Question about Canon Imagerunner 1025IF Grayscale Copier
Unable to print
On the printer it says to change sizepaper in common settings, already changed it but still unable to print
I have been using wi-fi printing on Samsung Galaxy 8.4 Tablet & now I'm unable to get my tablet to print.
Your printer may have changed it's IP address. This is a common occurrence on wireless networks. You should be able to get the new IP (to configure your tablet) by doing this on your printer: Go to the Home Screen --> Setup, then touch Reports and then select Network Configuration to see all of the printer's network details.
Mar 16, 2016 | HP Tablets & eReaders
Unable to print an email from my advent laptop to mt HP 3050A all-in-one J611 wireless printer
Check your WiFi setting, sometimes the printer goes offline or not recognized if the device IP is changed by the gateway DHCP (router or pc), just check ON THE PRINTER if it is connected to your network, if not only reconnect you printer to the wireless newtork.
Mar 07, 2015 | Advent Computers & Internet
UNABLE TO PRINT LANDSCAPE AFTER 1: OPEN SPREADSHEET FILE 2: GO TO PRINT 3: GO TO PROPERTIES 4: GO TO PAGE SET UP & CLICK LANDSCAPE 5: GO TO PRINT PREVIEW(DOES NOT SHOW OR PRINT LANDSCAPE)
You need to change the page layout within excel set it to lancscape.
for excel 2007
Look along the top ribbon and click on "Page Layout"
then select "orientation"
and change to "Landscape"
Dec 04, 2009 | Canon PIXMA MX310 All-In-One Printer
Pc load letter
Hi there this issue is caused by your driver defaulting to letter and a4 paper being used set your default paper size to a4 in the driver and also set tray to a4 this should cure the problem Regards AL "alstech"
May 28, 2009 | HP LaserJet 4 plus Printer
ZebraDesigner Pro is changing my settings
If you have two printers 105se and the 105sl must install the two printers and select the correct model when you print your labels.
Mar 10, 2009 | Zebra 105SL Thermal Label Printer
Unable to print copies
Normal 0 Could have a corrupt driver.
Disconnect the printer or at least be sure it is turned off. I'd do both and when the CD software program asks you to connect the printer to the USB port, do so and it should again work properly.
Hope this helps. Bud
Dec 30, 2008 | Brother MFC-845CW InkJet Printer
Brother mfc-210c printer display keeps saying unable to change
you don't mention if itn is unable to change the paper size before printing.
if that is the case, please change the papaer size set up that is correct for your region, in the printer properties
Apr 29, 2008 | Office Equipment & Supplies
Printer Defaults
try setting up your sizes etc on the required printer in" printers and faxes" first and then access your print system , when you then select the "print" function you will find the sizes etc that you have set up in printers and faxes are already set for you , unfortunately it will only save for a few prints and then will default ,however it defaults to the settings you have already set up in printers and faxes
Jan 27, 2008 | Zebra Printer 140-751-00000
PRINT ROTATE
Hello. Try setting the casstte sitch located just inside the paper cassette, coloured blue, to the A4R setting. Let me know?
Nov 21, 2007 | Canon imageRUNNER 2000 Copier
Canon Imagerunner 1025IF Grayscale Copier Logo
20 people viewed this question
old marine
old marine
