Question about Sony CDP-CX53 51-Disc CD Changer
All discs skip. what is a good lens cleaner for this model ?
2 Suggested Answers
  • 92 Answers
SOURCE: my laser in my stereo
keep cleaning it
Posted on Mar 16, 2011
Won't play, just keeps skipping discs
Good morning Lori.
My troubleshooting thoughts run something like this:
  1. It sounds like it's skipping on every CD.
  2. This is (according to the manual Denon DCM 390 Operating Instructions Manual Troubleshooting a cauousel-type system, so it has a tray that you manually place CDs into, rather than a cassette that you put all the CDs into and then insert into the player.
  3. Most of the manual Troubleshooting section puts the blame for discs not playing upon dirty or damaged discs - you're told to re-load it, clean the disc, try another disc.
  4. If this is just one set of discs, then it's worth it to pull out at least a couple and try other discs that are clean, don't have scratches, and, hopefully, that you know work on another player. If they work, then, kudos to the manual, the discs may need cleaning or replacement.
  5. If you're playing home-burned CDs, you may need to finalize them for play. Computer CD burners can often give you a lot more leeway in what they're willing to play, since there is a much more sophisticated bunch of code running the burner that will have some expectation that in-process discs might end up there.
  6. Last, but, IMO, most likely - steady skipping on every CD can mean that the CD laser lens is dirty. Over time, dust on CDs or from the air drawn through the chassis can build up on the lens, which has a fairly small gap from lens to Disc surface. In something like a DiscMan or other portable CD player, the lens is usually pretty obvious and can be blown off with some canned air or brushed with a micro-fiber camera lens cleaning brush. In this case, it's what I suspect is the problem. Depending on what gear you might have, or how much you'd want to spend on it, what I'd suggest to try fixing this possibility would be :
    1. Use a commercial CD Lens cleaner. They'll likely run 6 to 10 dollars. A list here Amazon com cd lens cleaner Electronics has lots of possibilities. You'll want one of the ones that looks like a CD with a small brush attached to the bottom, possibly some fluid. You'll put it in the player, hit play, it'll at least attempt to play for like 5 to 30 seconds, and end. The brush will be spun past the lens multiple times, removing dust / gunk buildup.
    2. Use canned air. I'm talking commercial stuff expressly meant for cleaning computers and other gear that will suffer from a blast of oil-laden air from a garage air-tool compressor. Examples here Amazon com canned air Electronics
    3. Open the system up. I can't give too much guidance other than I did it years ago on my system - make sure it's unplugged before starting. Remove screws attaching black cover to chassis, and you may be able to get in with a brush to clean the lens. Don't go this direction unless you're confident of your DIY skills.
    4. In any case, try to stick with dry cleaning methods like the cleaner disc or canned air. If you do anything with direct contact, stick to clean microfiber cloth or brushes, and be gentle - no scrubbing motions. It's a tiny lens, and a scratch or mis-alignment from forceful handling will be the end of it. If a liquid must be involved and isn't part of a commercial kit, nothing but distilled water. Many, if not most, of the CD lenses are molded plastic, and glass cleaners, likely as not, will attack the lens surface and roughen or fog it.
  7. Last note - the reviews on Amazon for this unit are not kind. It sounds like the skipping and failure to play is not uncommon with this particular Denon model. If the unit is still under warranty, I'd grab the opportunity to have someone fix it for real and deal with any faulty mechanisms. If not, you have little to lose with the above, but the reviews suggest that replacing with the same model might not be the best idea.
Good Luck, and Happy Holidays
D
Dec 09, 2015 | Denon Home Audio Dcm-290p 5-disc Auto Cd...
CD player skipping
Make sure the unit is mounted level and not to secured that its pinching down on the unit
Jul 23, 2012 | GE 7-5295 Undercounter DC /Radio Combo -...
The DVD skips about half way through a program. The same DVD works fine in our desktop computer. Can this problem be fixed? If so, how?
If it is a dvd copy of something, or was made on a computer...some dvd players have a hard time reading the disc consistently. Try with a normal store bought dvd, and see what happens. Also, the lens could use a cleaning. A good thing to have is a cd/dvd lens cleaner disc. hope this helps
Apr 02, 2010 | Zenith DVB216 DVD Player
DVD GO FORWARD BY ITSELF
Do you mean DVD jumps / skips forward in playback?
If yes, please clean optical laser lens in player. It sounds optical lens has thin layer of dust and causing ' tracking error ' in playback.
Put CD Lens Cleaner disc in player and press play to clean optical lens by cleaning disc and if problem still exist, need to clean lens manually with good quality cotton bud.
Hope this will solve your problem.
Thanks.
Sep 08, 2009 | Samsung HT-Q100 System
The CD's skip. I tried 7 different CD's in all of
buy a lens cleaning disc for the cd unit you may have a dust build up on the lens inside the cd unit.. if you are tech savy you can take the unit out take the cover off and clean with a soft cloth and some glass cleaner..
Aug 06, 2009 | Audio Players & Recorders
Plays cd's but lots of skipping going on. I tried cleaning with a CD player disc cleaner that I got today. That didn't help. None of the CD's skip in another machine. Thanks!!
When optical lens got dusty or thin layer of dust on lens, cd starts skipping, as you tried cleaning with lens cleaner cd but no result.
You need to open the unit and clean the lens with good quality cotton bud / swab with care.
Still no joy, replace optical lens.
Oct 10, 2008 | Sony XPLOD CDX-GT200 CD Player
CDA-9855
Try lens cleaner first, always the best idea. If it makes a clicking sound when trying to read the discs, you're looking at a bad optical pickup.
Oct 24, 2006 | Alpine CD Player CDA-9855 LIMITED QUANTITY...
Cd's skipping
Try first to clean the lens with a lens cleaner disc. or cleaning the lens manually. if that does not help, then im afraid the unit has come to the end of its usefull life. and is time to get a new one . Good Luck
Oct 05, 2006 | Panasonic SC-AK110 CD Shelf System
Sound skips alot while playing dvd
skipping audio or video on a cd or dvd is generally caused by a dirty lens or a bad disc. . Try a lens cleaner disc and get back to us ?? Thanks Good Luck
Jun 28, 2006 | LGDVT418 System
Sony CDP-CX53 51-Disc CD Changer Logo
52 people viewed this question
Top Sony Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Sony Audio Player and Recorder Expert? Answer questions, earn points and help others
