Question about Kitchen Ranges
Oven wont shut off - Kitchen Ranges
My Gibson Oven oven door will not shut because lock mechanism wont retract?
You almost certainly have a bad lock motor & latch assembly. Please provide model & serial # if you'd like more help, and with more detail on exactly what it will take to repair the oven.
Jul 27, 2016 | Ovens
GE Built In Wall oven JTP25SOH6SS wont completely shut off
The cooling fan will stay on for a long time after using the oven. It should shut off after a while. If it is running all night for instance there is a great possibility that a relay is stuck on the control board.
Apr 13, 2014 | GE Ovens
Oven light wont turn off
make sure the door is shut tight and making the switch
Jan 04, 2014 | Maytag 30" Built-In Single Electric Wall...
Oven door wont shut
There might be some obstruction at the bottom of the door or in the joints, or you could open it all the way push on the top of the door just a bit and see if it moves in if it does try closing it again.
Dec 26, 2013 | Ovens
Oven wont shut off
replace the switch behind the knob
Jun 27, 2012 | Tappan 30IN ELEC IGNa Oven
My heat element stay on and wont turn off
Here is a tip that I wrote about why an electric oven will not shut off.
Electric Oven Problem Oven will not shut off
heatman101
Apr 17, 2011 | Ovens
The heat wont turn off
heatman101
Apr 01, 2011 | Smeg DO 10PSS Stainless Steel Electric...
Oven door wont stay shut
U need to fit new door hinges, only solution as they are not adjustable.
Plz rate my solution.
Thanks.
Dec 30, 2008 | Kenmore 30464 / 30465 / 30469 Gas Single...
Oven Heat
THE OVEN SWITCH IS BAD ITS STAYING CLOSED.FAIRLY EASY TO REPLACE AND NOT THAT EXPENSIVE.ANY APPLIANCE STORE CAN ORDER THE PART OR YOU CAN FIND IT ONLINE.
Aug 28, 2007 | Kenmore 91112 / 91114 / 91117 Electric...
Kitchen Ranges Logo
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
