Question about RCA L32WD22 32 in. LCD HDTV
Color problem how do i adjust rhe RGB setting to reduce red overcast
  • 47 Answers
If ur saying abt the graphic setting thn u can graphic properties, if it is not thn u can change it frm the monitor control option. to make normal RGB
Posted on Jan 04, 2014
Perblem lg37lb1r has a color very often the color of green blindon
You can adjust the green temperature at the color RGB adjustment.press the menu button then choose the video adjust then scroll down to RGB setting RGB stands for RED,GREEN AND BLUE..adjust it according to your preference..
Apr 06, 2012 | LG 37LB1R 37 in. HD-Ready LCD Television
Sony kdl55nx720 picture settings
Your are the one that knowing the best settings for your TV..To adjust the picture make it sure that all colors are appear like RGB red,green,blue on your screen to easily set the best picture,,..
Dec 28, 2011 | Sony Televison & Video
I have a red tint to my tv?
If you have RGB color settings adjust either green and blue higher or drop red lower, if this doesnt fix the problem than that means you have a problem with the colors/lights going out inside the TV
Jan 11, 2011 | Hitachi 60V710 60" Rear Projection HDTV
I have ATT U-verse, (it's own remote). Using the LG remote, I try to adjust color, too red and too green, otherwise, BEAUTIFUL!! Now, it lets me look at brightness, contrast, but not color, just skips...
You will have to access the service menu. From it, you can reduce the luminance of the red and green bands.
To enter the menu, press the menu button the TV panel and hold it down then press the menu button the remote simultaneously.
In a few seconds, you will be prompted for a 4 digit password.
The password is 0000. Enter it with the remote.
There are two menus that will alternate upon entering it with this method, which one comes up depends on the last time the service menu was entered if it ever was.
You can navigate the menu with the remote. Find the selections labeled for R G B. This stands for red, green and blue. There will be more than one input available for these selections, make sure you select the input that your ATT-U-verse is connected to by toggling through the menus.
Adjusting your red and green;
After finding your proper input and your adjustments for RGB with that input, toggle down to the selections labeled as RGB gain. Reduce the numbered value by 2 or 3 points for R and G and press enter on the remote. Then press menu. This will return you to your input currently use, preferably the input you are adjusting. Using the same picture every time, such as a freeze frame picture that was not to your liking, repeat this process until you are satisfied.
Keep in mind that all colors will interact together. If you find that after making the R and G adjustments together tends to make your red tones appear to be too muted or more of a purple hue, return to the service menu as I described above and reduce the B (blue).
Going by eye is quite inaccurate but however; for a picture that isn't far off from your preference changing these values by only few points in the Gain channel will not make any drastic differences.
For a more accurate picture for your input in question, I recommend a monitor calibration tool such as the Spyder 3 TV. You could alternatively use a DVD based software such as Avia, but that is for your DVD input...in that case you could simply use the settings from that calibration for your other inputs by manually copying them and that may work too. The Spyder is my best consumer based recommendation short of a professional calibration for your ATT U-verse input, the DVD is second but both are much much better than the naked eye.
Dec 03, 2010 | LG 50PG20 50 in. Plasma HDTV
Its glittery white because i briten the color but when darken it gets green
you must re-adjust in the RGB (Red-Green-Blue) setting. depending on the brand of your TV, because there are set manually from the TV (you must open the cover of the rear of the TV). and there is a set directly from the remote only, with the open "factory settings", then you can re-adjust RGB color, especially green, not too dominant with the other colors (RED-BLUE). how to set is that you need to neutralize the color, (color TV sets to zero level) so that the image becomes black and white. if the green is too dominant, then Decrease the level of Green Bias or Green Cut off/ G-drive.
Aug 05, 2010 | Televison & Video
Viewsonic VA2012WB monitor too much red color
I hope there's nothing wrong the the RGB circuitry. Here's what i recommend. degauss, recall the monitor. There's also a temperature setting for the monitor. Change it to COOL or NORMAL.
Mar 15, 2009 | ViewSonic VA2012WB Monitor
50 inch samsung tv has red tint n dis colored
Hi
please try to reset the color settings then hit the tint color adjustment, if nothing change, you have a problem with the RGB Section that is need to replace some small parts!
Thanks!
Jan 14, 2009 | Samsung DLP HL-P5663W 56" TV
I need the color adjusted
1)Remove rear cover..clean RGB lens with soft cloth....
replace cover...........
2)Remove front speaker grill & access panel.....
locate RGB screen control block.....slighty adjust RGB
for best color mix.......check B/W tracking by reducing
customer color control to minimum....does pix look gray ?
touch up RGB screen again.....then increase color to middle
of range.....how is that ?......................................T.
Feb 21, 2008 | Televison & Video
Samsung monitor and mac os
Please do not adjust RGB unless you know what you are doing.
For critical color work, you will need to use a photospectrometer and calibration software to analyze what your monitor is spitting out.
There are a million obvious reasons you should not trust your eye making arbitrary RGB adjustments off the hip.
Feb 15, 2008 | ViewSonic VX2255 Monitor
Monitor Coloring
Well most monitors come with 2 preset color temperatures and the option to customize it(the rgb setting). Your monitor has them as well 6500K or 9300K. 6500 is more reddish(like outdoors) and 9300 is more a bluish white(like a tv, i like the 9300 more). How u said its red and bright, what i would do is set the 9300 preset and if its still too red the customize the RGB by lowering the red. and If too bright then Lower the brightness(Press down on BRIGHTNESS CONTRAST page). If you don't have the manual you can download the full manual from LG's download site here: http://www.lge.com/support/manual. If you see that you can't get it just right,then the monitor might need adjustment from inside and you should make a qualified technician open the monitor and adjust that for you. Hope this was helpful.
Apr 26, 2007 | LG Studioworks EZ-FLAT E700B 17 in.CRT...
RCA L32WD22 32 in. LCD HDTV Logo
21 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
