Question about Kenmore 31 cu. ft. French-Door Grab-N-Go Bottom-Freezer
Had a power outage for a few seconds, the control panel is not working on my refrigerator, it reads er lf.
I have tried pressing and holding the unlock key, however, there is nothing functioning on the control panel.
  • 468 Answers
This error means some thing is wrong with the fan to the ice maker. It might also be a bad control board. If it is still under warranty get he board replaced. Kenmore has had some problems with these particular boards. You make be able to reset board by unplugging unit for a while and plugging it back in. Hope this helps
Posted on Jan 03, 2014
Refrigerator GTH18IBXWW Control panel lights not illuminated (refrig and freezer settings and read out). This after a power outage.
Unplug it and see if it resets after you wait 5 minutes and plug it back in. If the outage was caused by a surge, it may have damaged the control board.
Dec 22, 2015 | GE 18.0 Cu. Ft. White Top-Freezer...
Ok, upright freezer, frigidaire, read -12 after power outage but working ok..when I tried to reset temp to 0, light went off, freezer went off, front display reads 56..any ideas?
Thank you for your post, Cynthia!
Based off the information you have provided your Frigidaire freezer is not cooling properly and is now displaying the temperature of 56. It sounds like your freezer is not on, even though it has power the compressor is not turned on. I would suggest pressing either the down or up arrow three times within five seconds. That should power on your compressor and it should start cooling properly. I hope this is helpful and if you should need further assistance please feel free to reconnect. -Matt
Feb 28, 2015 | Frigidaire Freezers
How to reset a samsung refrigerator model number rs261mdpn aftthea power outage
http://www.searspartsdirect.com/partsdirect/part-number/Samsung-Parts/Refrigerator-Parts/DA41-00669A/0046/401/Model-RS261MDPNXAA/1482/0165000
this is the control board you will need for your model if unplugging the unit for 5 minutes doesn't fix the problem. If they are LED lights, then I point my finger at this. This is a plug and play board with molex connectors. Very easy to install with unit unplugged. You can manually reset the display and check for error codes by holding the top left and top right button on your user interface for 5 seconds in unison FOR 5 or more seconds after all the lights flash.
Feb 01, 2015 | Samsung 26.0 cu. ft. French-Door Bottom...
I have a samsung Refigerator RF4287HABP that has an error code SE after a power failure. What should I do.
According to Samsung Customer Support SE stand for Sensor Error... after a power outage... so follow the same procedure as 1e (holding the save energy and lighting button for about 6 to 10 seconds.)
Jan 02, 2015 | Samsung RF4287HABP 28 cu. ft. 4-door...
Power outage-- how do I start up
Look for the button with the on/off logo, then press and hold for a few seconds
Oct 17, 2014 | Freezers
How do I reset blinking code, 33 E, on Samsung French door fridge after power outage?
33 E code, hold energy saver button and the lighting button at the same time for 6 to 10 seconds
Oct 13, 2014 | Samsung RF323TEDBSR 31.6 Cu. Ft. French...
How do I fix a Freezer door alarm went off How do I reset the freezer?
Hello Friend, this is Z. I am happy to assist you!
From what you have described it sounds like your freezer may possibly be in the OFF position or lock which may occur after a power outage or alarm. In the meantime, let's attempt resetting your freezer by pressing and releasing the "UP" arrow three times within three seconds or the "DOWN" arrow three times within three seconds. If an LC appears, then your control is locked. Then repress and hold the control lock key and try the procedure above. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your freezer status has changed successfully.
Jul 29, 2014 | Frigidaire Freezers
How to unlock control panel LFFH21F7HWG?
Press and hold the Control Lock key for three seconds
to activate or deactivate the function. The Control Lock
feature prevents the user from changing the temperature
and freeze settings. At the first press of any key, the
key press click tone will be heard and the display will
show "LO", but no other change will take place. Holding
the Control Lock key for three seconds will activate or
deactivate the Control Lock feature. After three seconds,
the accept tone sounds and the Control Lock LED (if so
equipped) is activated. In lockout mode, when any key
is pressed, the invalid key tone will be heard and "LO"
will be displayed for 1 second. When the lockout is
deactivated, the Control Lock LED is turned off and the
display shows "UL"
if this does not work unplug the freezer for 30seconds then plug it in. if all of the above fails replace the control.
Jul 04, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Power outage and fridge doesnt come back on when power is restored
First make sure there is power to the plug at the wall. If not check the breaker. If power at the plug, the power outage could have been associated with a power surge that killed your refrig.
Mar 21, 2014 | Whirlpool WRF560SMY 19.6 cu. ft. French...
Kenmore 31 cu. ft. French-Door Grab-N-Go Bottom-Freezer Logo
220 people viewed this question
Top Kenmore Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
christian nielsen
Are you a Kenmore Freezer Expert? Answer questions, earn points and help others
