Question about Samsung DLP HL-P5663W 56" TV
Freezes and sometimes picture disappears. Switch if off and then on again, same thing happens a few times, eventually it will correct itself. Sometimes it is then ok for hours until I switch it off and then the problem continues. The problem doesn't seem to be consistent though. Today when I first put it on was fine and it stayed that way for ages, switched off and then later when put it on the same problem returned. It is definitely the tv and not the cable box
    Top Expert:
  • Samsung Master
  • 34,743 Answers
The internal power supply could gradually failing.
Posted on Jan 03, 2014
4 Suggested Answers
SOURCE: Tv won't stay on
MY SAMSUNG 27# MODEL TXT27820 ONLY NINE MONTHS OLD SHUTS OFF BY ITSELF AND WILL NOT START AGAIN
Posted on Sep 13, 2008
SOURCE: DLP HL-R5067W
Your model has a maximum resolution of 720p. What you might want to do is make sure that both your cable/sat box and game stations are outputting at no more than 720 resolution. It's easy to assume that all HDTVs may accept a higher signal, and while they might, some of the scene changes or handshakes may make that operation cause the symptoms you describe.
Posted on Jan 27, 2009
  • 89 Answers
SOURCE: switch off & on
have y ou check the sleep timer some tvs have an auto off timer under tv settings
Posted on Jul 28, 2009
Tv stays on standby when switched on, then switches itself off after a minute or 2. Then may show a picture after several attempts to turn on, but will turn off again after a few minutes. It does...
I would suspect this has issues with the power supply, I would put it down to faulty capacitors, take the back off and look on the power supply for domed shaped capacitors, they may also leak a brown liquid like substance.
Replace these and all should be ok if it is capacitor related.
Mar 05, 2010 | Televison & Video
Just bought a Sony XBR9 and Comcast gave me a Motorola DCT6200 box which has a DVI output to a HDMI input into the TV. When switching from a HD channel to an analog or digital channel, the picture is...
I am having the exact same issue. It started happening within the first few hours of turning on the XBR9 for the first time. I also have a Motorola box from Comcast. This did not happen with the HD TV that was hooked up previously. Did you return the TV?
Jan 07, 2010 | Arris DCT6200 DTV Receiver
Freezes on the 'Rebuilding...' screen.
The same thing happened too me about six months ago after about a year and a half of using my zen with min. problems. It would freeze on 'Rebuilding..' and then there was an endless cycle of reset but eventually it would Rebuild completely and all my music and information was fine. It seemed to be playing fine but if it froze I had to start the reset game all over again. Then the real problems started. There are a few load screens before you make it to the Rebuild and it started to freeze on that instead after awhile. I was actually revealed when I froze on 'rebuilding..' and made it that far.
If you can get it into recover mode and reboot it seems to have less problems freezing but that doesn't even work for me anymore. Then occasionally when it freezes it starts to vibrate terribly and make a horrible sound. Then it stops and flashes hard disk problems.
This all happened slowly too me. It really wasn't worth the time I put into it trying to fix it. My advice is to work on getting a new MP3 player. If you can get it past the 'rebuilding..' your going to have to play the reset game every time it freeze and it will probably freeze more often.
Aug 21, 2009 | Creative Labs ZEN Vision:M Digital Media...
After i've turned on my computer, and used it for about 5 to 10 minutes, the computer freezes and i have to turn the computer off. when my computer freezes my mouse usually does not freeze. sometimes i'll...
You can start by uninstalling the program you installed before this started happening. You can also do system restore which you'll find in start>accessories>system tools.
If nogo, try disconnecting devices on the back of the computer except the keyboard, mouse, monitor and power. Turn the computer on without them. If the issue disappeared, reconnect what you unplugged one at a time until you find the culprit.
Nov 05, 2008 | Computers & Internet
Zigzag lines in picture when first turning on the tv
possoble cold solder connections breaking when unit is cold they expand when hot thus making connection.
Oct 11, 2008 | JVC AV-27530 27" TV
Sony ke-p42m1
dunguard, How long have you had this for, zazwpx
Jun 04, 2007 | Sony KE-P42M1 42 in. Plasma Television
Shrinking picture
All symptoms indicate a problem in the vertical circuit,the first thing to look for will be loose conection on the vertical output IC,sometimes this IC goes bad completly and it needs to be replaced.If you are familiar with soldering electronics you can take care of it but if you are not too familiar you can play it safe and take it to a servicer ,it will be a lot less expensive than if they come to your house.Let Us know how it goes or if you need more information.
Oct 26, 2006 | Quasar SP-2722 27" TV
Samsung DLP HL-P5663W 56" TV Logo
Henry  Thomas
Henry Thomas
Jerry Greenberg
Jerry Greenberg
