Question about Garden
Gas build up in chamber to point it won't turn over
I have gas leaking out of the bottom of the carb and I have so much gas in chamber that the engine won't turn over. I pulled the spark plug out and flushed gas out of chamber, put the plug back in and it starts right off. I have a fuel solenoid and I was wondering if this could cause this problem. I had a previous solution that the needle valve in the float wasn't stopping the gas flow. I was wondering which would be a more likely solution. Any info on the matter would be greatly appreciated.
  • Garden Master
  • 2,478 Answers
Put a fuel shut-off in line as it leave the tank. I had the same problem.
Posted on Jan 03, 2014
4 Suggested Answers
redbeard00
  • 957 Answers
SOURCE: Craftsman GT5000 W/22hp B+S surges and dies when warm
Replace the spark-plug, check the quality of the fuel(gas that is mixed or was stored more then three months is stale and wont fire correctly) make sure the fuel and air filter not clogged. If there is no change then your problem may be more technical, a nest may be restricting the govenor or you missed something with the carb and there still is debre causing it to stall.
Posted on Apr 24, 2009
  • 376 Answers
SOURCE: I have gas going into my oil. 17.5 Briggs solenoid on carb bowl
The problem is the float needle and seat are leaking. It is not shutting off the gas when the bowl is full. The bowl fills up, then runs down the intake through the intake valve into cylinder, past the rings into the crankcase. Fairly common problem. Just replacing the rubber tipped needle probably will not stop the leak. The pressed-in brass seat needs to be pulled out and a new one pressed in also. Possibly there is some trash or rust in the carb that has gotten between the needle and seat, but in my experience, it usually takes replacing both to fix.
Posted on Jun 25, 2009
backwoodsctr
  • 169 Answers
SOURCE: DLT 3000 Intek 18.5 Carb Float Stuck?
If it starts cold and runs for 10 min then it sounds like the fuel cap is not venting properly, try runnin engine with fuel cap loose and see if it dies. 9 times out of 10 the fuel cap is the culprit. Let me know
Posted on Nov 30, 2009
Leaking gas into engine
If the carburetor is dripping gas into the engine, the float may have sunk or the needle valve may have worn out, and be leaking. You may be able to clean the needle valve at the top of the float chamber in the carb.
Jun 08, 2015 | Briggs & Stratton Garden
Gas leak threw bottom of carb and building up in cylinder
Pinch the fuel line then take the carb bowl off then reopen the gas line and press the floats upward and see for yourself if they are shutting off the flow.
Jan 03, 2014 | Garden
2001 Triumph Legend TT engine oil flooding with petrol
Hi, Malcolm you're getting ready to go riding you pull out the dipstick to check your oil level and are greeted with the unmistakable smell of gasoline. What happens next depends on the following:
1. You have experienced this before and do not start the engine but do change your oil and filter leaving it 1 quart low until the engine reaches operating temperature then top off as necessary.
2. The amount of time your bike has been sitting since the last time the engine was running.
3. The amount of gas and contaminants in the tank.
4. The oil pump location, exterior or interior.
5. The condition of your petcock gasket/seal/diaphragm.
If your gas tank was low and you start the engine probably nothing you would notice but if your gas tank was full and you start your engine the oil/gas mixture can blow into your air filter, come streaming out of your crankcase breather hose, and launch your oil tank cap followed by a blast of oil. The mess can be minor or you need to call a Hazmat team for assistance. This will also happen if you overfill your oil tank.
Next is the how and why gas can get into your oil tank/system:
a. The vacuum petcock rubber/diaphragm fails, which allows gas to flow from the fuel tank through the petcock, through the vacuum line into the intake manifold, then into the combustion chamber, where it seeps past the piston rings and into the bottom end.
3. Nonvacuum petcocks that are not turned to the off position will patiently wait until contaminants from the gas tank build up in between the carburetor needle and seat breaking the seal thus inviting gas to enter the combustion chamber eventually finding it's way into the bottom end and the oil tank.
4. Bottom line if you're not going to ride your bike for a while turn off the petcock.
For more information about your issue and valuable "FREE" downloads that you will need please click on the blue links below. Good luck and have a wonderful day.
Legend leaking lots of fuel from airbox Problem Solving Tech Forums...
gas in oil
Triumph Thunderbird Service Manual
Hermys Tire Cycle Inc 2001 Triumph Legend TT Genuine Motorcycle Parts in...
