Horstmann t50 instructions
Room thermostat not coming on at times it is set for
3 Suggested Answers
SOURCE: how do i change an old style honeywell room stat
Shut the furnace off for starters. Remove the old Thermostat. As you remove each wire write down what terminal it wen to.
Example:
Red wire usually goes to R-Power
Green Wire usually goes to G-Fan
White usually goes to W-Heat
Blue or Yellow usually goes to Y-Cool
Posted on Jan 06, 2010
rockitman187
  • 2559 Answers
SOURCE: have a new ac system
Yes the temp should rise 2 to 3 degrees before the unit comes on, This is called the temp swing, try lowering the temp setting and wait for the temp to drop, then set it back when you want it.
Posted on Aug 21, 2010
Looking for manual to reset HRFS1 horstmann room thermometer
Try Googling (horstmann)(HRFS1)(manual) without parens.
May 29, 2017 | Heating & Cooling
How can I get a manual for my horstmann t50 thermostat?
You can download a manual for almost any equipment by Googling the make and model followed by the word Manual, then follow the appropriate link(s).
BTW, the Digital Cameras forum may not be the best place for queries concerning domestic appliances.
Oct 03, 2016 | Cameras
How do I set thermostat to come on after burner starts
You are asking a question that makes no sense mechanically, if you mean the fan, it is controlled by the temperature delay or a time delay built into the furnace.
Mar 01, 2015 | Honeywell Electronic Programmable...
Can I put my central heating on a different time from my water horstmann didam 425
It appears there are 4 trippers on the daily time dial that control all timing. 2 On and 2 OFF
On the right side are override switches for Hot water and Heating
You can only separate Hot water and Heater programming a little bit.
You can choose to have Hot water ON all day, or turn on-off once per day or turn on-off twice a day. Or OFF all day.
The Heater has the same options and the same on-off times as the Hot water.
Manual:
http://www.horstmann.co.uk/files/2513/9867/2118/user_guide_425-TiaraDiadem1.pdf
For fully separate programming, where Hot water and Heater can each be programmed differently, you would need a 2-channel controller like the Grasslin QE2
http://www.grasslin-controls.co.uk/towerchronqe2.html
http://waterheatertimer.org/pdf/Grasslin-QE1-QE2_GB-instructions.pdf
Gene
Oct 11, 2014 | Water Heaters
Honeywell troubleshoot
Is the temp in the room higher then the tstat setting? If so the unit will not come on. Try setting it up to maximum, it should then come on within a few minutes.
Aug 18, 2014 | Heating & Cooling
It is increasing temp 2 hours before scheduled
Most programmable thermostats are "smart stats" which use a programmed algorithm base on a preprogrammed P (proportional) I (Integral) D (derivative) Loop. To make a long story short, the programmed temperature will make the room that temperature by the programmed time. This is based on how long it has taken it in the past to bring the room up or down to temperature. So if your setpoint is 70, and your set time is 7 AM, then the furnace or AC will bring the room to that temperature by the set time...not start at the set time.
Dec 04, 2013 | Heating & Cooling
MH035FNCA
the thermostats work from the room temperature and not outside temp
could be a problem with the thermostats or the setting procedure
Oct 29, 2017 | Samsung Heating & Cooling
Have a new ac system installed thermostat is set at 76 shows room and setting the same all the time shouldn't the room temp rise before unit comes on.
Aug 21, 2010 | Computers & Internet
Heating & Cooling Logo
455 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
