Question about Maytag Refrigerators
Ice Dispenser Door does not close - Maytag Refrigerators
  • 4 Answers
Check door to see if it needs adjustment or check for ice around seal
Posted on Jan 03, 2014
dididsaythat
  • 291 Answers
SOURCE: Frost buildup on ice/water dispenser
Is the trap door flap closing properly where the ice comes through the door? If open, warm air would be coming in frosting and maybe iceing things up
Posted on Aug 28, 2007
aasc
  • 1606 Answers
SOURCE: ice dispenser door flap will not close.
Remove the top freezer hinge hover on top of the freezer door . Unplug the receptical there ( this will remove power to the door only ) .
Using a small screwdriver at the "crease" on the bottom of the dispensor control board inside the dispensor , twist slightly to disengage the 2 clips ( 1 on each side ) holding the dispensor board . Unplug the 3 connectors from the board . 4 screws ( 1 on each corner ) hold the dispensor housing shield . Remove these 4 small screws . After removing , at the top right , you will see a solenoid and plunger . These are probably rusted , holding the flap open . The part number for the solenoid and plunger is WR62X10055 . 3 screws hold this part on . When reinstalling the dispensor housing , It slides back on 2 "grooves" so make sure it is back in place , or the board will not snap back on properly at the bottom .
Posted on Sep 02, 2009
  • 534 Answers
SOURCE: frost buildup inside freezer door at ice dispenser
you are still not getting a seal on that flap. It sounds as if it may be warped. THe reason the frost and ice is building up is due to the flap not sealing there isn't any other reson for your problem. Good luck on your repairs
Dave
Posted on Oct 06, 2009
eXistinZ
  • 7 Answers
SOURCE: LG LSC27931st.ice dispenser flap doesnt close after ice drops
Not that this is much help, but I have the same problem with the same model.
Posted on Feb 10, 2010
SOURCE: lights on panel blinking. ice dispenser keeps opening and closing
there is the HV board on the back under a cover . 2 680uf capacitors @ 35v are likely domed instead of flat on the top and are likely hot. replacing these with an equal value will cure the problem. they are in parallel so 1000 and 470uf will cure it. mine was same model except white. local dealer said no warranty. did not call maytag but he indicated it might help. good luck
Posted on Jun 02, 2010
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
My ice maker is making snow in the dispenser area---What can I do to resolve this?
I would look at the dispenser door to be the issue not the ice maker. This door if not closed will allow warm air to enter the freezer and create frost.
You would look into the dispenser door and clear the ice out, use a flashlight, open and close the dispenser door, if you see light after this. replace the dispenser door and or bar, spring, or other related part to the dispenser.
Good Luck
Oct 12, 2011 | Kenmore Side by Side Refrigerator
Frigdaire model GLHS68EGW2 Ice dispenser does not work on side door. I pulled out the ice tray and held in the switch on the door and pushed on the ice dispenser on the door and no movement on the ice...
The paddle serves as an off and on control for your dispenser, auger and trap door that retains cold air in freeze when finished getting ice it also closes. If you notice something different I would want to rule that out first. Click Here=> GLHS68EGW2 Water Dispenser Parts Breakdown for a larger view, part 24 in photo. You May find the partts here also=> 241685701 or here=> 241685701
for additional assistance I will be here to help you, Thanks Sea Breeze
Aug 19, 2010 | Refrigerators
Ice dispenser appearing to get stuck in the open
The noise is probably the solenoid which operates the door or the one that switches it from cube to crushed ice. Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} You'll have to look to see what's wrong.
Remove the dispenser cover by gently prying starting at the bottom going round and round a little at a time to prevent from breaking it. When it's off the screws will be exposed to access the other components.
Here's a diagram of the dispenser which may help.
http://www.appliancepartspros.com/partsearch/model.aspx?model_id=48122&diagram_id=656733#d656733
Jan 08, 2010 | Maytag MZD2768G Side by Side Refrigerator
In door ice dispenser runs without stopping.
The door switch for ice dispenser is stuck on and will need to be replaced.
Oct 02, 2009 | GE Monogram ZDI15C Automatic Icemaker
Ice dispenser door not closing fully and ice is forming in the opening. How do I remove the panel to replace the dispenser door mechanism?
The hood,Canopy has to be snapped apart at the bottom, then slid upwards to disengage the retainer tongues at the top, of which there are three. Then I was able to see that the connecting rod on the damper which causes the ice dispenser door to close slowly, was bent and about to break and interfering with the dispenser door flap not to close fully.
Aug 24, 2009 | Refrigerators
Ice Maker Dispenser Motor Won't Stop Running
There is a plastic part in the dispenser that holds the micro switch that operates the auger motor when you push the paddle. If you're handy with hand tools, you can order the part and replace it yourself. The part is on the outside of the door.
Jun 15, 2017 | Kenmore Refrigerators
Ge, tfx26kpda ww, ice maker only dispences crushed ice
At least yours is making ice. Mine wount even make ice. While toubleshooting my prob, I notice a metal rod on the bottom of the ice tray. This rod opens and shuts a plastic "trap door" in the tray. The position of that door determines whether the ice is crushed or whole. If the trap door is open the ice falls through the dispenser freely. If the door this closed the ice is force thorugh metal teeth where it is crushed then dispensed. Open the freezer door and take the ice tray out. You should see a hole at the back of the freezer that the metal rod goes through. In that hole there is a plastic square that moves up and down. If the set your dispenser to crushed ice, leave the door open, push in the door switch at the bottom, and press the dispenser. The plastic square does nothing while the motor is turning. That allows the door to stay closed and forces the ice through the metal teeth. If you set the dispenser to whole ice and do the same thing the plastic square is suppose to lift up forcing the door open and letting the whole ice drop freely. The plastic square probably does nothing even if you set it to whole ice. That mean the trap door never opens focing the ice to always get crushed.
Unfortunately, I have no solution because mine works and I had no need to investigate further. I hopes this helps you figure out the problem though
Good Luck.
Jan 15, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
Amana side by side with ice/water in the door freezer stops freezing about 8 yrs old
First of all the worst thing you can do is set your fridge on the highest setting even though it has it. That's live reving your car to the red line just because it has it. As far as your challenge is concerned, it sounds like a breach in the seal of the fridge or dispenser. Check to see if the ice despenser is closing properly after use and check the door seal to make sure it's closing tight when the door is closed. To do this, simply inspect it for any bad wrinkles, cracks, folds, etc. if none are visible close the door on a dollar bill and make sure it holds securly all the way around the door. I f it doesn't, the seal may need to be replaced and/or the door is warped. If you continue to have issues, post again, we will work this out.
Jan 15, 2009 | Amana 22.6 cu. ft. Side-By-Side...
Ice dispenser comes on by itself.
you need to replace the dispenser selector board.
Sep 03, 2007 | Frigidaire FSC23F7D Side by Side...
Refrigerators Logo
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
isaac johny
isaac johny
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