Triumph Thunderbird Owner Manual
Jul 05, 2017 | 2001 Triumph Legend TT
90HP Yamaha won't turn over
It sounds like you have a air line busted somewhere i had one of my outboards do that it wouldnt prime for anything so i ran everything down checked the fuel pump and cleaned that out tore apart the carbs cleaned them bought brand new fuel hose still scratching my head i took off the air lines for the carbs and put new ones worked like a champ
Aug 22, 2012 | Boating
2006 Honda Shadow won't start. Gas tank filled. Sat 8 mo. Gas leaked out but not into engine.No sign of external leak. into
1. Drain the gasoline.
2. Remove the carb bowl(s) and turn on the petcock to drain the fuel in the lines.
3. Clean out the carb bowl(s) and replace.
4. Refill with gasoline, add 1 oz of Seafoam fuel system cleaner (I'm not a sponsor, I just haven't found anything better) to each gallon of gas. This will stabilize your fuel as well as do a great job of cleaning out the carb(s).
5. Try to start it.
If it still won't start, begin the standard troubleshooting procedure by first pulling a spark plug and turning it over to ensure gas is getting to the cylinder. If so, replace the plug, hold the plug wire slightly away from the plug and turn it over to ensure a spark jumps between the wire and plug. If so, it starts getting complicated. Buy a manual for the bike if you don't have one and follow the troubleshooting steps there.
Jul 24, 2012 | 2006 Honda Shadow Spirit 750
19e412-0134-01 won't start. gas leaks out air
The float is stuck on the carb flooding the engine and leaking gas out of air filter. Remove the float bowl after the gas is turned of or drained. Thoroughly clean carb And bowl with carb cleaner. Reove the float {very carefully} if it is copper, shake it. If you here fuel in it then it is no good. If not then clean everything and reassemble. If it needs to be replaced, most small engine repair shops will have your parts.
Aug 28, 2011 | Porter Cable BSI550 W 5,500 Watt Generator...
I have a 1991 honda cr 250 I cant get to start at fist gas ran right thru carb and out bottom i took carb apart and got the floats to stop sticking cleaned it out with carb cleaner put back together but...
try a new spark plug. if u fowl out a plug some time they will not fire under compression.2 strokes need. fuel,fire and air, very simple engines.it is possible crank seal are bad .that doesn't allow the engine to create vacuum in the crank case.thus fuel and air will not make it to combustion chamber.
Jul 11, 2010 | 2002 Honda CR 250 R
Coleman 6250 PoweLeaking gas at bottom of motor housing. Can not
The gas is leaking from carb but in the motor not out.
You should check and repair the carb flow valve. The floating unit may be full and bent down.
Jun 20, 2010 | Coleman Powermate Powermate 5000W...
I have a sears lawnmower that was flooded recently. I bought a tune up kit and installed it. I changed the gas and oil also. when I poured in the gas it all came out the air filter. What should I check...
carburator float is stuck in the open position allowing fuel to continiously run / drain out the fuel tank into the carb and then overflow into the venturi of the carb into the engine and out the air filter. Bottom line the carb needs to be disassembled cleaned and rebuilt
Sep 20, 2009 | Craftsman Garden
Carb help
I'm new to the site and new to carbs. I bought a bike last week that had been sitting in a barn for a couple years the engine hadn't been running in over a year. I was able to get it running the first day after cleaning out the field mouse home occupying the air filter chamber and swapping the old gas for new gas. The bike ran and idled fine but the left carb (dual carb setup Keihin) poured gas from the tube coming out the bottom. I did some research and found out the floats may be stuck. I went ahead and ordered new floats and float bowl gaskets. I took the carbs apart apart as much as I could, using Berryman parts cleaner to soak all the metal parts I could get off. I put everything back together and put the new floats in yesterday. I started the engine and not only is the gas is still pouring out the bottom of the left carb, but now the bike is idleing very fast. The idle adjustment is backed out completely. When putting the carbs back together, I screwed all the jets back in all the way. I screwed in the Pilot Air screw, the one with the spring, all the way in, then backed it out 1 1/2 turns. Not sure if this has anything to do with the idle. As far as the floats go, does it sound like I need to replace the float valves too? ,The seats on the jets, or the o-rings on the needle valves that the floats control are probably leaking.,,,
Nov 10, 2008 | 2007 HM CRM F490X I
Garden Logo
26 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
