Question about Cycling
Bike serial number look up
What size is a 2005 Lemond Zurich with a serial number WL3228042?
  • 29 Answers
Never mind the serial number. Bust out the tape measure and measure from the center of the crank spindle (the axle the cranks turn around) to the top of the seat tube. It's usually in centimeters, and sizes for road bikes run from anywhere from the low 40's to the mid 60's.
Posted on Jan 07, 2014
Trek 8000 frame size serial WTU 8120289 T
Your post makes no sense. Frame size is not ID'd by serial number. Just Google bike frame size. Just Google "measure bike frame" for instructions for measuring, and Google "bike frame size" for info on selecting the correct size.
I’m happy to help further over the phone at https://www.6ya.com/expert/donald_f2ed37026a3ac881
Nov 25, 2017 | Trek Cycling
Tip
Bottom Bracket & Spindle Replacement of LeMond RevMaster
Part 1 Video Discussing the Dis-assembly & Inspection of the Bottom Bracket & Spindle for a LeMond RevMaster Bike
  • This Part 1 video will demonstrate how to inspect and adjust or remove and replace the bottom bracket and spindle on your Lemond Revmaster
  • Tools needed for this procedure:
    • 8mm Allen Wrench or Socket
    • Cotterless Crank Puller Tool
    • Lock Ring Removal Tool
    • Bottom Bracket Tool
    • Phillips Screwdriver
    • 4mm Allen Wrench
    • Bungee (optional)
    • Rubber Mallet
    • 7/8" Wrench
  • To begin remove the belt cover, there are four screws
    • You will need a 4MM Allen wrench
  • Now remove the two screws on the back from the opposite side of the bike
    • You will need a Phillips screwdriver
  • Now position the crank arm as seen in the video and remove the belt cover from the bike
  • Before removing the drive belt, tighten the brake assembly so that the flywheel is locked in place and loosen the torque on both bolts using an 8mm Allen wrench or socket
    • Do not remove them at this time only loosen them by a half a turn or so
  • Using a 7/8" wrench loosen the belt idler
  • Now use a 4mm Allen wrench to loosen the tension adjustment bolt completely, but do not remove it from the frame
  • Now remove the drive belt
    • To aid in this process you can use a bungee to slide in behind the belt at the top, as shown in the video
  • Then pull away from the bike while spinning the crank arms
  • Now remove both crank bolts with a 8MM Allen wrench or socket
    • Removal of the crank bolt on the left side of the bike is the same as removal from the right side
  • Now remove the crank arms with a crank arm puller, threading the outer portion into the crank arm as shown in the video
    • Be sure to thread the outer portion in as far as possible to prevent damage to the crank arm threads or the tools threads
    • Use a 7/8" wrench to make sure the outer portion is threaded in completely
    • Now spin the handle clockwise to press the crank arm off of the bike
    • Be careful when the crank arm comes off as if you are not holding it, it can fall in the floor
    • Also use the wrench to loosen the tool before removing the crank arm from the unit
    • Now you can unthread the tool from the cranks arm by hand after removing the crank arm from the bike
  • Next inspect the bottom bracket cups for looseness, to do this use the bottom bracket tool by hand to see if you can turn either of the bearing cups
    • To further verify the adjustment of your bottom bracket use a rubber mallet to tap lightly on each side of the spindle to check for movement from side to side, if you have movement, or one or both of the bearing cups is loose, you need to re-adjust the bottom bracket. If you are only inspecting the bottom bracket and did not find any need for adjustment you would re-assemble the bike at this point
  • Once the crank arms are removed look closely at the spindle
    • It should have defined edges and be smooth
  • As you can see by the video our spindle needs to be replaced
  • Next you will need to remove the lock ring
    • The lock ring is around the bottom bracket cup on the left side of the bike
      • In the video is an example of a lock ring
    • To use the lock ring tool you slip it over the lock ring using the three notches and torque the lock ring in the proper direction
      • This one needs to be turned counter-clockwise to loosen
    • Then remove the lock ring by spinning it off the bearing cup
  • Next you will need to use the bottom bracket tool to remove the bottom bracket cups
    • Begin with the left side
      • Slip the tool into the splines of the cup and loosen
        • For stubborn bottom brackets use a 5/16"-24 x 2" bolt and some washers with a 1-1/4" wrench
          • Slip the tool into the splines and thread the bolt with the washers into the spindle
          • Get it snug but not completely tight
      • Now use the wrench to turn the cup counter-clockwise for the left side and remove it completely
    • Remove the cup from the right side now
      • Slip the bottom bracket tool into the splines of the cup and turn it clockwise to loosen
    • If you cannot get the cups loose with this method try turning the bike on its side to get better leverage as shown in the video
  • This concludes the dis-assembly and inspection procedure of the LeMond RevMaster bottom bracket & spindle
  • Click here to see Part 2, re-assembly and installation to complete the replacement procedure
Video of Bottom Bracket and Spindle Replacement Part 1 Dis assembly LeMond...
on Feb 19, 2015 | Lemond Revmaster Lemond G-Force Digital...
How do you interpret the serial number so I know the size of my bike
serial number may not tell size of the frame. take it to the nearest bike shop for measurement
Mar 04, 2015 | Cycling
How do I tell how old my bicycle is by the serial number
Serial numbers by themselves don't tell who manufactured your bike. You need the brand name, the kind and size of bike is also helpful
Sep 14, 2014 | Cycling
Bike serial number lookup
Serial number alone doesn't provide enough inform to identify a bke. You need manufacturer, location of the number and tire size to properly idientify an bike.
Aug 08, 2014 | Mongoose Cycling
WHAT KIND OF BIKE MODEL GOES THIS SERIAL NUMBER WTU140CS0456J
Serial numbers alone won't tell much about a bike. Need size, type of bike and any decals or markings on it
Jul 23, 2014 | Trek Cycling
Need to no year make and model of trek bike bye serial number
Hi
Trek's serial numbers are on the underside of the bottom bracket. Flip the bike over and read the letters and numbers. It will look like this :
9000697000480
This would be a Trek 9000, made in June 1997 and number 480 off the production line.
Hope this makes sense and you can decipher your bike. Vote for me if this helps, thanks.
Jun 27, 2010 | Mountain Trek Fisher Bike Derailleur...
I have a serial number need to know what size
Look on your frame, (or registration) and get the vin number. Take both these numbers to a local Yamaha dealer and he will accurately give you the information you require.
Feb 10, 2010 | 2001 Yamaha SR 125
Looking to find age of yamaha bike using serial number
Get the vin number off the front downtube that the steering triple tree mounts to. Call a Yamaha dealer with the vin # and they can tell the year, engine size and model of bike.
Please rate this solution.
Mar 30, 2009 | Yamaha DT 125 X Motorcycles
Cycling Logo
176 people viewed this question
Top Cycling Experts
Michial Gueffroy
Andrew Taylor
Andrew Taylor
Are you a Cycling Expert? Answer questions, earn points and help others
