Question about Vehicle Parts & Accessories
Ford transit problems
Engine runs intermitantly
    New Friend:
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
  • 54 Answers
Check for ground and ecu related issues ignition as well
Posted on Jan 05, 2014
Would my 2.4 2003 diesel ford transit engine fit my 2.4 2010 diesel ford transit
some of the vital parts are different e.g. pump, injectors, ecu, so may not run
Jan 22, 2018 | Ford Cars & Trucks
My Ford Transit Diesel 2007 (camper van)intermitantly loses power and the Engine Malfunction light comes on. If I stop, turn off the engine and restart it a few minutes later everything goes like a ch
When the engine is under load it uses more fuel then normal .First replace the fuel filter then check the fuel pressure and flow. the pressure and flow are checked with gauges. For a rough check remove the return pipe from the fuel rail, if fuel is flowing there the fuel system should be ok providing the pressure valve is not stuck open. if there is no flow there the pump may be at fault.
Nov 13, 2014 | Cars & Trucks
2010 ford transit connect 150,000 miles great shape runs and shifts ok but when decelerating there is a whine in the trans??? it has the advance trac rsc trans what could it be
I'm going to say it is a main shaft bearing that is wearing out, much like a differential or axle bearing.
You might do some online research for that model and see if it is a common problem with other owners.
Sep 23, 2012 | 2010 Ford Transit Connect
2005 Ford Transit not starting. Battery fully charged,engine turning over ok. Heater plugs ok and engine getting fuel. Anyone know what it might be. Engine relay problem maybe????
I have difficulty in starting my 2005 Ford Transit during the cold weather.There is no problem during normal temperatures.Are ther engine cold start heaters and where are they positioned on the engine.
Oct 27, 2010 | 2001 Ford Focus
Transit 2.4di starts then cuts out straight away, been plugged in, the fault code is po149 fuel timing error. the problem is intermitent, sometimes runs fine for days.can you help?
Hi if it is a non common rail engine the common cause is the cam chain will need replacing i have replaced many of these for that very reason
Apr 01, 2010 | Ford Fusion Cars & Trucks
1988 Ford F250, 4.9L engine. Runs sluggish
EGR is maybe stuck open. disconnect the vac hose at the EGR valve and see if the idle smoothes out. If the EGR is sitcking open, thats a vac leak. If that fixes it, replace the EGR solenoid valve.
Jan 28, 2010 | 1995 Chevrolet K1500
Instruments on dash cutting out intermitently
Check the temperature sensor under hood far a short. Common problem with this car.
Nov 16, 2009 | 2004 Ford Focus
Ford transit lock problem
i, i get this all the time, had lots of old transits. get as many ford keys as you can borrow friends from escort mondeo transit, these locks are **** some 1s key will open it, when doors are open u have to remove locks and soak them in oil leave under engine oil all night, fixes ur prob.
Feb 08, 2009 | Code-Alarm Code Alarm Transponder
Ford transit van dashboard display not working
ive got a 55 plate 85 T260 swb crewcab 68000 miles, , i bought it 12 months ago, red light flashes on dash board most days, some times arratically, sometimes quite slow, and all clocks, speedo and dash does not work?????????
the smallest scratch and the van rusts, no under seal, there just a use it and dump it van.
i would just like to say fords are ****
Dec 27, 2008 | 2003 Ford Escort
Vehicle Parts & Accessories Logo
44 people viewed this question
Top Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Are you a Vehicle Part and Accessory Expert? Answer questions, earn points and help others
