Question about Electrolux 450 Watts DLX-N24 Assistent Stand Mixer
The switch wont stay on - Electrolux 450 Watts DLX-N24 Assistent Stand Mixer
The speed lever won't hold a speed
The spring attached to the speed control switch has come off or broken. Does the switch stay in one place when you move it or does the switch move about freely. I need a little more info to be more help.
Feb 23, 2013 | KitchenAid Classic Stand Mixer
Our switch doesn't stay in off position
you probabley bent the switch lever so the little indent on the lever won't stay positioned in the off detent. probabley need new switch lever. part doesn't cost much .not hard to put in if your mechanicly inclined , if not a repair center can do it for you.
Sep 12, 2011 | KitchenAid 32685 Mixer
Hobart L800 will not stay on unless you hold start buuton
If it has a bowl guard on it then it could be the bowl height switch or the side switch on the contactor. If it does not have a bowl guard then it is more than likely the contactor side switch.Check www.hobartservice.com for your local Hobart office.
Mar 15, 2011 | Hobart D340-6007 Mixer
My mixer wont turn off...the speed lever wont stay in off position so I have to unplug to turn off. Can I take it apart and fix it?
i have this same problem!! mine is less than a yr old. im upset that i paid so much for this problem. love the mixer but dang, this shouldnt be happening.
Oct 05, 2010 | KitchenAid K45SS Classic Stand Mixer
Kitchenaid stand mixer will not stay in the off position.
There is a spring, item #4, which hooks on to the bottom of the control plate, item # 25, and pulls it back when you move the lever to off. Remove the rear cover and see if that spring is still connected to the control plate and to the lever arm, Item # 3. Here is the diagram:
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%208212369.pdf
Mar 31, 2010 | KitchenAid KSM90 Ultra Power Series Stand...
I have brown hand mixer . hand mixer's switch is
Just buy the replacement switch, buy a star or philips
screw driver and do it yourself. Just copy how it is mounted and get it done. Just e-mail to us the result.
Oct 05, 2009 | Braun M880 280 Watts Hand Mixer
Need part for H 600T mixer
I dont think the button is the problem.I suspect the side switch on the contactor is bad.Give me a little more info like when the problem started.
Mar 23, 2009 | Hobart H600 Stand Mixer
Blades won't stay on mixer
if this is new then i would just take it back it may be faulty.
Oct 27, 2017 | Wolfgang Puck Food Mixers
Hobsrt Mixer problem
Its ok to by pass the timer.You can bypass it and the switch will work.Let me get my service manual and ill post back on how to do it.
Feb 20, 2008 | Hobart A200 Stand Mixer
Electrolux 450 Watts DLX-N24 Assistent Stand Mixer Logo
Top Electrolux Food Mixers Experts
Oscar Netto
Oscar Netto
Are you an Electrolux Food Mixer Expert? Answer questions, earn points and help others
