Question about Ryobi BE318-2 3 X 18 BELT SANDER
Ryobi BE318-2 dust bag don't work
Dust bag stopped working, after first I emptied the bag, I just bought the sander and it worked till I reattached it and started to sand again, I check and it was on properly but didn't collect the dust.
    Problem Solver:
  • 9 Answers
The pathway that the dust follows to reach the bag is most likely clogged. Take the bag off and look inside to see if there's sawdust plugging the orifice. If there is then you could vacuum out the dust or simply start up the sander and let the machine clear itself. If you do the latter just know that you will create a cloud of dust so do it in the proper environment.
Posted on Jan 21, 2014
Ryobi belt and disc sander
It's only a month old. Take it back for a repair/replacement under warranty.
Jul 01, 2017 | Tools & Hardware - Others
Where to purchase Ryobi dust bag for model RESV-1200A
I couldn't find a Ryobi blower model RESV1200 but they do have an RESV1300. A dust bag is available for that model at: http://www.ereplacementparts.com/ryobi-resv1300-41abespg034-handheld-blowervacuum-parts-c-7931_15636_18676.html. Hopefully it is compatable with your blower. If you're unsure call their 800 number, they're really helpful (no I don't work for them).
Dec 23, 2010 | Ryobi Garden
Air and dust no longer blow into dust collection bag. I suspect that there is a clog somewhere.
are you putting holes in the papper with the guide? there has to be holes in the paper for the dust collection to work
Oct 15, 2010 | Dewalt DW411 quarter - sheet palm grip...
Hello, the dust is not coming out into the bag
if you have compressed air remove the dust bag and blow thru every port and opening you can find. Make sure to wear safety glasses. Then I would run the tool with the dust port facing away from you, there is a buildup inside not allowing proper flow, you should empty the dust bag when half full for maximum performance.
Apr 19, 2010 | Makita 3 x 24" Belt Sander
I have a porter cable belt sander that shoots dust out the front. It has a dust bag but the wood dust doesn't go in the bag. it used to. I have taped up some weak parts of the bag but I am not sure what...
the inside of the tool is full of dust not allowing it to get into the bag. I have had to completely disassemble and clean the track for the dust. You can try blowing thru every port with compressed air and see if that helps.
Nov 09, 2009 | Porter Cable 3" x 21" Electronic Variable...
Bosch 3 x 21 Belt Sander
Remove the dust bag and unplug sander for now. Everywhere you see an access hole (fan area, dust port, back of sander blow thru the tool to remove lodged dust that clogged the system, Also look for broken belt pieces in the back of sander. Then while running (remove belt) blow again thru all the ports to try and reomve as much contamination as possible. When finished you can feel to see if air coming from dust bag port, it not you still have a clog that might need more work. If I have clarified your request would you please rate this response accordingly and thank you.
Sep 10, 2009 | Bosch 1274DVS 3" x 21" Belt Sander
Unable to remove dust bag
Get your wife to help you remove bag. Turn and pull.
Jul 22, 2009 | Makita 9924DB Electric Sanders & Polishers
Belt sander clogged dust collection
What have you been sanding?  Make sure the sander is unplugged. Remove the dust collector bag and use a flexible wire, like a coat hanger, to free the clogged material from the dust tube.  Replace bag and sand away!  Hope this solution works for you.  Michael Mittelsdorf
Jan 10, 2009 | Porter Cable 362 12 Amp 4 Inch By 24 Inch...
Dust collector
dust collectors usually work off the motor via a fan. Either the fan is broken or the bag is blocked up.If the bag is too dirty inside you don't get any airflow through the bag which can stop it collecting. A good wash should do the trick
Aug 29, 2008 | Porter Cable 3" x 21" Electronic Variable...
Ryobi BE318-2 3 X 18 BELT SANDER Logo
750 people viewed this question
Top Ryobi Tools & Hardware - Others Experts
Jim Parker
Jim Parker
Mike
Jay Finke
Jay Finke
Are you a Ryobi Tool and Hardware - Other Expert? Answer questions, earn points and help others
