Question about Philips HR1358 Handheld Blender
PHILIPS hl 1643, blender blade not working - Philips HR1358 Handheld Blender
My jug blade of Blender HL-2573 is broken. I need the replacement part. Will you please guide me from where I can get this part.
start with an online search of manufacturer for part or a distributor near you or do a search for the part it self
Oct 10, 2016 | Blenders
I need a blade for jug of model HL-2573
Fixya does not sell replacement blades. Check with a local appliance parts supplier.
Model HR7772. Where can I get a plastic coupler driver?
Check with a local appliance parts supplier and/or Philips to determine availability and source.
Oct 10, 2015 | Philips Blenders
Blender is not working after giving electric supply
UNPLUG it and try to turn the blades by hand. Put a drop of alcohl at the point where the shaft comes through the case and turn to loosen the blade. Next, put a drop ov cooking oil at that same place every time you're finished using it.
Dec 26, 2009 | Philips HR1358 Handheld Blender
My blender seems to spin without the glass blender "jar" in place. Once the blender is put on top, the blade will not spin.
your blade assembly is corroded. take it off, and using a rag, grab the blades. using another rag, grab the other end (probably rubber) and turn CLOCKWISE - it's threaded reverse, so you have to turn to the right to loosen, not the left like usual. I had to clean out the rod that connects to the blades - it was all nasty and corroded. I cleaned it with my Dremel and regreased with a tube of grease I keep in the garage, cleaned all other parts with some Dawn, dried well, reassembled, and works almost like new. I'm guessing I ran it too long without pulsing the motor and the heat corroded the rod that's connected to the blades. OR you can buy a replacement blade unit for about $10 online on a blender parts site
Oct 10, 2009 | KitchenAid KSB5 Ultra Power Work Top...
My kenmore blender stopped blending!!!
There is a gear underneath the blender blade. This connects the blade to the motor found on the base of the blender. This gear usually get worn out specially if the load that we are giving to the blender is beyond its limit. I hope you could by a spare on one of the electric shop near or might as well consider buying a new set.
Oct 06, 2009 | Kenmore Blender Single-Speed Blender
Where can buy spare parts
I need a new blade aftermarket
Sep 27, 2008 | Philips HR1358 Handheld Blender
Philips Hand blender
My wife picked ours up at a rummage sale, and we've grown to love the little thing for making single servings of banana milk shake. (half a frozen banana, cover with milk, a drop of vanilla, and about one minute with the hand blender blade!) When my youngest boys dropped ours, I gathered up the pieces of plastic that connect the attachments to the motor shaft, and carefully super glued them together. I then wrapped the plastic piece with fine nylon thread and a thin layer of super glue and placed it back onto the motor shaft, then let it sit for 24 hours. It is now permanently attached to the motor shaft and good to go. Too bad Philips doesn't care enough to support their customers with a part their engineers designed to break and save the rest of the product. I'll remember this about Philips products when I buy an HDTV.
Aug 14, 2008 | Philips HR1358 Handheld Blender
VILLA WARE 5767
my blender jar is broken. I need to replace it
Aug 05, 2007 | VillaWare 5787 Double Smoothee Work Top...
Philips HR1358 Handheld Blender Logo
Top Philips Blenders Experts
Ross Keen
lakeareaserv
Tom Chichester
Are you a Philips Blender Expert? Answer questions, earn points and help others
