Question about Uniden D3097 Loud & Clear Expandable Cordless Phone
Cannot turn handset ringer back on. Do not know how it got turned off.
SOURCE: how do you turn the ringer back on a V-Teech 5.8 phone
Snowbird woman is right. Push the talk button. Push the end button. Push the up arrow. This will get you into the ring tone volume menu. One of the options will be "off" or on for the ring tone. Keep cycling through it until you turn it back on.
Posted on Jun 21, 2008
SOURCE: Ringer turned off
You have probably solved it by now. Just turn up the volume with the ^ button. :-)
Posted on Sep 19, 2008
  • 84 Answers
SOURCE: uniden 5.8 ghz phone. Can you turn the ringers off and how ?
On most of the phones you just keep pushing the volume down button untill it turns off. On some models there is a "Do not disturb" feature, usually it is a soft key feature so look on the LCD screen. Also, for the person that can't turn the ringer back on, just push the volume up key untill the ringer is at the level you like.
Posted on Mar 24, 2009
SOURCE: ringer was accidentally turned off. How to turn on ringer.
I found a free online owners' manual and read it. Thanks, though.
Posted on Apr 15, 2009
SOURCE: the ringer is off and I don't know hoe to turn it on
I have two uniden phones 2.4 GHz and the ringer is turned off and we cannot figure out how to turn it back on again. Please help!!!
Posted on Jun 24, 2009
How do I turn the ringer back on my panasonic cordless phone #kx-tga402
Go in to the settings on the handset, look for ringing or ringer and turn the tone from off to on.
Dec 13, 2014 | Panasonic Lands Phones
How do I turn the ringer back on.
You just press the up arrow until you get the volume you desire.
Jun 17, 2014 | Uniden D17602 D1760-2 D1760 2 DECT 6.0...
Somehow the ringer got turned off. Can't figure
Adjusting the Ringer, Earpiece and Speaker Volume
Adjusting the Ringer Volume
You can choose from four ringer volume settings (off, low, medium, and high) separately on each handset or the base.
With the phone in standby, press or on the handset or VOLUME or VOLUME on the base. The handset or base sounds the ringer at that level.
Use on the handset or VOLUME on the base to make the ringer volume louder. Use on the handset or VOLUME on the base to make it softer or turn it completely off.
When you hear the ringer volume level you want to use, stop pressing keys.
The handset or base will use the new ringer volume starting with the next incoming call.
Note: If you set the ringer volume to Off, the handset or base won't ring. Other handsets or base will ring according
to their individual settings.
Muting the Ringer (One call only)
While the phone is ringing, press /Mute or END on the handset or on the base to mute the ringer
Sep 12, 2011 | Uniden Lands Phones
Can i turn down the base ringer (or turn off) on my vtech dect 6.0?
Welcome to FixYa!
The base ringer is dependent to your handset ringer. If you lower the volume or turn off the handset ringer, the base ringer will follow.
Thank you for using FixYa.
Have a great day.
Jas247
May 17, 2011 | Vtech Cordless 6041 Phone
KX TGA244B How do I get the ringer back on
Handset ringer volume
4 levels (high/medium/low/off) are
available. The default setting is HIGH.
1 Press {MENU}.
2 Scroll to “Ringer setting” by
pressing {V} or {^}, then press {>}.
3 Scroll to “Ringer volume” by pressing
4 Press {V} or {^} repeatedly to select
the desired volume.
LTo turn the ringer off, press {V}
repeatedly until “Off ?” is displayed.
5 Press {Save}.
Note:
LWhen the ringer volume is set to off, the
handset will display “Ringer off”, and
will not ring for outside calls. The
handset will ring at the low level when
paged by the base unit.
Jan 05, 2010 | Lands Phones
How can I turn the ringer back on? Thank you
1 Press (MUTE/FUNCTION).
pressing öor ñ, and press á.
3 Press áat “Ringer volume”.
4 Select the desired volume by
pressing öor ñ.
•Each time you press öor ñ, the
volume will change and ring.
To turn the ringer OFF:
press örepeatedly until “Off ?” is
displayed.
5 Press á(Save key).
•A beep sounds.
To turn the ringer ON:
Press ñin step 4.
•The ringer will sound at the LOW level.
•You can exit the programming mode any time by pressing (OFF).
•If set to OFF, “Ringer off” will be displayed while the handset is not in use.
•If you have received new calls, “Ringer off” will not be displayed but
“Received calls” will be displayed while the handset is not in use.
“Ringer off” will be displayed for about 5 seconds after completing operations
or lifting the handset from the base unit or the charger.
•You can also select the ringer volume while an external call is being received.
Press öor ñwhile the handset is just ringing.
•You can change the ringer tone for external calls. See page 49.
HIGH
MEDIUM
OFF
Ringer volume
Low High
Ringer volume
Off ?
LOW
ñ
ñ
ñ
ö
ö
ö
V.M. access
HRinger setting
Initial set
HRinger volume
Ringer tone
18
LCD
Oct 26, 2009 | Panasonic KX-TG2352 Cordless Phone
Ringer turned off do not know how to turn on. Phone is GE DECT 6.0, have 2 handsets and both turned off at same time for no apparent reason.
I'm not sure if it was the solution or just coinsidental that I replaced the handsets in the base, and unplugged power source and phone lines for
just a minute and then plugged them back in and the ringers came back on. I don't know for sure but we have had a frequent problem losing dial tone with these phones and it is the same thing we do to correct that problem.
We have Charter cable bundle package for phone service .
Aug 23, 2009 | GE 25932 Cordless Phone
My son turned off the ringer on our uniden portable phne and I cant figure out how to turn it back on. Chris
Pick up the handset and underneath the handset is an off on switch for the ringer
Handset ringer switch
This switch turns the handset
ringer on or off.
Page 20 of the manual
EXAI985HS English 2,578 kB Product Details
Apr 17, 2009 | Uniden Cordless Phone EXAI985
KX-TG6052 two handsets. Can't get Talking-Caller ID to turn off!
to turn the talking caller id off go to the menu press 0 then * then 4, then press 0 again to select off.
to turn the ringer on the handset back on, go to the menu, prees 1, 1, then press 1 for a low ringer, 2 for medium and 3 for high.
Mar 15, 2008 | Panasonic KX-TG6052B Phone
Turn the ringer off
To turn off the ringer on my Vtech cordless phones, I have had to turn off the base ringer & all handsets.
Base Ringer:
Press Menu and listen carefully, continue to press menu until you hear "Base Ringer, to change base ringer press change", hit change and it will say "Off", then you must hit the PLAY/STOP button to save your change.
Handset:
Press the program button and use your "up/down" key to cycle until you see the Ringer selection. Press SELECT and then use your "up/down" key(s) to cycle until the OFF selection is see on the handset screen. Press select.
Jan 17, 2008 | Lands Phones
Uniden D3097 Loud & Clear Expandable Cordless Phone Logo
12 people viewed this question
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
