Question about NetGear DG834G 54 Mbps 802.11g Wireless ADSL Firewall Router w/4-port 10/100Mbps Switch (NTWRNGDG834G)
Netgear DG834G router
Hi .. me facing  issues with netgear DG834G router : ipconfig shows media state media disconnected bith with ethernet connected and wireless : have tried resetting the router to its factory defaults
  • Anonymous Mar 18, 2014
    restore default
    Scholar:
  • 110 Answers
Are you getting any internet?
Are you using Windows Vista?
Posted on Oct 19, 2007
SOURCE:
How do i secure wireless net work its shows local only
Hi if it shows local only means you not connected to the internet and only you can access your network make sure you apply wireless password to make your network secure check the WAN cable which directly connect to your NetGear DG834G Router you can disconnect that directly connected to your laptop and see if you can access the internet should you need any other help please contact me on my weblog http://computernetworksupportindubai.com/
Jul 22, 2011 | NetGear DG834G Router
Hi I'm looking to install a DG834G router to give wireless access but the only instal disc is from AOL and I'm not with them anymore, I have tiscali broadband. How do install the router if it won't plug...
Try NOT using any install disk.
Turn the TISCALI router off.
Turn the NetGear off.
Use an Ethernet cable to connect from the LAN port on the TISCALI router to the WAN port on the router.
Use another Ethenet cable to connect from one LAN port on the router to the network-port on your computer.
Turn the TISCALI on. Wait 60 seconds.
Turn the NetGear on. Wait 60 seconds.
Restart your computer.
Click Start
Click Run
Type CMD
Press Enter
Type IPCONFIG
Press Enter
Look for output like: Default Gateway....192.168.123.456
Note that the '123.456' will be some other numbers.
Start Internet Explorer.
Type http://192.168.123.456 (substitute the current values)
Login to the web-server running on the router.
Run the "Wireless Networking Setup Wizard"
to configure a SSID, an encryption-level (use 'WPA')
and a password for your network.
After the router restarts, you should be able to get wireless access, using the SSID and password that you configured your router to use.
Sep 29, 2010 | NetGear DG834G Router
Wireless Netnotwork Connectivity issues
At last, I have finally resolved the issue, sometimes the solution is so somple that you totally miss the solution. It was as simple as the Windows Firewall ( switch it on ), I have a Mcafee security center protecting my network and it wouldn't let me connect with additional protection. Also, I entered the wrong mac address on the routers (access control) settings. I'm now on the internet. Obviously I have to big up Mcafee for excellent security controls. So if anybody else ever has the same problem follow these simple steps.
  1. Check all of the settings that I described in the original question
  2. Make sure Firwall settings are correct (& active).
  3. Check your routers homepage ( access control truly works).
  4. Make sure you you enter the correct MAC address (use the MAC address of the wireless network adapter, that's what connect you to a network) i.e. 00-01-a2-11-22
May 04, 2009 | NetGear DG834G Router
Have lost/can't remember the security code to wirelessly connect to my netgear DG 834G
Paul.
Can you connect to the router via ethernet?
If so assuming you havent changed the routers address connecting to 192.168.0.1 from your web browser should get you into your routers admin page.
Once you have entered the user name and password click the Wireless link from teh main menu where you will be able to see the relevent key and or change it if required.
If you need the manuals you can download from here.
http://kbserver.netgear.com/products/DG834G.asp
Regards
Nick
Oct 28, 2008 | NetGear DG834G Router
NETGEAR DG834G WAS WORKING FINE THEN WE UNPLUGGED IT, COS THE GUY AT VIRGIN MEDIA SAID IT WOLD HELP IT SPEED UP THE INTERNET TO MY LAPTOP. WHEN WE HAVE PLUGGED IT BACK IN, IT TURNS ON, THE ORANGE TICK...
hi ,
i went through the problem that u r telling me nut i think that the router has gone bad so u can call customer care of ur router and they will replace ur router .....
Oct 25, 2008 | NetGear DG834G Router
LAN ports not working
make sure that the local area connection in the computer is enabled and that the drivers of the ethernet adapter are working properly.
try to reset the router by pressing the reset button for 30 seconds then if the problem still persist then that means the router should be replaced already.
Aug 09, 2008 | NetGear DG834G Router
Netgear DG834G v3 Installation
connect the yellow (or blue?) ethernet cable to your computer, this should connect to the router (router should be ON)
Now, in internet explorer type 192.168.0.1 (this should be the defualt gateway for the router on default settings.
Now you're into the router, there should be a setup wizard button in there.
See if you can set it up using that
Regards
Tony
Feb 28, 2008 | NetGear DG834G Router
Computers & Internet Logo
244 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
