Question about Proform Pro-form 600 Lt Treadmill In Ct
Treadmill won't go back to 0 incline - Proform Pro-form 600 Lt Treadmill In Ct
4 Suggested Answers
erpaalai
  • 999 Answers
SOURCE: My Proform treadmill will not incline. It is stuck
Under the hood there should be a tech sheet with calibration instructions. I have not worked on these for several years or I would rattle off the procedure. If the sheet is still there make sure you put it back in the plastic sleeve for next time..... Eric
Posted on Jun 17, 2009
ercupa190
  • 12223 Answers
SOURCE: My treadmill won't start. It sounds like it is inclining when I insert the key but nothing lights and it is not moving.
Dear Sir:
Inside test the fuse and replace use DVOM, or reset the c.breaker
2) Adjust the reed switch see the diagram attached, clean,and tight the connector very well. Tigh the ribbon cable from keypad + connector from display board vs lower board
3) Lube the deck vs deck belt, this produce enough friction.
4) test the input motor voltage,if there are the motor need repair or replace
5) Test the output voltage from the m.motor board for the input motor voltage, if there are NOT the board is faulty.
6) Try after your fix, the software calibration for diagnose, and troubleshooting.
sincerely. God bless you
Posted on May 02, 2012
rozell26
SOURCE: treadmill keeps inclining and declining
I have a Proform ZT5 model - had the same incline/decline problem. It needed calibrated.
- unplug, turn off, and take the key out
- plug machine in
- turn switch on
- Pres and hold the STOP and SPEED UP button at the same time, while holding them insert the RED KEY
- let go of both buttons
- press STOP 1 time
- pres INCLINE UP 1 time
- this should reset it.
The tech on the phone mentioned the importance of turning the maching off, taking the key out, and unplugging after each use. Leaving it plugged in there is still an electrical current running and this can cause more seriouc problems that require a new control panel.
Posted on Aug 28, 2012
Adjust incline on weslo cadence g 5.9 bought it used no manual
On the rear of walking deck you have the left and right feet. Down the deck is at 0 degree incline, fold them up and you have a 3 degree incline.. You have no incline motor on this model.
Mar 02, 2015 | Cadence Weslo 825 Treadmill Walking Belt
The treadmill on my Roger Black Gold Treadmill won't move when the power is on. The board lights up and the incline etc works but the treadmill just won't move. Can anyone help me please?
please see the video and proceed according, LUBE the rollers bearing very IMPORTANT!
However , if the problem persist your must test a) main motor+belt
b) main control motor board see the block diagram attached.
God bless you
Jan 04, 2013 | Exercise & Fitness
Incline won't shut off
Please RUN The software calibration for diagnose, troubleshooting and fix it.
download your inst.manual from www.iconservice.com or www.fitness.manualsonline.com and proceed according
God bless you
Jul 18, 2012 | Icon Proform 560 Crosstrainer Treadmill
Incline reads 0.0 but is not all the way down
Renee, Here is how to recalibrate the incline motor. Read all of it It will be good to keep.
Plug in your treadmill, do not stand on the walking belt. Hold down the "Stop" and "Speed +" key and insert the safety key or magnet, let go of the two keys. Now press "Stop" key once. This puts you into the level 2 of calibration. Press the "Speed +" key slowly until you see 85 on the console, (at this point the display is going to show the percentage of motor usage and also the actual walking belt speed) at 85% motor usage your top speed should be between 10 and 10.5 MPH or (of 12 and 12.5) depending on the treadmill. You must know your treadmills top speed. (Important the motor may be damaged if you set the maximum speed higher than the maximum speed that your treadmill is made for). If the speed is higher than 10.5 or 12.5 then you need to turn the potentiometer down to the correct level. If the speed it to low you need to turn the potentiometer higher. Once the speed is correct you are done calibrating the speed. Press the (-) speed key to lower the percentage to (0). Next press the incline (+) button, this will make the incline motor go all the way to the maximum incline and come all the way down to the level position. Then remove the safety key and the treadmill will reset into the normal manual mode, when you re-insert the safety key. Matt
Dec 04, 2011 | Nordic Track NordicTrack Treadmill, A2550
I have a series 7 Bowflex treadmill. Though the incline reads 0, it is still somewhat inclined. We can raise the incline but it will not go flat. This prevents us from folding it up as well as using it...
