Question about iHome Ih120b Refurbished Dual Alarm Clock
How to fix the ih120b
Wont turn on, show time or play music, does charge
Wont turn on when not plugged in. but will turn on if charg plug is plugged in and you turn on the power switch and unplug the charger it will stay on but wont play, keeps coming up format error.
Customer Reviews: Kubik Evo 8GB MP3 Player with Radio ...
www.amazon.com/Kubik-Player.../B0041MMMWW
Amazon.com, Inc.Find helpful customer reviews and review ratings for Kubik Evo 8GB MP3 Player with ... Con's - Wonder if some of these items can be fixed with a firmware update. ... Just push the main button (or any button) and it will turn on and function as usual. ... 2) Play while plugged in charging works with the wall charger, but still NOT ...
Evo won't charge via USB ' Android Forums
androidforums.com > Android Phones > HTC EVO 4G
Jun 29, 2010 - Whenever I plug in my Evo, I select Charge Only (or if I do nothing, it selects Charge. ... If I turn off my Evo it charges from the USB fine. ... Check your computer's stats... what does it say about its USB status when your Evo is plugged in or ... I had a problem a while back where it would charge via USB, but not ...
Dec 29, 2015 | Kubik Digital Electronics Kubik Evo 8Gb...
Car will turn over and wont crank at times
Your alternator isn't charging your batter and needs to be replaced, your battery no longer holds a charge or doesn't have enough cranking amps for the application and that only applies if you aren't playing your music without the motor running. If you play music without the motor running it's going to drain your battery, sure, it'll still play music but the amps will be too low to turn the motor over fast enough to catch the timing on the motor in order to start it. Winter is hard on batteries as well, that's why they have cranking amps and cold cranking amps.
Mar 04, 2011 | Car Audio & Video
Wont charge properly, music only last 5 minutes or so
Hello there :)
Try to chance the battery and see if it helps or read this site :
http://rubensmenswear.com/pages/photographs/oakley/mp3/oakley%20thump%20faqs.htm
The write on the site :
5. I'm sure my THUMP is fully charged, so why doesn't it play music?
  • Make sure the volume is not set too low to hear.
  • Make sure there are song files stored on THUMP. Connect THUMP to your computer and open the folder that shows the contents of the THUMP memory
  • Make sure you have the correct music file formats loaded into the THUMP memory. Currently, THUMP plays MP3, WMA and WAV file formats. No other music file formats are supported at this time.
  • Make sure the WMA music files you are trying to play are not protected by DRM. (See below for more information on DRM.) If the song files are protected by DRM, you need to download the DRM Enabled Utility found at www.oakley.com/thump.
6. Why can't I get a full six hours of song play time out of THUMP?
  • Many things affect play time, including the volume level, file compression and music file format. Also, lithium ion polymer batteries gradually lose their charge while not in use. These batteries are also susceptible to temperature.
  • Even though they represent the best technology available, lithium ion batteries do not perform best in high heat.
7. Is it best to completely drain the THUMP battery before recharging?
  • It makes no difference. Lithium ion batteries have no "memory effect" like older technologies such as nickel cadmium, so you can charge them at any time - even when they are not fully discharged.
Hope thats helps
If not then try to return here
Please rate my answer :)
Jun 10, 2010 | Oakley Thump MP3 Player
I have a sylvania mp3 player 4gb and it wont let me put music on it. when i plug in the usb cord it doesnt even show up on the computer...help!!!
First, try another USB cable. Cheap players often come with broken cords. If it still won't work send it back, it's broken.
Jun 14, 2009 | iLO MP3 Player
Music on the hard drive but wont show up in music files.
on the player: menu, settings, system, update ARClibrary.
Mar 07, 2009 | Archos 605 WiFi Digital Media Player
My ipod 2gb need help!!!!!!!!!!!
Please restore it and check
Oct 11, 2008 | Apple iPod nano
Screen wont come on but music plays
Try getting the screen fixed.
Aug 01, 2008 | RCA S1000 MP3 Player
The new ipod nano
How old is it? if it's under warranty apple may fix it.
Simply, if you charge your iPod through you computer then the battery could be damaged. USB ports only put out 5 volts. If you have an AC charger that puts out 9.5 volts then consider charging it with that. Some AC adapters only put out 5 volts for the purpose matching the USB standard, but it's not good for the ipod.
Check out VaxTex @ http://www.vaxtex.com
hope this helps
Jun 27, 2008 | Apple iPod nano 3rd Generation
Blue opal 2 GB M4002 not working
I have the same **** problem! Except I never dropped it or anything! I just hooked it up and it wont frikken recognize it. WILL SOMEONE PLEASE HELP! DDD: email me at Keeah5@hotmail.com ;_; This is soo agrivating.
Jan 23, 2008 | RCA OPAL M4001 MP3 Player
iHome Ih120b Refurbished Dual Alarm Clock Logo
Top iHome Audio Players & Recorders Experts
ray gallant
Tom Chichester
Are you an iHome Audio Player and Recorder Expert? Answer questions, earn points and help others
