Question about Provo Craft Cricut Disney Font Cartridge
Cricut mini flashing red light - Provo Craft Cricut Disney Font Cartridge
1-Open Cricut Craft Room with circuit on and flashing green/red
2-Hold power & feed button together until both are solid green
3-You'll be prompted to update firmware
4-Press & hold two buttons again (keep holding)
5-initiate firmware update
6-Let sequence go until 99% ...you may hear a sequence of beeping, don't be alarmed
7-Release buttons
8-You'll be prompted to restart your machine
9-Unplug all plugs from Cricut
10-Wait 30 seconds
11-Plug in both cords
12-Power on Cricut
13-Light should be solid green
14-Press OK on Craftroom prompt on computer
15-Done
Posted on Mar 24, 2016
My Cricut Explore Air wont cut
If your Cricut machine is not cutting all the way through your material, or is only scoring the material, choose a machine below for specific troubleshooting tips. Fortunately this issue can usually be resolved with basic troubleshooting.
correct cut settings.
  • Remove the blade housing, then remove the blade and ensure that there are not any bits of paper stuck to the blade or lodged inside the blade housing. Ensure that you replace the blade housing correctly into the machine. Once clean, test your cuts again. If the blade and housing are already free from debris, or cleaning it did not help, proceed to 3.
  • Try an arm buoyancy test: gently press down on the black arms that surround the blade housing and then release them. Do they bounce right back up, or do they stick or rub in any way? If they stick or rub, please contact Customer Care through one of the options below for further assistance. If they bounce right back up when released, proceed to 4.
  • Increase the machine pressure settings and try your cuts again. If this does not change the cut result, proceed to 5.
  • Increase blade depth by turning the dial at the top of the blade housing. If this does not change the cut result, proceed to 6.
  • Perform a Hard Reset on the machine. If this does not help, proceed to 7.
  • Check your machine's firmware version. If the firmware is not up to date, perform a Firmware Update using Cricut Craft Room, a Gypsy device, or Cricut Design Studio.
  • Retry your cuts with a new blade housing.
  • If the machine is still not cutting through materials, or is only scoring the paper, please contact Customer Care through one of the options below for further assistance.
  • Forced Firmware Update on the machine through Cricut Sync.
  • Retry your cuts with a new blade housing. If the issue persists, proceed to 8.
  • Attempt a Format and Restore on the machine through Cricut Sync. Please note that this step should only be taken if all other steps have failed to resolve the issue.
  • If this does not resolve the issue, please contact Customer Care through one of the options below for assistance.
  • new blade. If this does not help, proceed to 5.
  • Adjust/increase the Multi-Cut setting in the Cricut Craft Room cut preview screen and retry your cuts. If this does not change the cut result, proceed to 6.
  • Retry a cut using a new blade housing.
  • If the machine is still only scoring or not cutting through the material, please contact Customer Care through one of the options below for assistance.
  • Jan 16, 2017 | Crafts & Hobbies
    My cricut mini wont cut. an error appears and says that the images arent on the mat properly and will be skipped
    I am having this problem also. The image i wish to cut is well inside the 12 inchs. Hope someone has the answer
    Oct 30, 2016 | Crafts & Hobbies
    One or more of your cut images are not positioned entirely on the mat, They will be skipped
    Just follow the steps given at this link, and your cutter should begin to cut again. I just tried it and my cutter is back cutting. Cricut Craft Room Troubleshooting Cricut Help Center
    Aug 01, 2016 | Provo Craft Cricut Mini Electronic Cutting...
    TheI can not reset the circuit machine all green lights are on
    You can call customer support. They will have you install the Cricut Design studio just so you can access the firmware update. You must find a PC to do this - it will not work on your Mac that you use for everything. After your 10 year old PC takes 40 minutes to install and open Studio, you run it and restart your Cricut and all of your green lights stay on. You re-run it just to be sure, and all of your green lights stay on. You call back customer support and they have you cut out the drive belt to disable your Cricut and take a picture of it, then they will send you a refurbished replacement Cricut - white and gray, not white and pink like you own. This was my experience today and my only used twice Cricut is now ready for garbage pickup.
    Jul 23, 2012 | Provo Craft Cricut Expression Personal...
    Cricut expression 2 has no power, will not turn on
    Any resolution to this issue? I like stone234 have narrowed it down to the cricut not getting power past the power board. I tested the two prongs that feed the red and black power for the main board and no voltage. Cricut Exp 2. Powered on as soon as I plugged it in. Plugged in usb to computer, I didnt have the software so i searched for it then started downloading it and noticed the screen on the unit was frozen. unplugged it and after plugging it back in it wouldn't power back on.
    Nov 05, 2011 | Cricut Expression Cutting Machine
    The cricut blade holder doesn´t go up or down.
    My housing was not going up or down. Every time i wanted to make a cut it dragged and cut shapes in half. So when I took it apart I pushed it up and down myself and noticed that it was very difficult. So where you see the coils, I lightly sprayed WD40 (my cricut is out of warranty, I would not advise to take apart if you are still under a warranty). I lightly sprayed until it was easy to move up and down. When your done be sure to wipe any access WD40 that dripped to the bottom. This fixed mine and thank goodness because I was close to pulling out my hair! Hope this helps someone else!
    Jul 26, 2010 | Cricut Expression Cutting Machine
    Brand new cricut doesn't turn on, just clicks with lights blinkin
    Yes, I was just going to recommend contacting them. I see you have contacted them already. Good luck with getting it fixed~they are prompt in helping with machines. If you have any further questions about the cricut feel free to ask.
    Aug 20, 2009 | Provo Craft Cricut Disney Font Cartridge
    Cricut Expression flashing lights
    Souns to me like the cutting slide head is binding or the material transprt has a meesed up gear train. Or the case has been fractured
    Jul 24, 2009 | Computers & Internet
    Flashing red light and working
    i have NV-D60EN model panasonic mini dv camer but when i use to record and play back, its red light falshing for about some second later switching itself off. it does not function any thing so that if you don't mid give me the solution please
    yours respectful customer
    God bless you !!
    May 13, 2008 | Panasonic NV-DS60 Mini DV Digital...
    Provo Craft Cricut Disney Font Cartridge Logo
    1,482 people viewed this question
    Top Provo Craft Crafts & Hobbies Experts
    R.A. Ellis
    R.A. Ellis
    Debbie
    Are you a Provo Craft Craft and Hobby Expert? Answer questions, earn points and help others
