Question about Watches
Bench watch bc0174slbk
How do i change battery
Battery for relic wet or 15478 and how to remove back of watch
Watch back will almost certainly need a dedicated wrench to loosen and unscrew it. Sometimes considerable force is needed and in that case a watch repairer would remove the strap and fit the watch into a bench-mounted holder.
Once the back has been disturbed the water resistance cannot be guaranteed unless it is pressure tested after refitting.
Jan 23, 2017 | Relic Watches
How do I set the time and date on my bench digital watch
hold the light button until it flash's 12 or 24, then press mode which will change you on to the time, date, ect then fiddle around with the start and reset button to toggle with the time and date. when your done with the time press light again.
Nov 26, 2015 | Watches
W to changebattery #65041g
Changing the battery on most watches is fairly straightforward and needs only the usual tiny screwdriver, insulated tweezers and a large measure of patience and good eyesight.
The main problem is usually opening the case and in the case of a quality watch that is guaranteed waterproof it really should be returned to the manufacturer for battery fitting and pressure testing. If testing isn't carried out after the case has been opened the watch realistically then becomes merely water resistant rather than waterproof.
Usually it is the back of the watch case that must be opened and in the case of ordinary non-waterproof and non-water resistant types it is a simple matter to prise the back off with a thin blade and then refit it with finger pressure.
Water-resistant watch cases that have a priseable back often need the back pressing back on with force supplied either by a purpose-made press or a large bench vice. In both cases adapters are needed to prevent damage to the case and the crystal.
A lot of watches have a back that unscrews and strictly a dedicated key, wrench or spanner is needed for this task. I have managed to overcome this problem a number of times by pressing other tools "that look as if they might do the job" into service. I cannot say what it was I used as I wandered around my workshop just trying things. I think the last time a particular circlip plier did the trick.
Simpler to take the watch and have someone else replace the battery I think.
Feb 20, 2015 | Timberland Watches
Bench bc0051 time set instuctions
Shortcut battery with AC contact. AC can be found on the sides of watch movement(very tiny). You have to use pointed tweezers: one end on battery+, another on AC contact for three secs
May 21, 2013 | Watches
How to set time on Bench Gents LCD Strap Watch
How to set the time on a bench digital watch Bench BC0013BR
Oct 26, 2009 | Watches
Reset time on bench watch bc0013br
I have a Bench Watch BC0013BR and do not know how to set it up any help would be appreciated
Oct 05, 2009 | Watches
Bench Watch BC0013BR display problem
There may be two batteries in your watch - one for backlight and another for movement. Check this out at your nearest watch repair shop and replace if needed. Alternatively you can do it yourself if you have knowledge and skills.
Rate, please.
Jul 21, 2009 | Watches
F55 watch is frozen and cannot get back to main
HI dyer_christi
Most of these watches hold there memory whilst the batteries is still in. Unfortunately the best thing to do is to remove the battery and reset all data! I know this means you loose the hard work you have done, but I do not know of any other solution? Are you capable of changing the battery or would you like some help? I can provide additional assistance with this if you'd like. You need a small philips head screwdriver, some small tweezers and a clean bench with a few mins (say 30). if you'd like I'll help you through
Jul 15, 2009 | Polar F6 Wrist Watch
Setting the time on a bench watch
hi i had the same problem but i have just found the answer. hold the light button until it flash's 12 or 24, then press mode which will change you on to the time, date, ect then fiddle around with the start and reset button to toggle with the time and date. when your done with the time press light again.
Oct 16, 2008 | Watches
Watch battery cover
You will need a special tool to pop it back on. Any other way will result in the crystal breaking.
Aug 04, 2008 | Kenneth Cole 1213 Wrist Watch
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
