Question about A O Smith Motors Pool & Spa
Remove impeller pool pump
I am trying to remove an Emerson EB841 pool pump motor but it does not want to separate from the impeller. What should I do to complete the removal? I did it about 10 yrs ago with a different motor, but this one was installed by a pool shop.
  • A O Smith Mo... Master
  • 1,383 Answers
Look to make sure there is no ***** in the center of the impeller, if so, it loosens to the right. the impeller will come off by turning it to the left (facing the impeller) if you still have trouble with the impeller, search your area for your ''local pool pump motor repair guy'' with free testing.
he should be able to save the impeller and install a new seal for around $20.
remember to prime the pump with water after any repair !
Posted on Apr 06, 2016
dragonsthatk
  • 547 Answers
SOURCE: water leaking
some times you need two people one to hold the shaft the other to turn impeller on you need to put in a vice wraped in a towel and not to tight or break it off and replace it to
Posted on Feb 11, 2009
  • 3 Answers
SOURCE: tring to take the pump face off the motor
You have to remove the back cover from the motor. Next loosen the capacitor. Put a 7/16" wrench on the shaft and the pump impeller will screw off by hand.
Posted on Jun 04, 2009
valiantma595
  • 176 Answers
SOURCE: how to remove impeller from motor to replace
If it's a separate shaft, it requires a puller tool, but first you have to remove a nut that holds the impeller to the shaft. If the shaft is part of the impeller, meaning that it is a one piece fabrication, then there is nothing you can do about it. You haven't even stated where does this impeller come from, a washing machine, a water pump, etc.
Posted on Sep 18, 2009
  • 106 Answers
SOURCE: How to remove impeller on pool pump to replace seal?
First, separate motor and pump. Remove back cover of motor. Drive shaft of motor either has a slot on end for a large screwdriver or a flat on it for a wrench.(usually 7/16) Hold shaft and unscrew impeller.
Posted on Feb 21, 2010
MOTORWIZJ
  • 1383 Answers
SOURCE: how to disassemble impeller on rs1000 hayward pump
OFF TO THE LEFT FOR REMOVAL OF A IMPELLER BUT SOME MAY HAVE A SCREW IN THE CENTER IT IS A LEFT HAND THREAD SO IT OFF TO THE RIGHT.. BRING IT TO YOUR LOCAL POOL PUMP MOTOR REPAIR GUY TO HAVE IT DONE RIGHT
Posted on Jun 29, 2010
Where can I find a diagram to fix a pump K55MYGRD-8367
this can be a hard pump to service. but you can remove the front pump housing and see if you can remove the impeller by hand, the back of the motor will have a screwdriver slot in the shaft to hold the rotor still while attempting to unscrew the impeller. after removing impeller you will need to remove the 4 thru bolts this will allow you access to the ceramic portion of the shaft seal assembly.
replace all needed parts and reassemble. never run pumps dry always prime the pump with water.
doing this job can save you a bunch of money and usually cost about $150 at my shop.
Jay the pool pump repair guy Longwood FL.
Jun 26, 2017 | Emerson Pool & Spa
How hard is it to change the motor out in an Emerson pool pump model k63cxese4793 (Challenger Pyrex triton)
NOT tat bad, (first x2) shut breaker off next take off the stainless steel band, pull motor and seal plate back from plumbing portion use wrench on back of the shaft of the motor, impeller screws off to the left, take out 4 9/16 bolts that attach the motor to the seal plate, give seal plate a tug and it should separate from the motor. use new seals especially the shaft seal (the one w/the spring in it) and put it back together. tap on the SS band this allows it to evenly pull up around the tank body lastly FILL PUMP (prime) with water.
or search for your LOCAL POOL PUMP MOTOR REPAIR GUY. and ask about installing the motor on the seal plate.
I charge $20 and it includes the shaft seal (most pumps)
Apr 19, 2017 | Emerson Pool & Spa
How to replace impeller
take bolts out to separate wet end of pump and motor then remove screw if one on impeller sometimes they are backwards threads take screw out then unscrew impeller while holding shaft of motor that should be a regular thread separate backing plate from motor change seals then revese
Jul 06, 2014 | Pool & Spa
Need to remove the impeller
Turn off the system at the breaker,
Undo bolts for housing and separate the motor from the pump to access the impeller. Some styles of motors have a screw that is reverse threaded holding the impeller in place, if it has one , remove the screw. Once you have access to the impeller you can use a big pair of channel locks to turn the impeller. Take off the back cover of the motor or remove the plastic or metal cap that is covering the shaft. Use a wrench to hold the back end of the shaft as you unscrew the impeller.
Aug 29, 2013 | AO Smith Pool Pump Motor Hayward Swimming...
How to separate pump from motor
take screws off around housing that separates motor from wet end remove diffuser then remove screw from impeller backwards thread and hold back shaft of motor after removing still hold shaft and turn impeller off regular threads make sure to replace seals
Apr 16, 2013 | Pentair 1 hp WhisperFlo InGround Pool Pump...
Have a Sta-Rite 1.5 hp Model #HMSF 1F - trying to get it apart to change seal- has been leaking and losing prime- four bolts hold the motor on- tried to separate there first but will not pull apart (maybe...
Remove impeller housing cover. Insert screwdriver carefully into back of motor to keep the armature from turning then unscrew impeller clockwise or opposite the direction of operation. Replace seal on impeller and pump housing. Lube seal with graphite. Replace impeller and housing cover. Remove screwdriver from motor. You should be good to go.
Sep 10, 2011 | Sta Rite 1 Hp Sta - Rite Abg Swimming Pool...
I have emerson 1081 (model # K63CXETN-4820) pool motor. I am looking for impeller for this motor. Can you plz point me to where can I get the impeller?
that motor will fit all sorts of pumps, YOU NEED TO KNOW WHAT KIND OF PUMP you have,, hayward,jacuzzi.. the motor pictured is a round flange.. look on ebay to see if you can find that looks just like yours ! than ask the question..
May 12, 2011 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
How do I get old motor off pump to install my new motor?
The front of the wet end must be removed to access the impeller. Then remove the rear electrical covering to expose the rear end of the motor shaft. Look closely at the shaft. It has two flat sides. A 12mm open face wrench will fit onto the shaft. Lock the shaft in place with the wrench and unscrew the impeller. The rear housing behind the impeller pops off to reveal four 9/16 bolts. Remove them and the motor is free. Reverse the process with the new motor.
Apr 22, 2010 | Emerson THREADED SHAFT UP RATED - 1.00 HP...
Removing pool pump impellor from motor shaft
Separate pump and motor. Remove diffuser. Remove back cover from motor. Motor shaft has either a slot for a screwdriver or a flat area for a wrench. Hold shaft and unscrew impeller.
Feb 24, 2010 | AO Smith A O Smith Motors Century 1hp 115v...
May 01, 2009 | Pool & Spa
Pool & Spa Logo
91 people viewed this question
Top A O Smith Motors Pool & Spa Experts
Jay Finke
Jay Finke
Craig Butler
Craig Butler
Steve
Are you an A O Smith Motors Pool and Spa Expert? Answer questions, earn points and help others
