendor to program your phone and others that need be to have Handsfree/mute capabilities.. i assume since you can not mute then you can not place your phone on Handsfree either.
May 29, 2009 | NorStar Meridian M7310 Phone
Is there a mute feature? Using the speaker phone w/mute?
sometimes the mute button is with the menu button or it has it own button. I would look on the phone and see if there is mute above a button. If it is above a button than that is the mute button when the phone is on. To make sure, I would call a friend then put it on speaker, then hit that button to see if that is it.
Dec 22, 2008 | Toshiba DKT3020SD Corded Phone
Mute - Turn On??
Welcome to Panasonic :-)
The mute button works when you have a speakerphone call. That means SP-PHONE pressed and press MUTE and it flashes to let you know it's on mute.
Maybe software version 9.0 will fix the mute to work on handset calls.....
Carl
Jul 15, 2008 | Panasonic KX-T7731 Corded Phone
How to mute my Uniden phone
You have to use the menu on the handset. Press Menu/Clear, then Mute, then push the Select button. Repeat the same to turn mute off.
Mar 31, 2008 | Lands Phones
Conair SW-207AS Corded Phone (SW207AS) Logo
Top Conair Lands Phones Experts
k24674
Tom Chichester
Are you a Conair Lands Phone Expert? Answer questions, earn points and help others