There will be some faulty in the transformer and controller board:
Watch this videos and tips:
http://www.youtube.com/watch?v=TquYcOzGIw4&feature=related
http://www.youtube.com/watch?v=9G4MZh8JO2Q
http://www.youtube.com/watch?v=M7qJrRbdfBc
http://www.youtube.com/watch?v=MIIxoPtvhy8hthttp://www.fixya.com/support/r10724803-measure_voltage_in_transforme_fitnesshttp://www.youtube.com/watch?v=bF3OyQ3HwfU&feature=relatedIf need further assistance, reach me, sincerely.
Nov 13, 2011 | Bowflex Series 7 Treadmill Msrp 199999
My nordictrack is stuck on a program &wont let u do anything else..cant change the speed or incline &the fans wont turn on..its like the consol is frozen or stuck on a program..how can i reset it...
How to Troubleshoot a Nordic Track C2500 X15616db0-ef56-4f0a-afbd-b1ae3379f47f.small.jpg Jolie Johnson
Based in Austin, Texas, Jolie Johnson has been in the fitness industry for over 12 years and has been writing fitness-related articles since 2008 for various websites. She received her Bachelor of Arts in English and philosophy from the University of Illinois.
By Jolie Johnson, eHow Contributor
updated April 15, 2011
Related Searches:
The NordicTrack is a treadmill designed for in-home use. It offers a speed range of 0 to 10 mph and an incline range of 0 to 10 percent. It folds up vertically to save space when you aren't working out and can be rolled to a different room. The console has 16 preset workout programs and features iFit interactive technology. If you have problems with the console or walking belt, you can often fix them yourself with some basic troubleshooting steps
Instructions
  1. Power Turns Off When You're Using the Treadmill
    • 1 Check the reset switch on the bottom of the treadmill near the power cord. If it has tripped, the top of the switch will protrude. Wait 5 minutes then press the switch.
    • 2 Check that the power cord is plugged in completely. If it is plugged in, unplug it, wait 5 minutes then plug it back in.
    • 3 Remove the magnetic key from the console then reinsert it.
    The Console Won't Turn Off
    • 1 Insert the magnetic key into the console. Your C2500 is stuck in demo mode if the console won't turn off after you remove the magnetic key from the console.
    • 2 Hold the "Stop" button down for a few seconds.
    • 3 Press the "Speed" down (-) button. Remove the magnetic key.
    The Incline Does Not Change Correctly
    • 1 Press and hold the "Stop" and the "Speed" up (+) button. While holding the buttons, insert the key into the console, then release the buttons.
    • 2 Press either the "Incline" up or down arrow button. Wait while the incline raises and lowers. This recalibrates the incline system.
    • 3 Remove the key from the console.
    Walking Belt Slows
    • 1 Unplug your C2500 and remove the key from the console.
    • 2 Turn both rear adjustment bolts, located on the back of the walking deck, to the left, a 1/4 turn.
    • 3 Lift the edge of the walking belt in the middle of the deck. You should be able to lift it 2 to 3 inches off the walking platform. If the belt is still too tight, loosen the bolts another 1/4 turn each.
    • 4 Plug the treadmill in and reinsert the console key. Walk on the belt at a slow speed to see if it still slows. Repeat Step 2 if necessary.
Sep 27, 2011 | Nordic Track NordicTrack Treadmill, A2550
Epic treadmill t60 is stuck in max incline how do
Usually when stuck at the max up position it indicates that you may need a new incline motor. It is not the sensor. I have been repairing treadmills for 15 years and incline sensors seldom if ever go bad. If can isolate the incline motor using a 110 volt power cord, this may un-jam the motor and get it back down to 0%.
I use www.treadmillpartszone.com for parts.
Jul 25, 2010 | Icon Epic T60 Treadmill
Incline problem
Make surt that there is nothing under the treadmill that could get caught in the mechanism.
Feb 05, 2009 | Reebok 8700 ES Treadmill - Silver Service...
Proform Pro-form 600 Lt Treadmill In Ct Logo
Top Proform Exercise & Fitness Experts
Ross Metcalfe
Ross Metcalfe
Matt Olenzek
Matt Olenzek
 Atlanta Fitness
Atlanta Fitness
Level 1 Expert
Are you a Proform Exercise and Fitnes Expert? Answer questions, earn points and help others
