Question about Sub-Zero 650 / O Bottom Freezer Refrigerator
SUb-Zero 650 fridge lighting issue
Sub-Zero refrigerator compartment light not working AND the control panel light not working. Light works in freezer. Fridge and freezer cool as normal. Lights come on after.... some time. Use to power on/off then lights come on.
  • 175 Answers
Just a bad door switch. Turn the unit off, remove the upper grill, then remove the cover over the switches. there are 2. 1 with a black backside, and one that is all white. you want to replace the all white one with a new all white one. it just has 2 wires, doesn't matter what order they go in. pull em off and pop that thing out, then snap the new one into place. all of this should be done with the power off and the door open. Good Luck!
Posted on Jan 22, 2014
5 Suggested Answers
  • 958 Answers
SOURCE: Sub-Zero 650 -- lights/fan not working
you can check the bulb's resistance if they still have. they could be both busted. if they have, the problem could come from thre door switch if you have mechanical door switches that controls bulbs. on the LED read outs, you could have a loose connection to the main board because if the board is not functioning well, then you should not have a cooling refrigerator.
please rate me, i hope i was able to solve your problem.
Posted on Jul 16, 2008
SOURCE: Refridgerator light out, panel out, freezer fine
It's probably the swtich (the one on the left at the top of the door opening).
Posted on Nov 02, 2009
SOURCE: Sub Zero Model 680 - Light in Fridge and Control Panel out
Try wiggling light switch side to side kinda hard, (the light switch is the one on the left) it should come on, showing you its a bad lt. switch.if that fails install 1 new 40watt,(long) appliance bulb. but it is going to be the switch or the bulb considering there wasn't any wiring work done on unit. part# for the light switch is 3060140 make sure the back of the switch is white not black (black is a fan switch) Good Luck !!!
Posted on Mar 04, 2012
  • 9 Answers
SOURCE: Lights all went out in refrigerator side of Sub Zero 632
I WILL BET THEY ARE DISCONNECTED !!!! CHECK FOR CONTINUITY AND SEE WHERE THE CONNECTION IS OUT.
Posted on Oct 13, 2012
My sub zero 600 series has no light in fridge nor on control panel
There will be two switches per compartment, one is the fan switch, the other is for the lights... Remove the top compartment vent panel, the switches will be accessed from above... remove the wires and push them down into the fridge... you can test them by setting a meter to "continuity" test and pressing the paddle of the switch to see if it lets current through.
SUB-ZERO machines are more serial number dependent when ordering parts... http://www.midwestdistributing.com/Store/OpenPages/ManualPage.aspx?PageTitle=MANUALS
Aug 20, 2016 | Sub-Zero 632 / S
Sub Zero 650/s control board light is out and inside lights out but fridge works.
On this model, the lights work with the light switch, if it stick all the light in that section will not work. Parts number 7014646 (about 20 bucks) If only the control display is not illuminated then the bulb behind the control is the only problem.
I hope this helps.
Oct 02, 2013 | Sub-Zero 650 / O Bottom Freezer...
Frost accumulating on back of fridge - service light blinking
YOUR EVAPORATOR IN THE FRESH FOOD SECTION IS LEAKING FREON. THIS IS COMMON WITH EVAPORATORS IN THIS AREA. 12 PART WARRANY OR 6 YEAR FULL ON THIS. SUB ZERO HAS SUPERIOR CUSTOMEER SERVICE AND MAY COVER FULLY IF OUT OF THE 6TH YEAR. 1-800-222-7820 CALL THEM AND ASK.
Apr 23, 2010 | Sub-Zero 650 / O Bottom Freezer...
I have a sub zero 650. It is shutting down intermittently... The light is off on the fridge part but not on the freezer part. It seems to still be running but the fridge unit gets warm and the controls are...
This happens to me when the door gets left open...appears there is some energy saver or something...needless to say we all are very sure that the door closes the whole way after throwing away 3-4 sets of food!
Mar 03, 2010 | Sub-Zero 650 / O Bottom Freezer...
Service light is blinking & code 06 EC flashes on Sub Zero 650
Turned the breaker off to the fridge for 15 minutes and turned it back on.
Jan 01, 2010 | Sub-Zero 650 / O Bottom Freezer...
Sub-Zero 690 Side by Side Refrigerator light switch intermittent
This is a common problem - replace the left light switch with Sub Zero Part # 3060140.
Nov 25, 2009 | Sub-Zero 690 Side by Side Refrigerator
Fridge side light is off. fridge works
check if your bulb is busted, have it replace
Nov 14, 2009 | Sub-Zero 690 Side by Side Refrigerator
My lights are off in the subzero 650.
replace light bulbs or light switch...... is cooling ok?
Feb 24, 2009 | Sub-Zero 650 / O Bottom Freezer...
Sub zero 550 refrigerator light not working
first try to tightin the bulb, it has a seal and it's hard to drive it home. otherwise it could be the door switch.
Dec 22, 2008 | Sub-Zero 650 / O Bottom Freezer...
Sep 01, 2008 | Sub-Zero 680 / F
Sub-Zero 650 / O Bottom Freezer Refrigerator Logo
148 people viewed this question
Top Sub-Zero Refrigerators Experts
Charles T Nevin
Charles T Nevin
Sal De
John Tripp
John Tripp
Are you a Sub-Zero Refrigerator Expert? Answer questions, earn points and help others
